[RESUELTO] Paquete para ChatGPT (MacOS)
Respuesta
Bastien30
Inscripción: 8 de marzo de 2024 - 15:21
4 de septiembre de 2025 - 12:00
Hice un paquete para el cliente de escritorio ChatGPT para MacOS, con update_package() funcionando.
Nota: según su sitio web, el DMG solo es compatible con procesadores ARM.
Para Windows, la aplicación está disponible en la tienda, por lo que solo necesitas usar el paquete de plantillas dedicado: https://wapt.tranquil.it/store/fr/tis-t ... -tienda-aplicación
configuración.py:
from setupdevhelpers import *
import plistlib
    # Initializing variables
    package_version = control.version.split("-")[0]
    app_name = control.name
    # Installing the package
    bin_name= glob.glob('%s*.dmg' % app_name)[0]
    install_dmg(bin_name, key="/Applications/%s.app" % app_name, min_version=package_version)
def update_package():
    bin_name = r'%s.dmg' % app_name
    dl_url = r'%s/%s' % (control.sources, bin_name)
    plist_file_name = r'Info.plist'
    # Downloading and extracting to compare version
    if isfile(bin_name):
        remove_file(bin_name)
    wget(dl_url, bin_name)
    if isfile(plist_file_name):
        remove_file(plist_file_name)
    unzip_with_7zip(bin_name, target=basedir, filenames=["%s Installer/%s.app/Contents/Info.plist" % (app_name, app_name)], extract_with_full_paths=False, recursive=False)
    plist_file = get_plist_obj(plist_file_name)
    latest_version = plist_file[r'CFBundleShortVersionString']
    print(r'Latest %s version is %s' % (app_name, latest_version))
    if Version(latest_version) > Version(control.get_software_version()):
        control.version = '%s-%s' % (latest_version, control.version.split('-', 1)[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        print(r'Already up to date !')
def get_plist_obj(plist_file):
    """ Returns a plist obj when given the path to a plist file. """
    with open(plist_file, 'rb') as fp :
        plist_obj = plistlib.load(fp)
    return plist_obj
control:
package           : xxx-chatgpt
version           : 1.2025.231-2
architecture      : arm
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : ChatGPT Officiel Desktop Client
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : darwin
min_wapt_version  : 2.0
sources           : https://persistent.oaistatic.com/sidekick/public/
installed_size    :
impacted_process  : chatgpt
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : OpenAI
keywords          :
licence           : proprietary_free,wapt_public
homepage          : https://chatgpt.com
package_uuid      :
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://help.openai.com/en/articles/9703738-chatgpt-macos-app-release-notes
min_os_version    :
max_os_version    :
Respuesta
