Versión del servidor WAPT: 2.6.0.16552
Versión del agente WAPT: 2.6.0
Versión de la consola WAPT: 2.6.0.16767
Versión de mi PC de administrador: Ubuntu 24.04
He notado durante los últimos días que las acciones son imposibles en mi sistema Ubuntu debido al paso Actualizar el servidor con el estado de este host erróneo con los siguientes elementos:
'utf-8' codec can't decode byte 0x9f in position 1680: invalid start byte
File "<string>", line 1684, in run
File "/opt/wapt/waptservice/waptservice_common.py", line 870, in run
self._run()
File "/opt/wapt/waptservice/waptservice_common.py", line 1221, in _run
self.result = self.wapt.update_server_status(force=self.force, excluded_keys=self.excluded_keys, errors = errors)
File "/opt/wapt/common.py", line 6803, in update_server_status
if not self.waptserver_available():
File "/opt/wapt/common.py", line 6909, in waptserver_available
return self.waptserver and self.waptserver.available()
File "/opt/wapt/common.py", line 2076, in available
with self.get_requests_session() as session:
File "/opt/wapt/common.py", line 1738, in get_requests_session
if self.client_private_key and is_pem_key_encrypted(self.client_private_key):
File "/opt/wapt/waptutils.py", line 837, in is_pem_key_encrypted
pem_content = f.read()
File "/opt/wapt/lib/python3.9/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x9f in position 1680: invalid start byte
utf-8' codec can't decode byte 0x9f in position 1680: invalid start byte : faulty string is 'b'-----BEGIN RSA PRIVATE KEY----........Gracias de antemano, un cordial saludo.
