[RESUELTO] Paquete de cliente de escritorio Zulip
vnatton
Inscripción: 9 de enero de 2024 - 13:53
26 de febrero de 2024 - 14:56
Hola a todos
Un pequeño fragmento de código para limpiar la instalación y actualización del cliente de escritorio Zulip para Windows de 64 bits
Buen día
Vianney
    bin = "Zulip-%s-x64.msi" % control.get_software_version()
    install_msi_if_needed(bin)
    pass
def update_package():
    import json
    ancienne_version = control.get_software_version()
    # Declaring local variables
    package_updated = False
    proxies = get_proxies()
    if not proxies:
    api_url = "https://api.github.com/repos/zulip/zulip-desktop/releases/latest"
    # Getting latest version information from official sources
    print("API used is: %s" % api_url)
    json_load = json.loads(wgets(api_url, proxies=proxies))
    for download in json_load["assets"]:
        if "zulip-desktop" in download["browser_download_url"] and "-x64.msi" in download["browser_download_url"]:
            download_url = download["browser_download_url"]
            version = json_load["tag_name"].replace("v", "")
            latest_bin = download["name"]
            break
    # Downloading latest binaries
    print("Latest %s version is: %s" % (control.name, version))
    print("Download URL is: %s" % download_url)
    if not isfile(latest_bin):
        print("Binary is present: %s" % latest_bin)
    # Checking version from filename
    version_from_filename = latest_bin.split("-")[1]
    if Version(version_from_filename) != Version(version) and version_from_filename != "":
        print("Changing version to the version number of the binary")
        os.rename(latest_bin, latest_bin.replace(version, version_from_filename))
        version = version_from_filename
        print("Binary file version corresponds to online version")
    if Version(version) > Version(control.get_software_version()):
        print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
        package_updated = True
        print("Software version up-to-date (%s)" % Version(version))
    control.set_software_version(version)
    # Suppression de l'ancien binaire
    if isfile("Zulip-%s-x64.msi" % ancienne_version):
        os.remove("Zulip-%s-x64.msi" % ancienne_version)
    # Validating update-package-sources
    return package_updated
dcardón
29 de febrero de 2024 - 09:46
Hola Vianney,
muchas gracias por el paquete. Ingrid lo revisará para ver si puede integrarlo en la tienda. Parece una herramienta muy buena; la probaremos internamente. :-)
Saludos cordiales,
italbot
Inscripciones: 26 sept 2023 - 15:50 horas.
7 de marzo de 2024 - 10:55
el paquete está listo. Lo encontrarás en la tienda en unos días. :)
Atentamente,
Ingrid.
TI tranquila
