Error de jQuery de PostgreSQL en los registros de PostgreSQL
Respuesta
Mikael S
Inscripción: 20 de enero de 2025 - 15:54
3 de octubre de 2025 - 8:11 AM
En los registros de la base de datos, encontré esto
2025-10-02 23:59:27.817 CEST [1202] LOG:  starting PostgreSQL 15.14 (Debian 15.14-0+deb12u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv6 address "::1", port 5432
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv4 address "127.0.0.1", port 5432
2025-10-02 23:59:27.824 CEST [1202] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-10-02 23:59:27.856 CEST [1224] LOG:  database system was shut down at 2025-10-02 23:59:02 CEST
2025-10-02 23:59:27.888 CEST [1202] LOG:  database system is ready to accept connections
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt ERROR:  extension "jsquery" is not available
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt DETAIL:  Could not open extension control file "/usr/share/postgresql/15/extension/jsquery.control": No such file or directory.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt HINT:  The extension must first be installed on the system where PostgreSQL is running.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt STATEMENT:  CREATE EXTENSION if not exists jsquery;
2025-10-02 23:59:30.867 CEST [1794] wapt@wapt WARNING:  there is no transaction in progress
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt LOG:  could not send data to client: Broken pipe
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt STATEMENT:  COPY public.hostauditdata (id, host_id, value_id, value_date, value_section, value_key, value, expiration_date, created_on, created_by) TO stdout;
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt ERROR:  canceling statement due to user request
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt FATAL:  connection to client lost
No mencionas la necesidad de instalar el paquete postgresql-15-jsquery en Bookworm en la wiki. O quizás esté en otra página https://www.wapt.fr/es/doc/wapt-server-...er-install
Atentamente,
dcardón
3 de octubre de 2025 - 11:04
Hola Mickael,
la extensión jQuery ya no es necesaria para WAPT. En una instalación nueva, el script postconf solo la instala si está disponible en el sistema. Sin embargo, es cierto que puede causar problemas al restaurar una copia de seguridad o al reinstalar el servidor. Esta extensión se puede usar en consultas SQL/JSON.
Consultaré con el equipo para ver si podemos volver a incluirla en la documentación durante la instalación o si podemos encontrar una mejor manera de solucionar esto durante una actualización.
Saludos,
Respuesta
