[RISOLTO] Valore DataError troppo lungo per il tipo di carattere variabile
yann83
Registrazione: 22 aprile 2021 - 07:54
3 maggio 2024 - 14:07
Buongiorno
Su alcune workstation ho un valore di controllo vuoto e nessuna informazione generale oltre all'ultima connessione e all'UUID.
A cosa potrebbe corrispondere questo errore nei dati?
DataError('valore troppo lungo per il tipo di carattere variabile (255)\n')
Ho il seguente registro:
2024-05-03 13:53:41,227 [wapttasks WaptTaskManager 2568] INFO Reloading waptcore configuration for Wapt instance thread 2568
2024-05-03 13:53:41,258 [wapttasks WaptTaskManager 2568] INFO Core Wapt config file has changed, reloaded. Reloading waptservice config too
2024-05-03 13:53:41,267 [wapttasks WaptTaskManager 2568] INFO Host capabilities have changed since last update 49ddc57ee5f64e34074542c361ba45e5f11e0fb9681795b24472f098707d7b17 -> 36e5d9a22f5b9ccc60af94bc50acbd7e0c32c02cf473717a72e67a0f7e737d8a, forcing update
2024-05-03 13:53:41,268 [wapttasks WaptTaskManager 2568] INFO Service config have changed 1be8e68afd9a14accfea6124f19f30e64f55c0d1bc025658b4eb979ec106c66d -> 593f766fdeeb222cc03684e1642d997484682382553045b5a593c253a1383691, forcing update
2024-05-03 13:54:03,799 [wapttasks WaptTaskManager 2568] INFO Add task Mise à jour de la liste des paquets disponibles to queue
2024-05-03 13:54:03,804 [wapttasks WaptTaskManager 2568] INFO Running task Mise à jour de la liste des paquets disponibles created by SCHEDULER
Get packages index from [<WaptRepo https://depot.serveur/wapt verify_cert=False client_cert_path=C:\Program Files (x86)\wapt\private\73dffc33-3f7d-3996-362c-d8496f1b75dd.crt>, <WaptHostRepo https://wapt.serveur/wapt-host for host_id 73dffc33-3f7d-3996-362c-d8496f1b75dd >]
2024-05-03 13:54:07,068 [wapttasks WaptTaskManager 2568] CRITICAL Unable to update server status: Error on server:
DataError('value too long for type character varying(255)\n')
3 maggio 2024 - 15:25
Ciao Yann83,
versione di WAPT, sistema operativo del server, sistema operativo del client, ecc. (vedi le regole del forum).
Avremmo bisogno del log con il messaggio di errore dal lato server; questo dovrebbe fornire maggiori informazioni.
yann83
3 maggio 2024 - 15:54
Questo è un server WAPT Enterprise 2.5.4, versione 15342
Su un server CentOS 7 con client Windows 10 22H2
lato server in waptserver.log
May  3 14:45:45 serveurdepot waptserver[642178]: 2024-05-03 14:45:45,476 [waptdb         ] CRITICAL Error updating data for 3891240b-2331-e6e7-26a3-14d0e6df1bac : DataError: value too long for type character varying(255)
May  3 14:45:45 serveurdepot waptserver[642178]: 2024-05-03 14:45:45,476 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 14:45:57 serveurdepot waptserver[642178]: 2024-05-03 14:45:57,557 [waptdb         ] CRITICAL Error updating data for 3891240b-2331-e6e7-26a3-14d0e6df1bac : DataError: value too long for type character varying(255)
May  3 14:45:57 serveurdepot waptserver[642178]: 2024-05-03 14:45:57,558 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 14:57:23 serveurdepot waptserver[642178]: 2024-05-03 14:57:23,960 [waptserver     ] CRITICAL add_host failed EWaptAuthenticationFailure('register_host : Mismatch hostname and subject_alt_names poste050.cnamts.local / poste002.cnamts.local')
May  3 15:03:28 serveurdepot waptserver[642178]: 2024-05-03 15:03:28,128 [waptdb         ] CRITICAL Error updating data for 00222798-6bec-ec11-8145-c83632083293 : DataError: value too long for type character varying(255)
May  3 15:03:28 serveurdepot waptserver[642178]: 2024-05-03 15:03:28,129 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 15:14:55 serveurdepot waptserver[642178]: 2024-05-03 15:14:55,715 [waptserver     ] CRITICAL add_host failed EWaptAuthenticationFailure('register_host : Mismatch hostname and subject_alt_names poste050.cnamts.local / poste002.cnamts.local')
May  3 15:15:16 serveurdepot waptserver[642178]: 2024-05-03 15:15:16,714 [waptserver     ] CRITICAL add_host failed EWaptAuthenticationFailure('register_host : Mismatch hostname and subject_alt_names poste050.cnamts.local / poste002.cnamts.local')
