Tengo un problema con uno de mis paquetes que me permite instalar Unity.
Desde que actualicé a la versión 1.5.21, he estado recibiendo errores IndexError: tuple index out of range en mi script.
Si alguien tiene alguna idea de cómo desentrañar este script.
Debo señalar que el servidor está instalado en Debian Jessie.
import shutil
import os
print('Suppression des anciennes versions ou de la 2017')
if os.path.isfile('C:\Program Files\Unity\Editor\Uninstall.exe'):
run(r'"C:\Program Files\Unity\Editor\Uninstall.exe" /S')
remove_tree(r'C:\Program Files\Unity')
if os.path.isfile('C:\Program Files\Unity2017\Editor\Uninstall.exe'):
run(r'"C:\Program Files\Unity2017\Editor\Uninstall.exe" /S')
remove_tree(r'C:\Program Files\Unity2017')
print('installation de unity')
run(r'"UnitySetup64.exe" -UI=reduced /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant IOS')
run(r'"UnitySetup-ios.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant Android')
run(r'"Unity-android.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant WebGL')
run(r'"Unity-webgl.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant TVOS')
run(r'"UnitySetup-tvos.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant Vuforia')
run(r'"UnitySetup-vuforia.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant UWP')
run(r'"UnitySetup-uwp.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation du composant Standard Assets')
run(r'"UnityStandardAssetsSetup.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('installation de la documentation')
run(r'"UnityDocumentationSetup.exe"/S /D=C:\Program Files\Unity2017',timeout=900)
print('configuration du firewall')
run(r'"script.bat"')
print('suppression de unity')
