[RESUELTO] Error de auditoría WAPT tras la actualización a -38
Pablo SLA
Inscripción: 10 oct. 2023 - 11:23
29 de noviembre de 2024 - 09:31
Tras actualizar el paquete de auditoría de BitLocker, recibo un error sin haber modificado el código (inicialmente lo modifiqué para añadir nuestro certificado y luego lo intenté de nuevo sin realizar ningún cambio). En ambos casos, recibo este error:
 https://srv-wapt.XXXX.dom/wapt/XXXX-audit-bitlocker_10.6.0-41_windows_10.0_PREPROD_f0fbc8a41032a3c9a76b1ee74e56ccfb.wapt : 9384 / 9384 (100%) (594 KB/s)
Erreur lors de l'installation de ['XXXX-audit-bitlocker(=10.6.0-41)']: erreurs dans les paquets [[PackageRequest(package='XXXX-audit-bitlocker',version=(Version('10.6.0.0'), 41),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('XXXX-audit-bitlocker','10.6.0-41' maturity='PREPROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4142, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1589, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\wapt_8oj1pba\\setup.py", line 153\n    certs_path.extend(x for x in get_code_signing_cert() if x not in certs_path)\n    ^\nIndentationError: expected an indented block\n']]
    self._run()
Exception: Erreur lors de l'installation de ['XXXX-audit-bitlocker(=10.6.0-41)']: erreurs dans les paquets [[PackageRequest(package='XXXX-audit-bitlocker',version=(Version('10.6.0.0'), 41),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.26100'),max_os_version=Version('10.0.26100')), PackageEntry('XXXX-audit-bitlocker','10.6.0-41' maturity='PREPROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4142, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1589, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\wapt_8oj1pba\\setup.py", line 153\n    certs_path.extend(x for x in get_code_signing_cert() if x not in certs_path)\n    ^\nIndentationError: expected an indented block\n']]
    self._run()
¿Es esto normal o está relacionado con un nuevo parámetro a configurar como su certificado o no?
Atentamente,
jlepiquet
Inscripciones: 3 sep 2024 - 16:09 horas.
29 de noviembre de 2024 - 10:01
esto se debe a un cambio realizado anoche que tenía una indentación incorrecta.
Acabamos de revertir la confirmación de ayer y hemos vuelto a subir el paquete a la versión -39.
Debería estar disponible esta mañana.
Disculpen las molestias.
Joffrey
jlepiquet
29 de noviembre de 2024 - 12:30
el paquete está disponible en la tienda https://wapt.tranquil.it/store/fr/wapt/ ... _PROD.wapt
Saludos,
