[Resuelto] 1.8.2.7303 => EXEC generando /opt/wapt/bin/python: Error de formato de ejecución
Marcolefo
Inscripción: 02 oct 2018 - 11:13
18 de noviembre de 2020 - 10:30 a. m
Tras la actualización de anoche, el servicio wpatserver ya no se inicia:
En /var/log/syslog
Nov 18 10:03:26 wobani systemd[2612]: waptserver.service: Failed to execute command: Exec format error
Nov 18 10:03:26 wobani systemd[2612]: waptserver.service: Failed at step EXEC spawning /opt/wapt/bin/python: Exec format error
Nov 18 10:03:26 wobani systemd[1]: waptserver.service: Main process exited, code=exited, status=203/EXEC
Nov 18 10:03:26 wobani systemd[1]: waptserver.service: Failed with result 'exit-code'.
En /var/log/dpkg.log:
2020-11-18 04:09:20 upgrade tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:09:20 status half-configured tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76
2020-11-18 04:09:20 status unpacked tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76
2020-11-18 04:09:20 status half-installed tis-waptserver:amd64 1.8.2.7269-debian-10-757cdc76
2020-11-18 04:09:20 status triggers-pending rsyslog:amd64 8.1901.0-1
2020-11-18 04:09:23 status unpacked tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:09:23 upgrade tis-waptsetup:all 1.8.2.7269 1.8.2.7303
2020-11-18 04:09:23 status half-configured tis-waptsetup:all 1.8.2.7269
2020-11-18 04:09:23 status unpacked tis-waptsetup:all 1.8.2.7269
2020-11-18 04:09:23 status half-installed tis-waptsetup:all 1.8.2.7269
2020-11-18 04:09:23 status unpacked tis-waptsetup:all 1.8.2.7303
2020-11-18 04:09:23 startup packages configure
2020-11-18 04:09:23 configure tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf <none>
2020-11-18 04:09:23 status half-configured tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:10:54 status installed tis-waptserver:amd64 1.8.2.7303-e2aff254-debian-10-armhf
2020-11-18 04:10:54 configure libldap-common:all 2.4.47+dfsg-3+deb10u4 <none>
2020-11-18 04:10:54 status unpacked libldap-common:all 2.4.47+dfsg-3+deb10u4
2020-11-18 04:10:54 status half-configured libldap-common:all 2.4.47+dfsg-3+deb10u4
2020-11-18 04:10:54 status installed libldap-common:all 2.4.47+dfsg-3+deb10u4
2020-11-18 04:10:54 configure tis-waptsetup:all 1.8.2.7303 <none>
2020-11-18 04:10:54 status unpacked tis-waptsetup:all 1.8.2.7303
2020-11-18 04:10:54 status half-configured tis-waptsetup:all 1.8.2.7303
2020-11-18 04:10:54 status installed tis-waptsetup:all 1.8.2.7303
¿Cómo se puede solucionar esto?
Última edición realizada por marcolefo el 18 de noviembre de 2020 a las 17:15, editado 1 vez.
Servidor WAPT Enterprise: 2.6.0.17343 / Sistema operativo del servidor: Debian bookworm /
Sistema operativo de la máquina de administración/creación de paquetes: macOS 15
Marcolefo
18 de noviembre de 2020 - 10:39
Parece que es la versión ARM la que se ha implementado...
¿Estoy equivocado?
Mi configuración de apt:
cat /etc/apt/sources.list.d/wapt.list
# Auth => auth.conf.d/wapt_enterprise.conf
deb https://srvwapt-pro.tranquil.it/entreprise/debian/wapt-1.8/ buster main
dcardón
18 de noviembre de 2020 - 10:51
Hola marcolefo,
Hubo una confusión entre los paquetes ARMFH y AMD64 en el repositorio. Esto se ha corregido; consulte el correo electrónico a continuación:
https://lists.tranquil.it/pipermail/wap...04210.html
Para corregir:
apt update && apt remove tis-waptserver && apt install tis-waptserver
Lo siento. Saludos,
Marcolefo
18 de noviembre de 2020 - 14:54
Sí, lo vi en Discord ;)
Pero :
apt update && apt install tis-waptserver --reinstall
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:3 http://ftp.debian.org/debian buster-backports InRelease
Hit:4 http://security.debian.org buster/updates InRelease
Hit:5 https://repo.saltstack.com/py3/debian/10/amd64/latest buster InRelease
Hit:6 https://srvwapt-pro.tranquil.it/entreprise/debian/wapt-1.8 buster InRelease
Hit:7 http://repo.zabbix.com/zabbix/4.2/debian buster InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Reinstallation of tis-waptserver is not possible, it cannot be downloaded.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
 aptitude versions tis-waptserver
p   1.8.2.7303-e2aff254-debian-10-amd64   <NULL>                                 500
i   1.8.2.7303-e2aff254-debian-10-armhf                                          100
Estaba a punto de hacer una
¿Qué opinas?
Marcolefo
18 de noviembre de 2020 - 17:15
Finalmente restauré mi VM.
