[RESUELTO] WaptWUA: Algunas PC permanecen en LISTO con un error de escaneo
t.heroult
Inscripción: 8 de diciembre de 2020 - 10:13 a. m.
12 de julio de 2024 - 10:48
Buen día
Desde el último parche del martes, tengo varias docenas de PC cuyos análisis fallan con el siguiente resultado:
Ensure wuauserv Auto Update option is disabled
Download all updates
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":false,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"2d",
 "install_scheduling":"2d",
 "install_delay":"20d",
 "postboot_delay":"10m",
 "user_locale":1033
Downloading wsusscn2.cab file from https://srvwapt.MonDomaine/waptwua/wsusscn2.cab
3145728 / 687267824 (0%) (2269 KB/s)
684720128 / 687267824 (100%) (3119 KB/s)
  -> download finished (3127 KB/s)
   Connecting to local update searcher using offline wsusscn2 file...
   Offline Update searcher ready...
Some windows updates have been installed/uninstalled since last scan
Looking for updates with filter: Type='Software' or Type='Driver'
Waiting for WUA search to complete
WUA Search completed !
Done searching
Updates scan done.
re-enabling wuauserv previous state: 0
(-2147319765, 'Élément introuvable.', None, None)
  File "<string>", line 1939, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 254, in _run
    self.result = wua.download_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1609, in download_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1228, in scan_updates_status
    self.store_cached_update_property(update, 'IsDownloaded', update.IsDownloaded)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 485, in __getattr__
    return self._ApplyTypes_(*args)
  File "C:\Program Files (x86)\wapt\lib\site-packages\win32com\client\__init__.py", line 478, in _ApplyTypes_
    self._oleobj_.InvokeTypes(dispid, 0, wFlags, retType, argTypes, *args),
pywintypes.com_error: (-2147319765, 'Élément introuvable.', None, None)
0x8002802b : Élément introuvable.
    self._run()
¿Alguna idea de qué está mal?
Atentamente
Tomás
Última edición realizada por t.heroult el 12 de julio de 2024 a las 13:33; editado 1 vez.
Consolas: Windows 10 y 11
Infraestructura: Windows
12 de julio de 2024 - 11:04
De hecho, hay un error por parte de Microsoft con respecto a las interfaces API del servicio Windows Update desde el último parche en Windows 11.
Otras herramientas de parcheo de "terceros" también parecen verse afectadas.
Ver por ejemplo: https://www.reddit.com/r/DattoRMM/comme...t/lcjisr0/
Para una explicación más detallada del problema: Normalmente, al buscar actualizaciones mediante el objeto COM IUpdateSearcher, el objeto ISearchResult devuelto contiene un objeto IUpdateCollection, que a su vez contiene los objetos IUpdate con la información de la actualización.
Sin embargo, en los dispositivos afectados, el objeto IUpdateCollection solo contiene objetos COM vacíos. Estos objetos no tienen propiedades ni métodos más allá de los que heredan, por lo que al intentar obtener las propiedades de la actualización, no se encuentra nada y se produce el error 0x8002802B, también conocido como TYPE_E_ELEMENTNOTFOUND.
Esperamos que Microsoft responda.
Por nuestra parte, estamos trabajando en el rediseño de nuestro módulo waptwua con una API de bajo nivel que, según nuestras pruebas, no se ve afectada por este error de Microsoft. Sin embargo, nos llevará de 2 a 3 semanas desarrollarlo e integrarlo para reemplazar el módulo Python actual.
TI tranquila
dcardón
12 de julio de 2024 - 11:47
Hola Thomas,
para complementar la respuesta de Hubert, la regresión en la última actualización de Microsoft afecta a todas las llamadas de Windows Update que dependen de la TLB (Biblioteca de Tipos), por lo tanto, a todos los lenguajes de scripting, incluido Python (que usa WAPT), pero también a las llamadas de Windows Update de PowerShell y a muchos otros lenguajes y soluciones de parcheo como Datto rmm o Altiris.
Saludos,
jacky35
Inscripciones: 17 sep 2020 - 17:51 horas.
12 de julio de 2024 - 12:09
Las cosas en Microsoft se están volviendo realmente ridículas.
La cantidad de problemas con los que nos vemos obligados a lidiar hoy en día debido a su falta de fiabilidad.
Jacky
t.heroult
12 de julio de 2024 - 13:30
Gracias Denis y Hubert por la información.
Bueno, nos las arreglaremos hasta que se publique una solución.
Saludos cordiales,
Tom.
dcardón
15 de julio de 2024 - 17:58
Hola a todos,
Microsoft ha publicado un artículo sobre este problema: https://learn.microsoft.com/en-us/windo ... pdate-apis
La solución requiere crear una directiva de grupo (GPO). Actualmente estamos trabajando en la creación del paquete WAPT correspondiente.
Saludos,
t.heroult
16 de julio de 2024 - 11:29
Gracias por los comentarios.
Estaré encantado de recibir el paquete; el procedimiento de Microsoft es problemático para crear la GPO con el filtro WMI no válido...
16 de julio de 2024 - 17:30
El paquete está disponible aquí:
https://wapt.tranquil.it/store/fr/tis-f ... date-issue
Tenga en cuenta que es necesario reiniciar el sistema. ;)
