[RESUELTO] Problema con la aplicación de Microsoft Store y la plantilla para compartir rápidamente
Vincent38
Inscripción: 22 de mayo de 2023 - 12:13
26 de septiembre de 2025 - 12:39
Buen día
Tengo un problema con el paquete "plantilla de aplicación de Microsoft Store", que parece no funcionar para generar el paquete con la aplicación de uso compartido rápido.
Funciona con otro software, pero con QuickShare esto es lo que obtengo:
Retrieving informations from Microsoft Store API, please wait
Downloading: SAMSUNGELECTRONICSCoLtd.SamsungQuickShare_2.2.19.0_neutral___wyx1vj98g3asy_17cba7b8-16ac-49e2-aa9e-429b732b4bdd.msixbundle
CRITICAL:waptcore:Fatal error in update_package  None : None:
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 534, in _make_request
    response = conn.getresponse()
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 565, in getresponse
    httplib_response = super().getresponse()
  File "http\client.py", line 1375, in getresponse
  File "http\client.py", line 318, in begin
  File "http\client.py", line 279, in _read_status
  File "socket.py", line 717, in readinto
TimeoutError: timed out
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 644, in send
    resp = conn.urlopen(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 841, in urlopen
    retries = retries.increment(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 474, in increment
    raise reraise(type(error), error, _stacktrace)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\util.py", line 39, in reraise
    raise value
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 787, in urlopen
    response = self._make_request(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 536, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 367, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='tlu.dl.delivery.mp.microsoft.com', port=80): Read timed out. (read timeout=10)
  File "C:\Program Files (x86)\wapt\common.py", line 9036, in call_python_code
    hookdata = hook_func()
  File "C:\Users\vmorey\AppData\Local\Temp\wapt\MKDEGI_9\domoprod-template-microsoft-store-app_0-77_windows_10.0_PROD-wapt\update_package.py", line 109, in update_package
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1139, in wget
    httpreq = session.get(url,
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 602, in get
    return self.request("GET", url, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 690, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='tlu.dl.delivery.mp.microsoft.com', port=80): Read timed out. (read timeout=10)
    raise value
  File "C:\Program Files (x86)\wapt\common.py", line 9040, in call_python_code
    raise e
¿Alguna idea de lo que está pasando?
GRACIAS
Comandante
WAPT 2.6.1.17472
Servidor Debian 12
Máquina de creación de Win 11 24h2 (26100.4349)
jlepiquet
Inscripciones: 3 sep 2024 - 16:09 horas.
29 de septiembre de 2025 - 09:35
Hola Vincent,
parece que hay un problema de tiempo de espera con los enlaces de descarga.
Lo probé por nuestra parte y funciona, así que puede que haya un bloqueo de URL en tu sistema o un problema de sincronización durante la descarga.
Por favor, inténtalo de nuevo y avísanos.
Saludos cordiales,
Joffrey
Vincent38
30 de septiembre de 2025 - 13:45
Hola
, sí, parece que hay algo que lo está bloqueando por nuestra parte. La descarga desde Microsoft es extraña; estoy trabajando en ello con WatchGuard.
Saludos.
dcardón
30 de septiembre de 2025 - 16:18
Hola Vincent,
gracias por tus comentarios :-) , marco el tema como resuelto.
