Estoy experimentando un problema con la actualización de Windows de WAPT que no funciona.
Inicialmente intenté usar un paquete wsus para desbloquear actualizaciones, pero no funcionó.
A continuación, ejecuté el comando "wapt-get waptwa-scan" y me devolvió esto:
wapt-get waptwua-scan
2023-07-10 09:27:55,696 INFO User Groups:[]
2023-07-10 09:27:55,696 DEBUG Host certificate C:\Program Files (x86)\wapt\private\03000200-0400-0500-0006-000700080009.crt not found, not using it for auth on repo global
2023-07-10 09:27:55,696 INFO WAPT base directory : C:\Program Files (x86)\wapt
2023-07-10 09:27:55,696 INFO Package cache dir : C:\Program Files (x86)\wapt\cache
2023-07-10 09:27:55,696 INFO WAPT DB Structure version: 20210420
2023-07-10 09:27:55,696 CRITICAL Bad persistent dir for package Maj windows
2023-07-10 09:27:55,696 CRITICAL Bad persistent dir for package wsus-all
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
"direct_download":false,
"default_allow":false,
"include_potentially_superseded_updates":false,
"filter":"Type='Software' or Type='Driver'",
"download_scheduling":"1d",
"install_scheduling":"2h",
"install_delay":"None",
"postboot_delay":"10m"
2023-07-10 09:27:56,228 DEBUG Host certificate C:\Program Files (x86)\wapt\private\03000200-0400-0500-0006-000700080009.crt not found, not using it for auth on repo wapt
2023-07-10 09:27:56,228 INFO Main repository: https://SRV-WAPT.mairie.mdm/wapt
2023-07-10 09:27:56,228 DEBUG Unable to get or create host key: [WinError 5] Accès refusé: 'C:\\Program Files (x86)\\wapt\\private\\03000200-0400-0500-0006-000700080009.pem'
2023-07-10 09:27:56,228 DEBUG Host certificate C:\Program Files (x86)\wapt\private\03000200-0400-0500-0006-000700080009.crt not found, not using it for auth on repo wapt-host
2023-07-10 09:27:56,228 DEBUG Host certificate C:\Program Files (x86)\wapt\private\03000200-0400-0500-0006-000700080009.crt not found, not using it for auth on repo waptwua
2023-07-10 09:27:56,228 INFO WAPTWUA repository: https://SRV-WAPT.mairie.mdm/wapt
2023-07-10 09:27:56,235 DEBUG Starting new HTTPS connection (1): srv-wapt.mairie.mdm:443
2023-07-10 09:27:56,281 DEBUG https://srv-wapt.mairie.mdm:443 "HEAD /waptwua/wsusscn2.cab HTTP/1.1" 200 0
2023-07-10 09:27:56,281 DEBUG New wsusscn2cab.cab date : 2023-06-13T04:25:13+00:00
Windows updates rules have been changed
2023-07-10 09:27:56,281 DEBUG Scanning installed / not installed Updates
2023-07-10 09:27:56,281 DEBUG DB Start transaction
2023-07-10 09:27:56,281 DEBUG DB rollback
2023-07-10 09:27:56,297 DEBUG Error at DB exit attempt to write a readonly database, rollbacking
[' File "C:\\Program Files (x86)\\wapt\\common.py", line 335, in set_param\n self.execute(\'insert or replace into wapt_params(name,value,create_date,ptype) values (?,?,?,?)\', (name, value, datetime2isodate(), ptype))\n', ' File "C:\\Program Files (x86)\\wapt\\common.py", line 385, in execute\n return self.db.execute(query, args)\n']
re-enabling wuauserv previous state: 2
FATAL ERROR : AttributeError: __enter__
File "<string>", line 1495, in main
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 914, in scan_updates_status
for update in self.updates():
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 801, in updates
self.wapt.write_param('waptwua.status', 'SCANNING')
File "C:\Program Files (x86)\wapt\common.py", line 8123, in write_param
self.waptdb.set_param(name, value)
File "C:\Program Files (x86)\wapt\common.py", line 335, in set_param
self.execute('insert or replace into wapt_params(name,value,create_date,ptype) values (?,?,?,?)', (name, value, datetime2isodate(), ptype))
File "C:\Program Files (x86)\wapt\common.py", line 385, in execute
sqlite3.OperationalError: attempt to write a readonly database
File "<string>", line 1677, in <module>
File "<string>", line 1496, in main
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 2534, in __exit__
registry_set(HKEY_LOCAL_MACHINE, r'SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update', 'AUOptions', self.old_au_options)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3542, in registry_set
with reg_openkey_noredir(root, path, sam=KEY_WRITE, create_if_missing=True) as key:
Exception at 005B3BE5: EPyAttributeError:
AttributeError: __enter__.
sqlite3.OperationalError: attempt to write a readonly database¿Me puedes ayudar?
GRACIAS.
