[RISOLTO] Errore con il pacchetto microsoft-teams-uwp
Gaeldi
Registrazione: 22 nov 2015 - 08:37
9 aprile 2024 - 15:48
Ho distribuito il pacchetto microsoft-teams-uwp sulla mia rete, ma alcune decine di computer continuano a riscontrare errori. Su questi computer, posso installare manualmente il file MSteams-x64.msix, ma il pacchetto non si installa comunque. I computer interessati eseguono Windows 10 20H2/21H1/21H2 o Windows 11 21H2/22H2
Ecco un esempio di errore nella console:
Installing: MSTeams-x64.msix (24004.1309.2689.2246)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1194, in run_powershell
    result = run(cmd,
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2174, in run
    raise CalledProcessErrorOutput(proc.returncode, cmd, ''.join(output+return_stderr))
waptutils.CalledProcessErrorOutput: Command 'powershell -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "QQBkAGQALQBBAHAAcAB4AFAAcgBvAHYAaQBzAGkAbwBuAGUAZABQAGEAYwBrAGEAZwBlACAALQBPAG4AbABpAG4AZQAgAC0AUABhAGMAawBhAGcAZQBQAGEAdABoACAAIgBNAFMAVABlAGEAbQBzAC0AeAA2ADQALgBtAHMAaQB4ACIAIAAtAFMAawBpAHAATABpAGMAZQBuAHMAZQA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="progress" RefId="0"><TN RefId="0"><T>System.Management.Automation.PSCustomObject</T><T>System.Object</T></TN><MS><I64 N="SourceId">1</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><Obj S="progress" RefId="1"><TNRef RefId="0" /><MS><I64 N="SourceId">2</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><S S="Error">Add-AppxProvisionedPackage : Le package ne satisfait pas à la condition requise pour la mise en service de l'image _x000D__x000A_</S><S S="Error">cible. Pour plus d'informations, voir l'aide._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\Program Files (x86)\wapt\common.py", line 4234, in install_wapt
  File "C:\Windows\TEMP\waptucvpk3rl\setup.py", line 24, in install
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1198, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
E in secondo luogo, prima di disinstallare i vecchi team, come faccio ad avviare automaticamente i "nuovi team" all'avvio?
Ultima modifica di gaelds l'11 giugno 2024 alle 10:49, modificato 3 volte.
Gaeldi
9 aprile 2024 - 17:00
Un altro PC visualizza un errore diverso: "Per installare questa applicazione è necessaria una licenza per sviluppatori Windows o..."
Installing: MSTeams-x64.msix (24033.813.2773.520)
  File "C:\wapt\setuphelpers_windows.py", line 1194, in run_powershell
    result = run(cmd,
  File "C:\wapt\waptutils.py", line 2174, in run
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><Obj S="progress" RefId="0"><TN RefId="0"><T>System.Management.Automation.PSCustomObject</T><T>System.Object</T></TN><MS><I64 N="SourceId">1</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><Obj S="progress" RefId="1"><TNRef RefId="0" /><MS><I64 N="SourceId">2</I64><PR N="Record"><AV>Préparation des modules à la première utilisation.</AV><AI>0</AI><Nil /><PI>-1</PI><PC>-1</PC><T>Completed</T><SR>-1</SR><SD> </SD></PR></MS></Obj><S S="Error">Add-AppxProvisionedPackage : L'installation de cette application requiert une licence de développeur Windows ou un _x000D__x000A_</S><S S="Error">système compatible avec le chargement indépendant._x000D__x000A_</S><S S="Error">Au caractère Ligne:1 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\wapt\common.py", line 4234, in install_wapt
  File "C:\Windows\TEMP\waptyd_xmrlk\setup.py", line 24, in install
  File "C:\wapt\setuphelpers_windows.py", line 1198, in run_powershell
Output:#< CLIXML
Output:#< CLIXML
10 aprile 2024 - 10:26
Ciao Gaël,
Quando si testa manualmente l'installazione, si utilizza la stessa riga di comando?
Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -SkipLicense
L'hai testato come account di sistema? (avviando un comando PowerShell con psexec -i -s powershell.exe)
Sinceramente,
Gaeldi
10 aprile 2024 - 11:02
Ciao, ecco come appare su uno dei PC interessati.
2024-04-10 11_00_12-Window.jpg (38,35 KB) Visualizzato 14111 volte
Gaeldi
10 aprile 2024 - 11:38
Non capisco bene, ma sembra funzionare meglio stamattina. Sullo stesso PC di cui sopra, ho reinstallato manualmente MSTeams-x64.msix come amministratore (era scomparso da ieri). Poi ho reinstallato il pacchetto microsoft-teams-uwp_24033.813.2773.520 e questa volta ha funzionato!
Ho appena fatto la stessa cosa su un altro PC desktop bloccato e anche lì il pacchetto ha funzionato dopo l'installazione manuale di msix.
Ci sono circa quaranta PC da sbloccare. :gridare: Di quelli che rimangono, ci sono solo portatili; non so se sia una coincidenza...?
10 aprile 2024 - 12:20
Ciao Gaël,
Potresti provare il seguente comando sul computer interessato prima di eseguire nuovamente add-appxprovisionedpackage?
Remove-AppxProvisionedPackage -PackageName teamsmsix.appx  -Online -AllUsers
Sinceramente,
Gaeldi
10 aprile 2024 - 13:01
Remove-AppxProvisionedPackage: Parametro non corretto.
Riga carattere:1: 1
+ Remove-AppxProvisionedPackage -PackageName teamsmsix.appx -Online -A ...
+ CategoryInfo: NotSpecified: (:) [Remove-AppxProvisionedPackage], PSArgumentException
+ FullyQualifiedErrorId: Microsoft.Dism.Commands.RemoveAppxProvisionedPackageCommand
Gaeldi
10 aprile 2024 - 13:47
Ho appena sbloccato l'installazione su 3 PC modificando questo valore in gpedit > Configurazione > Computer > Modelli amministrativi > Componenti > Distribuzione pacchetti applicazione, abilitando: Consenti l'installazione di tutte le applicazioni attendibili.
Fonte:https://learn.microsoft.com/fr-fr/micro ... installation
Ultima modifica di gaelds il 12 aprile 2024 alle 15:09, modificato 2 volte.
sfontenau
10 aprile 2024 - 14:53
Sui PC che presentano questo problema, puoi provare a fare quanto segue:
https://learn.microsoft.com/en-us/micro ... e-computer
Gaeldi
10 giugno 2024 - 11:57
Ho aggiornato di recente il pacchetto microsoft-teams-uwp (24102) e riscontro nuovamente errori sui PC in cui era installato il pacchetto precedente (versione 24033).
Su alcuni PC (sempre laptop!, Windows 10 o 11) ricevo questo errore:
Installing: MSTeams-x64.msix (24102.2223.2870.9480)
    result = run(cmd,
Output:#< CLIXML
  File "C:\Windows\TEMP\wapthidyptta\setup.py", line 24, in install
Output:#< CLIXML
Output:#< CLIXML
Sono riuscito a installare manualmente MSTeams-x64.msix (scaricato dal sito web di Microsoft) su alcuni PC e il pacchetto si è installato normalmente. Tuttavia, ci sono ancora alcuni casi in cui il pacchetto non riesce a installarsi, nonostante New Teams sia già presente e funzionante.
A volte riesco ad avviare MSTeams-x64.msix manualmente solo se abilito "Consenti installazione di applicazioni attendibili" nei criteri locali.
MODIFICA: Dopo aver eseguito sfc /scannow (oltre al GPO che abilita "Consenti l'installazione di applicazioni attendibili"), mi sono rimasti solo 8 laptop ostinati. Ma a parte ricreare l'immagine del disco, sono bloccato... New Teams è installato correttamente con il pacchetto msix, ma il pacchetto non funziona.
