[RESUELTO] WADS: el agente wapt no se registra
rlegrand
Inscripción: 30 de junio de 2026 - 15:37
30 de junio de 2026 - 16:11
Estoy teniendo un problema al implementar Windows 11 con WADS; el sistema operativo se implementa correctamente, pero el agente WAPT en la máquina ya no se registra con el servidor y el script posterior a la instalación tampoco se ejecuta
Probé la implementación en dos máquinas diferentes y sigo teniendo el mismo problema.
A continuación se muestra el registro del cliente Wapt:
2026-06-30 10:29:39,180 [waptcore WaptTaskManager 7500] CRITICAL Error merging Packages from wapt into db: 400 Client Error: Bad Request for url: https://srv-wapt.xxx.fr/wapt/Packages
Disabling Windows auto update service, using WaptWUA instead
2026-06-30 10:29:43,061 [waptcore WaptTaskManager 7500] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://srv-xxx.fr/update_host
2026-06-30 10:29:43,061 [waptcore WaptTaskManager 7500] CRITICAL Unable to update_server_status: None
2026-06-30 10:29:43,061 [wapttasks WaptTaskManager 7500] WARNING Update status failed, trying to register the computer...
2026-06-30 10:29:45,877 [waptcore WaptTaskManager 7500] CRITICAL Unable to register: Error sending registration data: status 403 content <html>
<head><title>403 Forbidden</title></head>
<body>
<center><h1>403 Forbidden</h1></center>
<hr><center>nginx</center>
</body>
</html>
2026-06-30 10:29:45,877 [wapttasks WaptTaskManager 7500] CRITICAL Unable to update server status: Error sending registration data: status 403 content <html>
<body>
</body>
</html>
2026-06-30 10:29:57,387 [wapttasks SocketIOClient 3520] INFO Socketio connection params have changed. Socketio needs reconnect
2026-06-30 10:29:57,394 [wapttasks SocketIOClient 3520] INFO Creating socketio client: https://srv-xxx.fr:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.crt', 'C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.pem') proxies: None verify_cert: False
2026-06-30 10:29:57,394 [wapttasks SocketIOClient 3520] INFO Connecting Socketio to https://srv-xxx.fr:443
2026-06-30 10:29:57,467 [waptws SocketIOClient 3520] WARNING Exception ConnectionError('Connection error'), waiting 33.76406250000001s before retrying
2026-06-30 10:30:31,250 [wapttasks SocketIOClient 3520] INFO Socketio connection params have changed. Socketio needs reconnect
2026-06-30 10:30:31,250 [wapttasks SocketIOClient 3520] INFO Creating socketio client: https://srv-xxx:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.crt', 'C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.pem') proxies: None verify_cert: False
Gracias de antemano por su ayuda
1 de julio de 2026 - 17:32
Hola
, ¿podría especificar su método de registro en el servidor WAPT?
¿Kerberos?
rlegrand
2 de julio de 2026 - 10:37
sí, el registro Kerberos está habilitado.
El servidor Linux es la versión 2.6.1.17834.
Al ejecutar `wapt-get register` en el cliente, me pide credenciales. No sé por qué; creo que esto no sucedía antes.
Funcionaba bien anteriormente, pero sospecho que el registro Kerberos ya no funciona.
dcardón
2 de julio de 2026 - 12:30
Hola rlegrand,
cuando preparas la máquina, ¿seleccionas la plantilla con integración de AD y generas el archivo DJoin correctamente? Si es así, ¿tienes varios Active Directory? ¿Y cuál es el tiempo de propagación de los cambios de AD? Es posible que hayas creado el archivo DJoin en un AD, pero la estación de trabajo se esté conectando a uno diferente.
Saludos,
rlegrand
2 de julio de 2026 - 13:59
dcardon escribió: 2 de julio de 2026 - 12:30 p. m. Hola rlegrand,
cuando preparas la máquina, ¿eliges la plantilla con integración de AD y generas el archivo DJoin correctamente? Si es así, ¿tienes varios Active Directory? ¿Y cuál es el tiempo de propagación de los cambios de AD? Es posible que hayas creado el archivo DJoin en un AD, pero la estación de trabajo se conecta a un AD diferente.
Saludos,
Sí, estoy usando una plantilla con integración de dominio.
La unión al dominio funciona correctamente, el agente WAPT se instala correctamente, pero el registro del cliente Wapt en el servidor ya no funciona (la estación de trabajo no aparece en la consola) y, por lo tanto, la ejecución de los comandos del script posterior a la instalación no puede funcionar (comandos "Wapt-get").
2 de julio de 2026 - 14:53
¿Podrías decirme qué devuelve esto en el servidor WAPT?
https://www.wapt.fr/fr/doc/wapt-securit ... -with-curl
¿Podrías también decirme qué tipo de servidor tienes? ¿Red Hat? ¿Alma? ¿Debian?
rlegrand
2 de julio de 2026 - 15:53
sfonteneau escribió: 2 de julio de 2026 - 14:53 ¿Puedes indicar qué devuelve esto en el servidor de Wapt?
root@SRV-WAPT:/home/wapt# kdestroy
root@SRV-WAPT:/home/wapt# kinit <user>
Password for <user>@<domaine>:
root@SRV-WAPT:/home/wapt# klist
Ticket cache: FILE:/tmp/krb5cc_0
Default principal: <user>@<domaine>
Valid starting       Expires              Service principal
07/02/2026 15:35:34  07/03/2026 01:35:34  krbtgt/<domaine>@<domaine>
        renew until 07/03/2026 15:35:28
root@SRV-WAPT:/home/wapt# curl -v --negotiate -u : https://srv-wapt.<domaine>/api/v3/add_host_kerberos -k
* Host srv-wapt.<domaine>:443 was resolved.
* IPv6: (none)
* IPv4: 192.168.1.11
*   Trying 192.168.1.11:443...
* connect to 192.168.1.11 port 443 from 192.168.1.10 port 34656 failed: No route to host
* Failed to connect to srv-wapt.<domaine> port 443 after 3078 ms: Could not connect to server
* closing connection #0
curl: (7) Failed to connect to srv-wapt.<domaine> port 443 after 3078 ms: Could not connect to server
2 de julio de 2026 - 15:59
¿Cuál es la dirección IP del servidor?
rlegrand
2 de julio de 2026 - 16:34
sfonteneau escribió: 2 de julio de 2026 - 15:59
192.168.1.10
2 de julio de 2026 - 16:44
¿No aparece 192.168.1.11 en /etc/hosts? (Configuración incorrecta)
Kinit está intentando conectarse a 192.168.1.11...
