07 14:35:11,564 [wapttasks MainThread 11728] INFO Service Configuration: {'config_filename': 'C:\\Program Files (x86)\\wapt\\wapt-get.ini', 'waptservice_user': None, 'waptservice_password': None, 'MAX_HISTORY': 30, 'waptservice_port': 8088, 'dbpath': 'C:\\Program Files (x86)\\wapt\\db\\waptdb.sqlite', 'loglevel': 'warning', 'log_directory': 'C:\\Program Files (x86)\\wapt\\log', 'waptserver': <WaptServer https://serveur.wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=None>, 'hiberboot_enabled': False, 'max_gpo_script_wait': 180, 'pre_shutdown_timeout': 180, 'log_to_windows_events': False, 'allow_user_service_restart': False, 'signature_clockskew': 21600, 'notify_user': False, 'waptservice_admin_filter': False, 'enable_remote_repo': False, 'local_repo_path': 'C:\\Program Files (x86)\\wapt\\repository', 'local_repo_sync_task_period': '2h', 'local_repo_time_for_sync_start': None, 'local_repo_time_for_sync_end': None, 'local_repo_limit_bandwidth': None, 'wol_port': '7,9', 'wol_relay': False, 'service_auth_type': 'system', 'verify_cert_ldap': False, 'waptservice_poll_timeout': 10, 'waptupdate_task_period': '120m', 'download_after_update_with_waptupdate_task_period': True, 'forced_installs_task_period': '2m', 'reconfig_on_network_change': False, 'websockets_verify_cert': 'C:\\Program Files (x86)\\wapt\\ssl\\server\\serveur.wapt.crt', 'update_server_status_on_connect': False, 'loglevel_waptcore': None, 'loglevel_waptservice': None, 'loglevel_waptws': None, 'loglevel_waptdb': None, 'loglevel_websocket': None, 'loglevel_waitress': None, 'loglevel_wapttasks': None}
2024-05-07 14:35:11,564 [wapttasks MainThread 11728] INFO Starting task queue
2024-05-07 14:35:11,564 [wapttasks WaptTaskManager 12976] INFO Wapt tasks management initialized with C:\Program Files (x86)\wapt\wapt-get.ini configuration
2024-05-07 14:35:11,565 [wapttasks MainThread 11728] INFO Tasks queue running
2024-05-07 14:35:11,567 [wapttasks MainThread 11728] INFO Starting waitress waptservice on port 8088
2024-05-07 14:35:11,575 [wapttasks SocketIOClient 16820] INFO Starting socketio on "https://serveur.wapt:443" Thread id 16820
2024-05-07 14:35:11,576 [wapttasks SocketIOClient 16820] INFO Socketio connection params have changed. Socketio needs reconnect
2024-05-07 14:35:11,577 [wapttasks SocketIOClient 16820] INFO Creating socketio client: https://serveur.wapt:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\00222798-6bec-ec11-8145-c83632083293.crt', 'C:\\Program Files (x86)\\wapt\\private\\00222798-6bec-ec11-8145-c83632083293.pem') proxies: None verify_cert: C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt
2024-05-07 14:35:11,577 [wapttasks SocketIOClient 16820] INFO Connecting Socketio to https://serveur.wapt:443
2024-05-07 14:35:11,584 [wapttasks WaptTaskManager 12976] INFO Core Configuration: {'wapt_base_dir': 'C:\\Program Files (x86)\\wapt', 'waptserver': <WaptServer https://serveur.wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=C:\Program Files (x86)\wapt\private\00222798-6bec-ec11-8145-c83632083293.crt>, 'config_filename': 'C:\\Program Files (x86)\\wapt\\wapt-get.ini', 'proxies': {'http': '', 'https': ''}, 'repositories': [<WaptRepo https://serveur.wapt/wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=C:\Program Files (x86)\wapt\private\00222798-6bec-ec11-8145-c83632083293.crt>, <WaptHostRepo https://serveur.wapt/wapt-host for host_id 00222798-6bec-ec11-8145-c83632083293 >], 'personal_certificate_path': '', 'public_certs_dir': 'C:\\Program Files (x86)\\wapt\\ssl', 'package_cache_dir': 'C:\\Program Files (x86)\\wapt\\cache', 'dbpath': 'C:\\Program Files (x86)\\wapt\\db\\waptdb.sqlite', 'use_http_proxy_for_repo': False, 'use_http_proxy_for_server': False, 'limit_bandwidth': None, 'locales': ['fr'], 'custom_tags': [], 'packages_whitelist': None, 'packages_blacklist': None, 'maturities': ['PROD'], 'host_uuid': '00222798-6bec-ec11-8145-c84632783293', 'use_fqdn_as_uuid': False, 'use_hostpackages': True, 'use_ad_groups': False, 'use_repo_rules': False, 'host_profiles': [], 'host_organizational_unit_dn': 'OU=Magasin,OU=Gestion des Achats et du Patrimoine,OU=Departement des Ressouces Budgetaires et Logistiques,OU=Direction Ressources Humaines Logistique et Patrimoine,OU=Direction Generale,OU=Postes,OU=notreOU,OU=nom,DC=nom,DC=fr', 'host_ad_site': None, 'waptaudit_task_period': '2h', 'hiberboot_enabled': 0, 'max_gpo_script_wait': 180.0, 'pre_shutdown_timeout': 180.0, 'uninstallkey_timeout': 120, 'check_certificates_validity': True, 'token_lifetime': 86400, 'trust_all_certs_in_pems': False, 'include_dmi_inventory': False, 'include_wmi_inventory': False, 'wapt_temp_dir': None}
2024-05-07 14:35:11,590 [wapttasks WaptTaskManager 12976] INFO Wapt tasks queue started
2024-05-07 14:35:11,608 [wapttasks SocketIOClient 16820] INFO WS read loop for 120s
2024-05-07 14:35:21,877 [wapttasks WaptTaskManager 12976] INFO Add task Mise � jour de la liste des paquets disponibles to queue
2024-05-07 14:35:21,881 [wapttasks WaptTaskManager 12976] INFO Running task Mise � jour de la liste des paquets disponibles created by SCHEDULER
t packages index from [<WaptRepo https://serveur.wapt/wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=C:\Program Files (x86)\wapt\private\00222798-6bec-ec11-8145-c83632083293.crt>, <WaptHostRepo https://serveur.wapt/wapt-host for host_id 00222798-6bec-ec11-8145-c83632083293 >]
2024-05-07 14:35:25,300 [wapttasks WaptTaskManager 12976] CRITICAL Unable to update server status: Error on server:
DataError('value too long for type character varying(255)\n')
