[RESUELTO] Paquete para Postman (Windows/MacOS)
Bastien30
Inscripción: 8 de marzo de 2024 - 15:21
30 de octubre de 2024 - 10:56
Si es de alguna utilidad, aquí está el código del paquete que uso para el software Postman:
Para Windows:
import time
setup_path = r'C:\ProgramData\postman-installer'
bin_name = r'Postman-win64-Setup.exe'
    mkdirs(setup_path)
    filecopyto(bin_name, makepath(setup_path, bin_name))
    for user_path in local_users_profiles():
        # Uninstall silently
        if isfile(makepath(user_path, r'\AppData\Local\Postman', r'Update.exe')):
            run_notfatal(r'"%s" --uninstall -s' % makepath(user_path, r'\AppData\Local\Postman', r'Update.exe'))
            time.sleep(2)
        # Remove local appdata dir
        if isdir(makepath(user_path, r'\AppData\Local\Postman')):
            remove_tree(makepath(user_path, r'\AppData\Local\Postman'))
    remove_tree(setup_path)
def session_setup():
    run(r'"%s" -s' % makepath(setup_path, bin_name))
    time.sleep(5)
    for i in range(30):
        if not isfile(makepath(user_local_appdata, r'\Postman\Update.exe')):
            time.sleep(5)
            break
def update_package():
    url = r'https://dl.pstmn.io/download/latest/win64'
    wget(url, bin_name)
    version_from_file = get_version_from_binary(bin_name)
    version_from_package = control.version.split('-')[0]
    if Version(version_from_file) > Version(version_from_package):
        print(r'Latest Postman version is %s' % version_from_file)
        control.version = '%s-%s' % (version_from_file, control.version.split('-', 1)[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        print(r'Already up to date !')
Para macOS:
zip_name = r'Postman-MacOS-arm64.zip'
app_name = r'Postman.app'
    run(r'unzip -qq %s %s/*' % (zip_name, app_name))
    install_app(app_name)
    uninstall_app(app_name)
    import plistlib
    if isdir(app_name):
        remove_tree(app_name)
    url = r'https://dl.pstmn.io/download/latest/osx_arm64'
    wget(url, zip_name)
    unzip(zip_name, target=r'', filenames=r'%s/*' % app_name)
    plist_file = plistlib.readPlist(r'%s/Contents/Info.plist' % app_name)
    version_from_plist = plist_file[r'CFBundleShortVersionString']
    if Version(version_from_plist) > Version(version_from_package):
        print(r'Latest Postman version is %s' % version_from_plist)
        control.version = '%s-%s' % (version_from_plist, control.version.split('-', 1)[-1])
dcardón
6 de noviembre de 2024 - 12:00
Hola Bastien,
gracias por compartirlo. Parece un programa bastante bueno; creo que también lo usaremos internamente. :-)
Saludos,
fschelfaut
Inscripción: 7 de noviembre de 2024 - 12:22
8 de noviembre de 2024 - 15:26
Hola Bastien,
hemos empaquetado Postman para Windows y macOS. Actualmente está disponible en el repositorio PREPROD y estará disponible en la tienda en 5 días.
Aquí tienes los enlaces a las versiones PREPROD:
- Windows x64
- macOS Intel
- macOS ARM
Saludos cordiales,
Flavien
Bastien30
8 de noviembre de 2024 - 16:43
genial. Esperaré a que esté en el repositorio estable para revisarlo y probablemente reemplazaré mis paquetes con los tuyos :D
. Gracias.
Bastien30
17 de diciembre de 2024 - 12:27
fschelfaut escribió: 8 de noviembre de 2024 - 15:26 Hola Bastien,
Hemos empaquetado Postman para Windows y macOS. Actualmente está disponible en el repositorio PREPROD y estará disponible en la tienda en 5 días.
Aquí están los enlaces a las compilaciones PREPROD:
- Windows x64
- macOS Intel
- macOS arm
Saludos cordiales,
Flavien
Descargué sus paquetes en lugar de los míos porque son más limpios (instalación en archivos de programa).
Sin embargo, he notado un pequeño problema después de una actualización de paquete: en Windows, el programa se inicia y luego se cierra unos segundos después.
Después de la investigación, se encontró que el problema se debía al archivo AppData\Roaming\Postman\storage\settings.json, en el que hay un parámetro "lastKnownVersion" que tiene el valor de la versión previamente instalada.
Si actualizamos el valor con la nueva versión el programa inicia normalmente.
¿Sería posible agregar esta modificación al paquete, por favor?
Por tanto, creo que sería necesario hacer esto para todos los usuarios.
Gracias de antemano.
fschelfaut
20 de diciembre de 2024 - 10:05 AM
Hola Bastien, ¡
Gracias por tus comentarios! Efectivamente, no había considerado ese archivo.
Por lo tanto, he adaptado el código para que settings.json se actualice automáticamente (session-setup).
Puedes encontrar el paquete en PREPROD aquí.
Por favor, avísame si esto resuelve tu problema.
Flavien,
Bastien30
20 de diciembre de 2024 - 17:11
¡Muchas gracias! :)
Bastien30
26 de diciembre de 2024 - 17:11
acabo de actualizar Postman, todo funciona bien :D
. ¡Gracias!
