WUA: errore pywintypes 2147352567
t.heroult
Iscrizioni: 8 dicembre 2020 - ore 10:13
18 agosto 2022 - 14:09
Buongiorno
Ho riscontrato questo problema su alcuni computer (Win 10 pro, Win 7 embedded, Win 10 LTSD)...
Lo stato di errore restituisce:
0x80020009 (Une exception s’est produite.): 0x80240031 ((unable to get meaning for error code 0x80240031))
E i dettagli sono i seguenti:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download": false,
 "default_allow": false,
 "include_potentially_superseded_updates": false,
 "filter": "Type='Software' or Type='Driver'",
 "download_scheduling": "5d",
 "install_scheduling": "12h",
 "install_delay": "2d",
 "postboot_delay": "10m"
Windows updates rules have been changed
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
re-enabling wuauserv previous state: 0
(-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1894, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 692, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 291, in _run
    self.result = wua.install_updates(self.force, uuids=self.uuids)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 1335, in install_updates
    self.scan_updates_status()
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 913, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 821, in updates
    search_job = self.update_searcher().BeginSearch(self.params.filter, scb_interface, None)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 783, in update_searcher
    self._update_service = self.update_service_manager().AddScanPackageService("Offline Sync Service", self.wsusscn2)
  File "C:\WINDOWS\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateServiceManager2.py", line 36, in AddScanPackageService
    ret = self._oleobj_.InvokeTypes(1610743814, LCID, 1, (9, 0), ((8, 1), (8, 1), (3, 49)),serviceName
pywintypes.com_error: (-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
    self._run()
A volte, invece di
pywintypes.com_error: (-2147352567, 'Si è verificata un'eccezione.', (0, Nessuno, Nessuno, Nessuno, 0, -2145124303)
Io ho
pywintypes.com_error: (-2147352567, 'Si è verificata un'eccezione.', (0, Nessuno, Nessuno, Nessuno, 0, -2146762487), Nessuno)
Hai idea di cosa ci sia che non va?
Sinceramente,
Tom
Server: WAPT Enterprise 2.6.1.17786 su Debian
Console: Windows 10 e 11
Infrastruttura: Windows
sfontenau
18 agosto 2022 - 17:13
una ricerca per 0x80240031 mi ha dato questi risultati:
https://www.bugsfighter.com/how-to-fix- ... x80240031/
https://www.auslogics.com/en/articles/f ... x80240031/
Potresti provare a seguire i tutorial e vedere se ti aiutano?
