Page 1 of 1
[SOLVED] tis-deepl problem
Published: September 16, 2026 - 3:41 PM
by Mikael S
We are having a problem with the tis-deepl package. The installation completes successfully, but the application crashes
Application: DeepL.exe
CoreCLR Version: 10.0.1226.42308
.NET Version: 10.0.12
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException: Could not load file or assembly 'Sentry, Version=6.8.0.0, Culture=neutral, PublicKeyToken=fba2ec45388e2af0'. Le fichier spécifié est introuvable.
File name: 'Sentry, Version=6.8.0.0, Culture=neutral, PublicKeyToken=fba2ec45388e2af0'
at Sentry.Generated.BuildPropertyInitializer.Initialize()
at .cctor()
Nom de l'application défaillante : DeepL.exe, version : 26.8.2.20990, horodatage : 0x693c0000
Nom du module défaillant : KERNELBASE.dll, version : 10.0.26100.9444, horodatage : 0x28606b21
Exception code: 0xe0434352
Fault offset: 0x00000000000c41ca
Identifiant du processus défaillant : 0x360C
Heure de début de l'application défaillante : 0x1DD45E0D9E34427
Chemin de l'application défaillante : C:\Program Files\DeepL\DeepL.exe
Chemin du module défaillant : C:\WINDOWS\System32\KERNELBASE.dll
ID du rapport : d50b5806-ea48-4f29-a86e-e6ffabef1ec2
Nom complet du package défaillant :
Package défaillant – ID d'application relatif :
The application works correctly with the official installer.
Are you experiencing the same problem?
Re: tis-deepl problem
Published: September 17, 2026 - 11:38 AM
by kcherel
I've just corrected the code; could you try modifying setup.py with this code?
from setupdevhelpers import unzip_with_7zip
Usage of the DeepLSetup.exe seems to crash when there is already 0install installed.
It tries to override the 0install directory in Program Files (C:\Program Files\Zero Install\)
We are now doing a portable install of DeepL with the sources downloaded from 0install executable.
This allow to avoid a lot of complication due to the usage of 0install and wrong usage of 0install by Deepl.
app_name = "DeepL"
app_dir = makepath(programfiles, app_name)
app_path = makepath(app_dir, f"{app_name}.exe")
icon_path = app_path
audit_version = True
# Uninstalling older package version (if deepl in registry, it is old package version)
for to_uninstall in installed_softwares(name="DeepL"):
print("Removing: %s (%s)" % (to_uninstall["name"], to_uninstall["version"]))
run(uninstall_cmd(to_uninstall["key"]))
wait_uninstallkey_absent(to_uninstall["key"])
# Declaring local variables
archive_name = glob.glob(f"{app_name}.zip")[0]
# Installing software
if isdir(app_dir) and force:
remove_tree(app_dir)
bin_name = glob.glob("DeepLSetup.exe")[0]
run(bin_name + r" --machine --verysilent")
# Creating custom shortcuts
create_desktop_shortcut(bin_name)
create_programs_menu_shortcut(bin_name)
def audit():
# Auditing software
audit_status = "OK"
installed_version = get_installed_version(app_path)
if Version(installed_version) < Version(control.get_software_version()) and audit_version:
print("%s is installed in version (%s) instead of (%s)" % (app_name, installed_version, control.get_software_version()))
audit_status = "WARNING"
elif isdir(app_dir) and not dir_is_empty(app_dir):
print("%s (%s) is installed" % (app_name, installed_version))
audit_status = "OK"
print("%s is not installed" % app_name)
audit_status = "ERROR"
return audit_status
# Uninstalling software
if isdir(app_dir):
# Removing shortcuts
remove_desktop_shortcut(app_name)
remove_programs_menu_shortcut(app_name)
Published: September 17, 2026 - 11:44 AM
by Mikael S
with this setup, it works correctly.
Regards,
Published: September 18, 2026 - 10:16 AM
by Mikael S
except for the audit, which is no longer good
Published: September 18, 2026 - 12:28 PM
by kcherel
Yes, indeed, I just noticed. You can try again with this code:
app_name = "DeepL"
def audit():
print("Auditing: %s" % control.package)
if installed_softwares(name=app_name):
print("%s is installed" % app_name)
return "OK"
return "ERROR"
if isdir(app_dir):
run(to_uninstall["uninstall_string"])
Sorry for the mistake, it will be available in production on the store in 5 days.
Kevin.
