Solicitud de paquete de software Icy
Respuesta
Aramis
Inscripción: 16 de julio de 2024 - 11:48
15 de octubre de 2025 - 15:40
la comunidad científica utiliza ampliamente el software Icy.
https://icy.bioimageanalysis.org/
Sería beneficioso que este software estuviera disponible para Windows, Linux y Mac.
Atentamente,
blemoigne
16 de octubre de 2025 - 12:34
Hola de nuevo,
Este software presenta el mismo problema operativo: no cumple con las mejores prácticas de seguridad en un entorno profesional. Enviamos este mensaje al editor del software en su foro:
Subject: Installation path recommendation – conflict with security best practices
Dear Support Team,
I hope this message finds you well.
While reviewing your installation documentation, I noticed that you recommend not installing your software in the “Program Files” directory due to potential permission issues.
However, according to security best practices and government cybersecurity agencies — such as ANSSI (the French National Cybersecurity Agency) and similar organizations like NIST (U.S. National Institute of Standards and Technology) and ENISA (European Union Agency for Cybersecurity) — it is strongly recommended that applications be installed in system-protected directories such as Program Files.
In professional environments, execution of binaries is restricted to trusted paths (e.g. C:\Program Files and C:\Program Files (x86)) to prevent the execution of untrusted or potentially malicious code.
This policy is commonly enforced through application whitelisting and endpoint security controls, which are standard practice in enterprise and government environments.
Would it be possible for you to review your installation process or adjust your software so that it can safely run from within Program Files while maintaining proper permission handling ?
This change would greatly facilitate deployment in secured and compliant environments.
Thank you for your attention, and please let me know if you would like more details about these compliance requirements.
Kind regards,
Veremos si todavía podemos conseguir que funcione en los archivos de programa.
Atentamente,
Bertrand
Aramis
21 de octubre de 2025 - 13:35
gracias. Sin duda, este es un mal hábito que se ha desarrollado en esta comunidad. ;)
Atentamente,
Julien
vcardón
21 de octubre de 2025 - 19:17
Hola Julien,
cuando dices "esta comunidad", ¿te refieres a la comunidad de editores de software científico?
Si es así, ¿conoces https://www.eprist.fr/qui-sommes-nous/ ? ¿Podrías ponernos en contacto con alguien de esta asociación para que podamos explicar esta situación, que parece estar extendiéndose?
Tranquilo IT
Aramis
27 de octubre de 2025 - 14:22
vcardon escribió: 21 de oct. de 2025 - 19:17 Hola Julien,
Sí, me refiero a la comunidad de editores de software científico. Empaquetar este tipo de software siempre es un proceso laborioso.
Lamentablemente no tengo ningún contacto con esta asociación, con la que no estaba familiarizado.
Atentamente,
Respuesta
