Estoy intentando leer un archivo de texto para recuperar información usando este código
chemin_txt=makepath("C:","Temp","Sup_fichiers.txt")
lignes = []
try :
file = open(chemin_txt,"r",encoding="utf8")
print(file.readlines())
lignes=file.readlines()
finally :
file.close()Código: Seleccionar todo
2025-01-16 11:10:22,825 CRITICAL Error importing C:\waptdev\test_0_PROD-wapt\setup.py :
File "C:\Program Files (x86)\wapt\waptutils.py", line 1608, in import_setup
File "imp.py", line 171, in load_source
File "<frozen importlib._bootstrap>", line 711, in _load
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 846, in exec_module
File "<frozen importlib._bootstrap_external>", line 983, in get_code
File "<frozen importlib._bootstrap_external>", line 913, in source_to_code
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "C:\waptdev\test_0_PROD-wapt\setup.py", line 35
IndentationError: expected an indented block
FATAL ERROR : IndentationError: expected an indented block (setup.py, line 35)
Exit code: 3Atentamente,
Brice
- Se instaló la versión 2.6.0 de WAPT
- Sistema operativo de servidor Linux y versión Debian
- Sistema operativo de la máquina de administración/creación de paquetes de Windows 11
