wapt-get register -ldebug
2020-02-12 14:58:47,450 DEBUG Default encoding : ascii
2020-02-12 14:58:47,455 DEBUG Setting encoding for stdout and stderr to UTF-8
2020-02-12 14:58:47,455 DEBUG Python path ['/opt/wapt', '/opt/wapt', '/opt/wapt/lib/python2.7', '/opt/wapt/lib/python2.7/plat-x86_64-linux-gnu', '/opt/wapt/lib/python2.7/lib-tk', '/opt/wapt/lib/python2.7/lib-old', '/opt/wapt/lib/python2.7/lib-dynload', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk', '/opt/wapt/lib/python2.7/site-packages']
2020-02-12 14:58:47,455 INFO Using local waptservice configuration /opt/wapt/wapt-get.ini
2020-02-12 14:58:47,456 DEBUG Config file: /opt/wapt/wapt-get.ini
Using config file: /opt/wapt/wapt-get.ini
2020-02-12 14:58:47,468 DEBUG Thread 140067123935040 is connecting to wapt db
2020-02-12 14:58:47,741 DEBUG Using host certificate /opt/wapt/private/f7097310-8436-bf45-ae76-394dd2f63dcf.pem for repo global auth
2020-02-12 14:58:47,848 DEBUG Thread 140067123935040 is connecting to wapt db
2020-02-12 14:58:47,849 DEBUG DB Start transaction
2020-02-12 14:58:47,850 DEBUG DB commit
2020-02-12 14:58:47,966 DEBUG Using host certificate /opt/wapt/private/f7097310-8436-bf45-ae76-394dd2f63dcf.pem for repo wapt auth
2020-02-12 14:58:48,180 DEBUG Using host certificate /opt/wapt/private/f7097310-8436-bf45-ae76-394dd2f63dcf.pem for repo wapt-host auth
2020-02-12 14:58:48,233 INFO User Groups:[]
2020-02-12 14:58:48,234 DEBUG WAPT base directory : /opt/wapt
2020-02-12 14:58:48,234 DEBUG Package cache dir : /opt/wapt/cache
2020-02-12 14:58:48,234 DEBUG WAPT DB Structure version;: 20190606
Registering host against server: https://XXX.XXX.dc/
2020-02-12 14:58:48,234 DEBUG DB Start transaction
2020-02-12 14:58:48,235 DEBUG DB commit
2020-02-12 14:58:48,265 DEBUG DB Start transaction
2020-02-12 14:58:48,266 DEBUG DB commit
2020-02-12 14:58:48,270 DEBUG DB Start transaction
2020-02-12 14:58:48,271 DEBUG DB commit
2020-02-12 14:58:48,461 DEBUG DB Start transaction
2020-02-12 14:58:48,462 DEBUG DB commit
2020-02-12 14:58:48,473 DEBUG Stores cert chain check in cache
2020-02-12 14:58:49,941 DEBUG Loading ssl context with cert /opt/wapt/private/f7097310-8436-bf45-ae76-394dd2f63dcf.crt and key /opt/wapt/private/f7097310-8436-bf45-ae76-394dd2f63dcf.pem
FATAL ERROR : Error: [('x509 certificate routines', 'X509_check_private_key', 'key values mismatch')]
File "/opt/wapt//wapt-get.py", line 1429, in <module>
main()
File "/opt/wapt//wapt-get.py", line 1211, in main
description=(" ".join(args[1:])).decode(sys.getfilesystemencoding()),
File "/opt/wapt/common.py", line 5482, in register_computer
signer = self.get_host_certificate().cn
File "/opt/wapt/common.py", line 1852, in post
with self.get_requests_session(surl,use_ssl_auth=use_ssl_auth) as session:
File "/opt/wapt/common.py", line 1594, in get_requests_session
session = get_requests_client_cert_session(url=url,cert=cert,verify=self.verify_cert,proxies=self.proxies)
File "/opt/wapt/waptutils.py", line 779, in get_requests_client_cert_session
result.mount(url, SSLAdapter(cert[0],cert[1],cert[2],**kwargs))
File "/opt/wapt/waptutils.py", line 730, in __init__
super(SSLAdapter, self).__init__(*args, **kwargs)
File "/opt/wapt/lib/python2.7/site-packages/requests/adapters.py", line 129, in __init__
self.init_poolmanager(pool_connections, pool_maxsize, block=pool_block)
File "/opt/wapt/waptutils.py", line 733, in init_poolmanager
self._add_ssl_context(kwargs)
File "/opt/wapt/waptutils.py", line 747, in _add_ssl_context
password=str(self._password))
File "/opt/wapt/lib/python2.7/site-packages/urllib3/contrib/pyopenssl.py", line 439, in load_cert_chain
self._ctx.use_privatekey_file(keyfile or certfile)
File "/opt/wapt/lib/python2.7/site-packages/OpenSSL/SSL.py", line 990, in use_privatekey_file
self._raise_passphrase_exception()
File "/opt/wapt/lib/python2.7/site-packages/OpenSSL/SSL.py", line 967, in _raise_passphrase_exception
_raise_current_error()
File "/opt/wapt/lib/python2.7/site-packages/OpenSSL/_util.py", line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [('x509 certificate routines', 'X509_check_private_key', 'key values mismatch')]
