Paquete de Office 2019
Gaelds
Inscripción: 22 de noviembre de 2015 - 08:37
30 de octubre de 2020 - 10:20
Utilicé el ejemplo del paquete para Office 2019 que pareció funcionar aquí:
viewtopic.php?f=9&t=2407&p=7967&hilit=office+2019#p7967
pero sigo recibiendo el error:
CalledProcessErrorOutput: el comando '"setup.exe" /configure "configuration-office2019.xml"' devolvió un estado de salida distinto de cero -2146994714.
Aquí está mi setup.py:
# You should also check for the uninstall string for uninstall_args by using : wapt-get list-registry Office
# raccourcis
RaccourcisDossierProgramm1 = makepath(programfiles32,"Microsoft Office","root","Office16")
softname = "Microsoft Office Professional Plus 2019 - fr-fr"
pgmsoffice = programfiles
uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
kill_list = ['winword.exe','powerpnt.exe','excel.exe','mspub.exe','msaccess.exe','infopath.exe','lync.exe','onenote.exe','outlook.exe','onenotem.exe','msosync.exe','groove.exe','OfficeClicktoRun.exe']
    office_installed = installed_softwares(softname)
    cmd = '"setup.exe" /configure "configuration-office2019.xml"'
    if not office_installed:
        print('Installation de {}'.format(softname))
        if Version(office_installed[0]['version']) < Version(control.version.split('-',1)[0]):
            print('{} already up to date or newer : {}'.format(softname,office_installed[0]['version']))
        error(' {} has been installed but the uninstall key can not be found'.format(softname))
    print('Copie des fichiers de desinstallation uninstall-all.XML et setup.exe')
    copytree2(r"uninstall",(RaccourcisDossierProgramm1))
    print('Removing {}'.format(softname))
    for soft in kill_list:
        killalltasks(soft)
    uninstallcmd = r'"C:\Program Files (x86)\Microsoft Office\root\Office16\setup.exe" /configure "C:\Program Files (x86)\Microsoft Office\root\Office16\uninstall-all.xml"'
    print('desinstallation de Microsoft Office')
    run(uninstallcmd,timeout=1800,accept_returncodes=[1641,3010,0])
    print('fin de uninstall')
Y el archivo configuration-office2019.xml:
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019" SourcePath="\\172.16.10.3\Logiciels\Office2019\" AllowCdnFallback="TRUE">
    <Product ID="ProPlus2019Volume" PIDKEY="xxxxxxxxxxxxxxxxxxxxx">
      <Language ID="fr-fr" />
      <ExcludeApp ID="Groove" />
      <ExcludeApp ID="OneDrive" />
      <ExcludeApp ID="Outlook" />
    </Product>
    <Product ID="LanguagePack">
    </Product>
    <Product ID="ProofingTools">
	  <Language ID="de-de" />
      <Language ID="en-us" />
	  <Language ID="es-ES" />
    </Product>
  </Add>
  <Property Name="SharedComputerLicensing" Value="0" />
  <Property Name="PinIconsToTaskbar" Value="FALSE" />
  <Property Name="SCLCacheOverride" Value="0" />
  <Property Name="AUTOACTIVATE" Value="1" />
  <Property Name="FORCEAPPSHUTDOWN" Value="TRUE" />
  <Property Name="DeviceBasedLicensing" Value="0" />
  <Updates Enabled="TRUE" UpdatePath="\\172.16.10.3\Logiciels\Office2019\Updates\" />
  <AppSettings>
    <Setup Name="Company" Value="XXX" />
    <User Key="software\microsoft\office\16.0\common\toolbars" Name="screentipscheme" Value="2" Type="REG_DWORD" App="office16" Id="L_ShowScreenTips" />
    <User Key="software\microsoft\office\16.0\excel\options" Name="defaultformat" Value="51" Type="REG_DWORD" App="excel16" Id="L_SaveExcelfilesas" />
    <User Key="software\microsoft\office\16.0\powerpoint\options" Name="defaultformat" Value="27" Type="REG_DWORD" App="ppt16" Id="L_SavePowerPointfilesas" />
    <User Key="software\microsoft\office\16.0\word\options" Name="defaultformat" Value="" Type="REG_SZ" App="word16" Id="L_SaveWordfilesas" />
  </AppSettings>
  <Display Level="None" AcceptEULA="TRUE" />
  <Logging Level="Off" />
</Configuration>
Gaelds
30 de octubre de 2020 - 11:29
El siguiente comando, ejecutado manualmente, funciona en las máquinas:
\\172.16.10.3\Logiciels\Office2019\setup.exe /configure \\172.16.10.3\Logiciels\Office2019\configuration-office2019.xml.
Sospecho que la cuenta del sistema utilizada por wapt podría no tener acceso al recurso compartido de red... Por lo tanto, es necesario cambiar la ruta de origen (SourcePath) en el archivo XML de configuración, pero he probado con "./office", "office" y ".\office". Nada funciona.
