[RESUELTO] Office 2019 de 64 bits
Eyji
Inscripción: 15 de febrero de 2022 - 09:32
16 de marzo de 2023 - 11:43
He creado un repositorio para instalar Office 2019 en 32 bits y funciona muy bien.
Mi problema es que me gustaría hacer el mismo paquete pero para una instalación de Office 2019 de 64 bits.
¿Podrías decirme qué error pude haber cometido?.
# https://github.com/YerongAI/Office-Tool
# You should also check for the uninstall string for uninstall_args by using : wapt-get list-registry Office
# raccourcis
RaccourcisDossierProgramm1 = makepath(programfiles32,"Microsoft Office","root","Office16")
softname = "Microsoft Office Professional Plus 2019 - fr-fr"
pgmsoffice = programfiles
uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
    killalltasks('WINWORD.EXE')
    killalltasks('POWERPNT.EXE')
    killalltasks('EXCEL.EXE')
    killalltasks('MSPUB.EXE')
    killalltasks('MSACCESS.EXE')
    killalltasks('INFOPATH.EXE')
    killalltasks('lync.exe')
    killalltasks('ONENOTE.EXE')
    killalltasks('OUTLOOK.EXE')
    killalltasks('ONENOTEM.EXE')
    killalltasks('MSOSYNC.EXE')
    killalltasks('GROOVE.EXE')
    print('installing %s'.format(control.asrequirement()))
    office_installed = installed_softwares(softname)
    cmd = r'"setup.exe" /configure "Configuration-office2019.xml"'
    if not office_installed:
        print('Installing {}'.format(softname))
        if Version(office_installed[0]['version']) < Version(control.version.split('-',1)[0]):
            print('{} already up to date or newer : {}'.format(softname,office_installed[0]['version']))
        error(' {} has been installed but the uninstall key can not be found'.format(softname))
    create_desktop_shortcut(r'Word',target=r'C:\Program Files\Microsoft Office\root\Office16\WINWORD.EXE')
    create_desktop_shortcut(r'Excel',target=r'C:\Program Files\Microsoft Office\root\Office16\EXCEL.EXE')
    create_desktop_shortcut(r'Outlook',target=r'C:\Program Files\Microsoft Office\root\Office16\OUTLOOK.EXE')
    create_desktop_shortcut(r'PowerPoint',target=r'C:\Program Files\Microsoft Office\root\Office16\POWERPNT.EXE')
Archivo de configuración XML
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019">
    <Product ID="ProPlus2019Volume">
      <Language ID="fr-fr" />
    </Product>
  </Add>
  <RemoveMSI>
    <IgnoreProduct ID="VisPro" />
    <IgnoreProduct ID="VisStd" />
  </RemoveMSI>
  <Display Level="None" AcceptEULA="TRUE" />
</Configuration>
Gracias de antemano.
dcardón
16 de marzo de 2023 - 14:06
Hola Mehdi,
¿cuál es tu versión de WAPT, versión del sistema operativo (servidor/cliente), edición, etc. (consulta las reglas del foro más arriba)?
¿Cuál es el mensaje de error original?
Saludos,
Eyji
16 de marzo de 2023 - 14:36
Estoy en la versión 2.3.0.13516, servidor DEBIAN 10.9 / cliente Windows 10 LTSC 21H2.
Aquí está mi mensaje de error.
  File "C:\Program Files (x86)\wapt\common.py", line 4001, in install_wapt
    setup = import_setup(setup_filename)
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1520, in import_setup
  File "imp.py", line 171, in load_source
  File "<frozen importlib._bootstrap>", line 702, in _load
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 843, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "C:\Windows\TEMP\waptom4sqfqv\setup.py", line 8, in <module>
NameError: name 'makepath' is not defined
Atentamente,
Mahdi
dcardón
16 de marzo de 2023 - 18:03
Hola de nuevo Mehdi,
Las siguientes dos líneas deben mantenerse en el encabezado del paquete:
# -*- coding: UTF-8 -*-
makepath es una función wapt/setuphelpers y no una función nativa de Python.
Atentamente,
Eyji
17 de marzo de 2023 - 11:07
lamento mucho haberte molestado con esto; no me había dado cuenta de que no había copiado todo. :?
Gracias por tu pronta respuesta.
Que tengas un buen día,
Mehdi.
dcardón
23 de marzo de 2023 - 16:41
No te preocupes, Medhi. ¡Gracias por tus comentarios!
