[RESUELTO] Paquete tis-microsoft-teams-uwp
Gaelds
Inscripción: 22 de noviembre de 2015 - 08:37
27 de febrero de 2024 - 16:55
Quería probar el último paquete de Teams "UWP", pero se bloquea durante la instalación en un comando de PowerShell:
Installing: MSTeams-x64.msix (23335.232.2637.4844)
  File "C:\wapt\setuphelpers_windows.py", line 1194, in run_powershell
    result = run(cmd,
  File "C:\wapt\waptutils.py", line 2174, in run
    raise CalledProcessErrorOutput(proc.returncode, cmd, ''.join(output+return_stderr))
waptutils.CalledProcessErrorOutput: Command 'powershell -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "QQBkAGQALQBBAHAAcAB4AFAAcgBvAHYAaQBzAGkAbwBuAGUAZABQAGEAYwBrAGEAZwBlACAALQBPAG4AbABpAG4AZQAgAC0AUABhAGMAawBhAGcAZQBQAGEAdABoACAAIgBNAFMAVABlAGEAbQBzAC0AeAA2ADQALgBtAHMAaQB4ACIAIAAtAFMAawBpAHAATABpAGMAZQBuAHMAZQA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="progress" RefId="0"><TN RefId="0"><T>System.Management.Automation.PSCustomObject</T><T>System.Object</T></TN><MS><I64 N="SourceId">1</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><Obj S="progress" RefId="1"><TNRef RefId="0" /><MS><I64 N="SourceId">2</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><S S="Error">Add-AppxProvisionedPackage : Élément introuvable._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\wapt\common.py", line 4234, in install_wapt
  File "C:\WINDOWS\TEMP\waptz0_us848\setup.py", line 22, in install
  File "C:\wapt\setuphelpers_windows.py", line 1198, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
Gaelds
28 de febrero de 2024 - 08:19
El comando ejecutado manualmente devuelve el error que se muestra en la imagen adjunta.
- Versión de WAPT instalada (2.5.4.15342)
- Sistema operativo del servidor (Linux/Windows) y versión (Debian 11)
- Sistema operativo de la máquina de administración/creación de paquetes (Windows 10)
Y otra pregunta: En las máquinas donde la instalación funciona, ¿cómo agrego un acceso directo a "Nuevos equipos" en el escritorio o hago que se inicie automáticamente (en segundo plano)?
Archivos adjuntos
2024-02-28 08_18_11.jpg (27,14 KB) Vista 6225 veces
jpele
Inscripción: 4 de marzo de 2019 - 12:01
28 de febrero de 2024 - 16:02
el paquete se solucionó ayer y está disponible en el repositorio de pruebas durante 5 días antes de su lanzamiento en la tienda pública:
https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Saludos,
Jimmy
Gaelds
29 de febrero de 2024 - 12:17
¡Gracias, Jimmy! Esta versión se instala sin errores. Ahora solo necesito averiguar cómo hacer que el nuevo Teams se inicie al iniciar, o al menos crear un acceso directo en el escritorio.
dcardón
29 de febrero de 2024 - 12:19
Hola Gaël,
gracias por tus comentarios. :-) Microsoft está causando muchos problemas con Teams últimamente; hemos visto usuarios con cinco versiones diferentes instaladas en la misma máquina... El método de implementación cambia cada mes; es bastante caótico.
Un saludo,
