¡Acabo de instalar la última versión de WAPT y ya nada funciona!
Ya no puedo conectarme a través del navegador web ni a través de la consola.
La información de inicio de sesión está siendo rechazada aunque es correcta...
Registro del servidor:
Jan 10 12:33:27 SRVWAPT-SRV waptserver[1682740]: 2025-01-10 12:33:27,779 [waptauth ] WARNING Failed auth for None from MON_IP path /
Jan 10 12:33:29 SRVWAPT-SRV waptserver[1682740]: 2025-01-10 12:33:29,146 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:34:05 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:34:05,588 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:34:07 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:34:07,284 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:35:56 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:35:56,728 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /api/v3/login
Jan 10 12:40:09 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:40:09,073 [waptauth ] WARNING Failed auth for MON_LOGIN from MON_IP path /api/v3/login
