[RISOLTO] Pacchetto certificato in errore
eliottifo
Registrazione: 2 maggio 2022 - 10:41
2 maggio 2022 - 10:53
Al momento sto testando WAPT Enterprise con una licenza demo.
Ho creato un gruppo di pacchetti di certificati collegati ai miei utenti e quando provo a distribuirli, ecco il registro degli errori che ottengo:
Installing cam-cert-adm-etiphaneau(=1.0-1)
Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n    print("Certificate %%s found" %% (crt_location))\n                                   ^\nSyntaxError: invalid syntax\n']]
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1880, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 656, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1229, in _run
Exception: Erreur lors de l'installation de ['cam-cert-adm-etiphaneau']: erreurs dans les paquets [[PackageRequest(package='cam-cert-adm-etiphaneau',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19043.2'),max_os_version=Version('10.0.19043.2')), PackageEntry('cam-cert-adm-etiphaneau','1.0-1' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5134, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4118, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3967, in install_wapt\n    setup = import_setup(setup_filename)\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1539, in import_setup\n    py_mod = imp.load_source(modulename, setupfilename)\n  File "imp.py", line 171, in load_source\n  File "<frozen importlib._bootstrap>", line 702, in _load\n  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked\n  File "<frozen importlib._bootstrap_external>", line 839, in exec_module\n  File "<frozen importlib._bootstrap_external>", line 976, in get_code\n  File "<frozen importlib._bootstrap_external>", line 906, in source_to_code\n  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed\n  File "C:\\WINDOWS\\TEMP\\waptx4_cv5ls\\setup.py", line 24\n    print("Certificate %%s found" %% (crt_location))\n                                   ^\nSyntaxError: invalid syntax\n']]
    self._run()
WAPT2.2 ENTERPRISE, server Linux Debian 10, macchina di amministrazione Windows 10.
Grazie in anticipo per il tuo feedback.
Ultima modifica di eliottiph il 2 maggio 2022 alle 11:48, modificato 1 volta.
sfontenau
2 maggio 2022 - 11:47
si è verificato un errore nell'ultima versione.
Sul suo computer, può applicare una patch al file: C:\Program Files (x86)\wapt\templates\setup_package_template_cert.py.tmpl.
Nel file, può sostituire %% con % (il doppio %% con un singolo %).
Grazie per il suo feedback; ho appena corretto l'errore
. Cordiali saluti.
eliottifo
2 maggio 2022 - 12:15
Buongiorno signor Fonteneau,
Grazie per il tuo feedback.
L'errore persiste nonostante la modifica del file setup_package_template_cert.py.tmpl
Ora la mia console si blocca e disabilita il servizio WAPT sul mio computer con console Win10, che è anche il computer su cui testo le distribuzioni. Il computer passa allo stato "DISCONNECTED", il che mi costringe a riattivarlo manualmente.
Tronco d'albero:
  File "C:\Program Files (x86)\wapt\common.py", line 3967, in install_wapt
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1539, in import_setup
  File "C:\WINDOWS\TEMP\waptubbf04_n\setup.py", line 24
SyntaxError: invalid syntax (setup.py, line 24)
sfontenau
2 maggio 2022 - 13:48
Sì, in effetti la patch consente di correggere il pacchetto durante la sua creazione
Puoi quindi eliminare il vecchio pacchetto di certificati dal tuo repository privato e poi eseguire un'operazione di "dimenticanza" sulla macchina in cui il pacchetto era già stato installato:
wapt-get forget packagename
Fare clic con il pulsante destro del mouse sul pacchetto di errore sulla macchina dalla console e selezionare "dimentica"
L'errore che descrivi, tuttavia, sembra strano e non è correlato al problema precedente
Simon Fonteneau
5 maggio 2022 - 19:23
il modello del pacchetto per il pacchetto del certificato è stato corretto nell'ultima versione di correzione bug wapt-2.2.1.11932-6522dccb rilasciata oggi.
