Dopo aver aggiornato il server alla versione 2.2, nessun computer riesce a connettersi al server.
Versione del server WAPT: 2.2.1
Versione di installazione WAPT: 2.2.1.11932
Versione di distribuzione WAPT: 2.2.1.11932
Stato di base: OK (2.2.5.1)
Ecco i registri che ho:
May 9 14:22:06 wapt waptserver[5085]: 2022-05-09 14:22:06,798 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098926) ON CONFLIC...\n ^\n")
May 9 14:22:06 wapt waptserver[5085]: 2022-05-09 14:22:06,926 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098926) ON CONFLIC...\n ^\n")
May 9 14:22:07 wapt waptserver[5085]: 2022-05-09 14:22:07,192 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098927) ON CONFLIC...\n ^\n")
May 9 14:22:07 wapt waptserver[5085]: 2022-05-09 14:22:07,661 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098927) ON CONFLIC...\n ^\n")
May 9 14:22:08 wapt waptserver[5085]: 2022-05-09 14:22:08,137 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098928) ON CONFLIC...\n ^\n")
May 9 14:22:08 wapt waptserver[5085]: 2022-05-09 14:22:08,396 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098928) ON CONFLIC...\n ^\n")
May 9 14:22:08 wapt waptserver[5085]: 2022-05-09 14:22:08,815 [waptserver ] CRITICAL Get_websocket_auth_token failed ProgrammingError("ERREUR: erreur de syntaxe sur ou près de « ON »\nLINE 1: ...41bfbe2-cbed-11e5-a7cc-000c294e492a', 1652098928) ON CONFLIC...\n
