Impossibile installare la versione 2.4
MathieuNG
Registrazione: 22 maggio 2023 - 15:32
26 maggio 2023 - 10:33
Per iniziare, ecco la mia configurazione:
- Versione WAPT installata: 2.3
- Sistema operativo del server: Debian GNU/Linux 11 (bullseye)
- Sistema operativo della macchina di amministrazione/creazione pacchetti: Windows 11
Durante il test di WAPT, volevo scaricare l'ultima versione, ma era impossibile. Quindi ho dovuto installare la versione 2.3, che funziona
root@TEST:~$ apt install apt-transport-https lsb-release gnupg wget -y
wget -O - https://wapt.tranquil.it/$(lsb_release -is)/tiswapt-pub.gpg | apt-key add -
echo "deb https://wapt.tranquil.it/$(lsb_release -is)/wapt-2.4/ $(lsb_release -c -s) main" > /etc/apt/sources.list.d/wapt.list
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
apt-transport-https is already the newest version (2.2.4).
gnupg is already the newest version (2.2.27-2+deb11u2).
lsb-release is already the newest version (11.1.0).
wget is already the newest version (1.21-1+deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
--2023-05-26 10:27:12--  https://wapt.tranquil.it/Debian/tiswapt-pub.gpg
Resolving wapt.tranquil.it (wapt.tranquil.it)... 195.154.18.13, 2001:bc8:392f:101::13
Connecting to wapt.tranquil.it (wapt.tranquil.it)|195.154.18.13|:443... Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
connected.
HTTP request sent, awaiting response... 200 OK
Length: 3839 (3.7K) [application/octet-stream]
Saving to: ‘STDOUT’
-                                       100%[===============================================================================>]   3.75K  --.-KB/s    in 0s
2023-05-26 10:27:12 (446 MB/s) - written to stdout [3839/3839]
OK
root@TEST:~$ export DEBIAN_FRONTEND=noninteractive
apt update
apt install tis-waptserver tis-waptsetup -y
unset DEBIAN_FRONTEND
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Ign:4 https://wapt.tranquil.it/Debian/wapt-2.4 bullseye InRelease
Err:5 https://wapt.tranquil.it/Debian/wapt-2.4 bullseye Release
  404  Not Found [IP: 195.154.18.13 443]
E: The repository 'https://wapt.tranquil.it/Debian/wapt-2.4 bullseye Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
tis-waptserver is already the newest version (2.3.0.13516-69968974-debian-11-amd64).
tis-waptsetup is already the newest version (2.3.0.13516-69968974-debian-10-amd64).
root@TEST:~$
Inoltre, quando vado all'URL "https://wapt.tranquil.it/Debian/wapt-2.4", ottengo "404 non trovato" ma sull'URL "https://wapt.tranquil.it/debian/wapt-2.3/"Ho una struttura ad albero.
Sinceramente,
sfontenau
26 maggio 2023 - 12:00
La versione 2.4 era una Release Candidate.
L'ho appena spostata allo stato di Release (sono in arrivo le comunicazioni).
Quindi puoi riprovare.