Gaelds
6 de noviembre de 2020 - 11:49
Sigo sin encontrar una solución. El comando ejecutado desde la carpeta compartida funciona:
"\\172.16.10.3\logiciels\Office2019\setup.exe /configure /configuration-office2019.xml" instala Office correctamente.
Sin embargo, al copiar localmente setup.exe y el archivo configuration-office2019.xml, no funciona.
"C:\temp\setup.exe /configure /configuration-office2019.xml"
muestra el error 30088-1021 (0).
Supongo que es el mismo error que impide la instalación mediante el paquete.
dcardón
6 de noviembre de 2020 - 12:06 p. m
Este foro y la documentación de WAPT indican claramente que se desaconseja encarecidamente el acceso a recursos compartidos de red para la instalación de paquetes. La instalación no necesariamente se produce cuando la máquina tiene acceso a la red, y más concretamente, acceso al servidor en cuestión (máquina conectada por Wi-Fi, 802.1x, VPN), o las credenciales de conexión podrían no coincidir (el agente de WAPT se ejecuta en LocalSystem, que no siempre está bien integrado). Es mucho mejor incluir los archivos ejecutables en el paquete (o crear dos paquetes separados si esto supone un problema real, por ejemplo, si se modifican con frecuencia los parámetros de instalación).
Saludos,
Gaelds
9 de noviembre de 2020 - 14:36
Bien, ¡gracias por la respuesta! Pero ¿podrías decirme qué poner en SourcePath? He intentado añadir la carpeta "office" que contiene los archivos de instalación al paquete y usar SourcePath="office", SourcePath="./office" y SourcePath=".\office", pero nada funciona...
TeoMrbl
Inscripción: 20 de noviembre de 2020 - 09:09
20 de noviembre de 2020 - 09:21
retomo este hilo.
¿Ha habido algún avance con este paquete? Estoy experimentando el mismo problema que tú.
Espero tu respuesta.
Saludos cordiales. ¡
Que tengas un buen día!
Gaelds
23 de noviembre de 2020 - 10:33
Acabo de instalar el paquete en una máquina con el comando "wapt-get install --direct -ldebug". Office se instaló correctamente, pero la ventana de instalación era visible a pesar de la instrucción `Display Level="NONE"` en el archivo "configuration-office2019.xml"
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019" SourcePath="Office" AllowCdnFallback="TRUE">
    <Product ID="ProPlus2019Volume" PIDKEY="XXXXXXXXXXXXXXXXXXXXXXXXXXX">
    </Product>
    </Product>
    </Product>
  </Add>
  <Updates Enabled="TRUE" UpdatePath="Updates" />
  <AppSettings>
    <Setup Name="Company" Value="DOM SORTAIS" />
  </AppSettings>
  <Display Level="NONE" AcceptEULA="TRUE" />
</Configuration>
Gaelds
23 de noviembre de 2020 - 13:50
Y aquí están los registros cuando hago un simple "wapt-get install dst-microsoft-office"
Instalando dst-microsoft-office(=16.0.13231.20350-22)
Eliminando la aplicación de Office de Win10 desde
Instalando Microsoft Office Professional Plus 2019 - fr-fr
2020-11-23 14:56:52,713 CRITICAL Error fatal en el script de instalación: CalledProcessErrorOutput: El comando '"c:\\users\\adm\\appdata\\local\\temp\\waptg1exkt\\setup.exe" /configure "./configuration-office2019.xml"' devolvió un estado de salida distinto de cero -2147418113.
Salida::
Traceback (última llamada):
Archivo "C:\wapt\common.py", línea 3876, en install_wapt
Archivo "c:\users\adm\appdata\local\temp\waptg1exkt\setup.py", línea 24, en install
Archivo "C:\wapt\common.py", línea 3646, en run
return ensure_unicode(setuphelpers.run(*arg,**args))
Archivo "C:\wapt\setuphelpers_windows.py", línea 3716, en run
CalledProcessErrorOutput: Comando '"c:\\users\\adm\\appdata\\local\\temp\\waptg1exkt\\setup.exe" /configure "./configuration-office2019.xml"' devolvió un estado de salida distinto de cero -2147418113.
Salida:
2020-11-23 14:56:53,641 CRITICAL El paquete dst-microsoft-office [x64_fr_PROD] no se instaló debido a errores: CalledProcessErrorOutput: El comando '"c:\\users\\adm\\appdata\\local\\temp\\waptg1exkt\\setup.exe" /configure "./configuration-office2019.xml"' devolvió un estado de salida distinto de cero -2147418113.
Salida:
florentR2
Inscripción: 13 de febrero de 2020 - 17:23
3 de marzo de 2021 - 16:23
Habiendo luchado también con este mismo problema, la solución muy simple que funcionó para mí fue vaciar el SourcePath de esta manera:
SourcePath=""
