[RESUELTO] Problema actualización 1.5.1.23 a 1.6
cdeze
Inscripción: 29 de noviembre de 2016 - 09:39
26 de septiembre de 2018 - 14:19
Me sale este mensaje de error
¿Podrías decirme si esto te resuena?
GRACIAS
root@wapt:~# apt-get update
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stable InRelease
Ign:3 http://cdn-fastly.deb.debian.org/debian stable-update InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stable Release
Ign:5 https://wapt.tranquil.it/debian/wapt-1.6 stretch InRelease
Ign:6 http://cdn-fastly.deb.debian.org/debian stable-update Release
Ign:7 http://deb.debian.org/debian stable-update/main all Packages
Ign:7 http://cdn-fastly.deb.debian.org/debian stable-update/main all Packages
Ign:9 http://deb.debian.org/debian stable-update/main amd64 Packages
Ign:9 http://cdn-fastly.deb.debian.org/debian stable-update/main amd64 Packages
Ign:10 http://deb.debian.org/debian stable-update/main Translation-en
Ign:10 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en
Ign:11 http://deb.debian.org/debian stable-update/main Translation-fr
Ign:11 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-fr
Ign:12 https://wapt.tranquil.it/debian/wapt-1.6 stretch Release
Ign:13 http://deb.debian.org/debian stable-update/main Translation-en_US
Ign:13 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en_US
Ign:14 http://deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:14 http://cdn-fastly.deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:15 http://deb.debian.org/debian stable-update/contrib all Packages
Ign:15 http://cdn-fastly.deb.debian.org/debian stable-update/contrib all Packages
Ign:16 http://deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:16 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:17 http://deb.debian.org/debian stable-update/contrib Translation-en
Ign:17 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en
Ign:18 http://deb.debian.org/debian stable-update/contrib Translation-fr
Ign:18 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-fr
Ign:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
Ign:20 http://deb.debian.org/debian stable-update/non-free all Packages
Ign:20 http://cdn-fastly.deb.debian.org/debian stable-update/non-free all Packages
Ign:21 http://deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:21 http://cdn-fastly.deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:22 http://deb.debian.org/debian stable-update/non-free Translation-fr
Ign:22 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-fr
Ign:23 http://deb.debian.org/debian stable-update/non-free Translation-en
Ign:23 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en
Ign:24 http://deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:24 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:25 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main all Packages
Ign:26 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en
Ign:27 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en_US
Ign:28 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-fr
Err:9 http://deb.debian.org/debian stable-update/main amd64 Packages
  404  Not Found
Err:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
  gnutls_handshake() failed: Error in the pull function.
Reading package lists... Done
W: The repository 'http://deb.debian.org/debian stable-update Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'https://wapt.tranquil.it/debian/wapt-1.6 stretch Release' does not have a Release file.
E: Failed to fetch http://deb.debian.org/debian/dists/stable-update/main/binary-amd64/Packages  404  Not Found
E: Failed to fetch https://wapt.tranquil.it/debian/wapt-1.6/dists/stretch/main/binary-amd64/Packages  gnutls_handshake() failed: Error in the pull function.
E: Some index files failed to download. They have been ignored, or old ones used instead.
dcardón
26 de septiembre de 2018 - 15:13
Hola cdeze,
cdeze escribió: 26 de septiembre de 2018 - 14:19 Me sale este mensaje de error
GRACIAS
Creo que tienes un problema con la descarga de APT... ¿Podrías revisar tu proxy? ¿Existe algún ataque de intermediario (MITM) que use un certificado comodín en tu proxy?
Atentamente,
cdeze
26 de septiembre de 2018 - 16:03
Buen día
No es un MITM, sino un proxy que no debe conocer un cifrado ni una versión de SSL
Para su información
root@wapt:~# curl -vv https://wapt.tranquil.it/
*   Trying 100.78.56.201...
* TCP_NODELAY set
* Connected to (nil) (100.78.56.201) port 8001 (#0)
* Establish HTTP proxy tunnel to wapt.tranquil.it:443
> CONNECT wapt.tranquil.it:443 HTTP/1.1
> Host: wapt.tranquil.it:443
> User-Agent: curl/7.52.1
> Proxy-Connection: Keep-Alive
< HTTP/1.1 200 Connection established
* Proxy replied OK to CONNECT request
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* Unknown SSL protocol error in connection to wapt.tranquil.it:443
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to wapt.tranquil.it:443
cdeze
26 de septiembre de 2018 - 16:12
Creo que mi proxy solo permite TLS 1.3 y tu servidor no tiene ese protocolo
. ¿Me equivoco?
dcardón
26 de septiembre de 2018 - 16:16
Hola Cdeze,
cdeze escribió: 26 de septiembre de 2018 - 16:12 Creo que mi proxy solo permite TLS 1.3 y tu servidor no tiene este protocolo
. ¿Me equivoco?
Creo que tu proxy no soporta TLS 1.2... Si tu proxy solo acepta TLS 1.3, ¡no podrá conectarse demasiado! :-)
cdeze
26 de septiembre de 2018 - 16:22
Sin embargo, lo hace:
root@wapt:~# curl -vv https://forum.tranquil.it/
* TCP_NODELAY set
* Establish HTTP proxy tunnel to forum.tranquil.it:443
> CONNECT forum.tranquil.it:443 HTTP/1.1
> Host: forum.tranquil.it:443
* ALPN, offering h2
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
*  subject: OU=Domain Control Validated; OU=Gandi Standard Wildcard SSL; CN=*.tranquil.it
*  start date: May 25 00:00:00 2018 GMT
*  expire date: Jun  8 23:59:59 2020 GMT
*  subjectAltName: host "forum.tranquil.it" matched cert's "*.tranquil.it"
*  issuer: C=FR; ST=Paris; L=Paris; O=Gandi; CN=Gandi Standard SSL CA 2
*  SSL certificate verify ok.
dcardón
26 de septiembre de 2018 - 17:21
Hola cdeze,
cdeze escribió: 26 de septiembre de 2018 - 16:22 Sin embargo, lo hace:
También estamos usando un proxy; tengo el mismo TLS y cifrado en ambos casos... Admito que no entiendo...
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://wapt.tranquil.it/
* Probando 192.168.149.13...
* Conexión SSL mediante TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://forum.tranquil.it/
Simon me dijo que, en el peor de los casos, siempre puedes descargar los archivos .deb usando tu navegador e instalarlos con dpkg... :-)
cdeze
27 de septiembre de 2018 - 08:46
El problema se originó en nuestro sistema de filtrado de Bluecoat, que había marcado el sitio como sospechoso.
Lo sentimos
dcardón
2 de octubre de 2018 - 20:04
Hola Cdeze,
cdeze escribió: 27 de septiembre de 2018 - 8:46 a. m. El problema provino de nuestro filtro en Bluecoat, que había marcado el sitio como sospechoso.
Lo sentimos.
Gracias por tus comentarios, marco el tema como [RESUELTO]
Atentamente,
