En algunas máquinas con Windows 10 y Windows Server, recibo errores con WUA.
Último estado de error: ValueError: los datos de tiempo '' no coinciden con el formato '%m/%d/%Y'
¿Este problema está solucionado en la última versión de WAPT?
Registros de la tarea Instalar Windows Update:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
"direct_download":false,
"default_allow":false,
"include_potentially_superseded_updates":false,
"filter":"Type='Software' or Type='Driver'",
"download_scheduling":"12h",
"install_scheduling":"6h",
"install_delay":"",
"postboot_delay":"10m"
Connecting to local update searcher using offline wsusscn2 file...
Offline Update searcher ready...
Bypassing scan, no change since last successful scan
Looking for updates with filter: Type='Software' or Type='Driver'
Waiting for WUA search to complete
WUA Search completed !
Done searching
Updates scan done.
re-enabling wuauserv previous state: 0
time data '' does not match format '%m/%d/%Y'
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 931, in update_local_status_as_dict
install_date = str(datetime.datetime.strptime(kbw['InstalledOn'], '%d/%m/%Y'))
File "_strptime.py", line 568, in _strptime_datetime
File "_strptime.py", line 349, in _strptime
ValueError: time data '' does not match format '%d/%m/%Y'
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1934, in run
self.running_task.run()
self._run()
File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 288, in _run
self.result = wua.install_updates(self.force, uuids=self.uuids)
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1640, in install_updates
self.scan_updates_status()
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1260, in scan_updates_status
dict_update_status[self.update_local_status_as_dict(u, _update_history,wmi_installed_windows_updates_result=wmi_installed_windows_updates_result)['update_id']] = self.update_local_status_as_dict(u, _update_history,wmi_installed_windows_updates_result=wmi_installed_windows_updates_result)
File "C:\Program Files (x86)\wapt\waptwua\client.py", line 933, in update_local_status_as_dict
install_date = str(datetime.datetime.strptime(kbw['InstalledOn'], '%m/%d/%Y'))
ValueError: time data '' does not match format '%m/%d/%Y'
self._run()