May  3 15:15:36 serveurdepot waptserver[642178]: 2024-05-03 15:15:36,254 [waptserver     ] CRITICAL add_host failed EWaptAuthenticationFailure('register_host : Mismatch hostname and subject_alt_names poste050.cnamts.local / poste002.cnamts.local')
May  3 15:22:15 serveurdepot waptserver[642178]: 2024-05-03 15:22:15,752 [waptdb         ] CRITICAL Error updating data for 84a194d1-2a5a-a949-86ff-8a12fb03ebf1 : DataError: value too long for type character varying(255)
May  3 15:22:15 serveurdepot waptserver[642178]: 2024-05-03 15:22:15,752 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 15:22:49 serveurdepot waptserver[642178]: 2024-05-03 15:22:49,364 [waptdb         ] CRITICAL Error updating data for 73dffc33-3f7d-3996-362c-d8496f1b75dd : DataError: value too long for type character varying(255)
May  3 15:22:49 serveurdepot waptserver[642178]: 2024-05-03 15:22:49,365 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 15:26:48 serveurdepot waptserver[642178]: 2024-05-03 15:26:48,775 [waptdb         ] CRITICAL Error updating data for 56763959-4245-df15-b88a-a4fe135c7f3f : DataError: value too long for type character varying(255)
May  3 15:26:48 serveurdepot waptserver[642178]: 2024-05-03 15:26:48,776 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 15:28:03 serveurdepot waptserver[642178]: 2024-05-03 15:28:03,818 [waptdb         ] CRITICAL Error updating data for 809f2da3-9ced-ec11-8145-c83632086382 : DataError: value too long for type character varying(255)
May  3 15:28:03 serveurdepot waptserver[642178]: 2024-05-03 15:28:03,819 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 15:32:49 serveurdepot waptserver[642178]: 2024-05-03 15:32:49,144 [waptdb         ] CRITICAL Error updating data for 00e63846-aaed-ec11-8145-c83632086443 : DataError: value too long for type character varying(255)
May  3 15:32:49 serveurdepot waptserver[642178]: 2024-05-03 15:32:49,145 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
May  3 15:35:48 serveurdepot waptserver[642178]: 2024-05-03 15:35:48,793 [waptdb         ] CRITICAL Error updating data for 3891240b-2331-e6e7-26a3-14d0e6df1bac : DataError: value too long for type character varying(255)
May  3 15:35:48 serveurdepot waptserver[642178]: 2024-05-03 15:35:48,794 [waptserver     ] CRITICAL update_host failed DataError('value too long for type character varying(255)\n')
yann83
7 maggio 2024 - 14:39
Ho disinstallato/reinstallato l'agente senza successo
07 14:35:11,564 [wapttasks MainThread 11728] INFO Service Configuration: {'config_filename': 'C:\\Program Files (x86)\\wapt\\wapt-get.ini', 'waptservice_user': None, 'waptservice_password': None, 'MAX_HISTORY': 30, 'waptservice_port': 8088, 'dbpath': 'C:\\Program Files (x86)\\wapt\\db\\waptdb.sqlite', 'loglevel': 'warning', 'log_directory': 'C:\\Program Files (x86)\\wapt\\log', 'waptserver': <WaptServer https://serveur.wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=None>, 'hiberboot_enabled': False, 'max_gpo_script_wait': 180, 'pre_shutdown_timeout': 180, 'log_to_windows_events': False, 'allow_user_service_restart': False, 'signature_clockskew': 21600, 'notify_user': False, 'waptservice_admin_filter': False, 'enable_remote_repo': False, 'local_repo_path': 'C:\\Program Files (x86)\\wapt\\repository', 'local_repo_sync_task_period': '2h', 'local_repo_time_for_sync_start': None, 'local_repo_time_for_sync_end': None, 'local_repo_limit_bandwidth': None, 'wol_port': '7,9', 'wol_relay': False, 'service_auth_type': 'system', 'verify_cert_ldap': False, 'waptservice_poll_timeout': 10, 'waptupdate_task_period': '120m', 'download_after_update_with_waptupdate_task_period': True, 'forced_installs_task_period': '2m', 'reconfig_on_network_change': False, 'websockets_verify_cert': 'C:\\Program Files (x86)\\wapt\\ssl\\server\\serveur.wapt.crt', 'update_server_status_on_connect': False, 'loglevel_waptcore': None, 'loglevel_waptservice': None, 'loglevel_waptws': None, 'loglevel_waptdb': None, 'loglevel_websocket': None, 'loglevel_waitress': None, 'loglevel_wapttasks': None}
2024-05-07 14:35:11,564 [wapttasks MainThread 11728] INFO Starting task queue
2024-05-07 14:35:11,564 [wapttasks WaptTaskManager 12976] INFO Wapt tasks management initialized with C:\Program Files (x86)\wapt\wapt-get.ini configuration
2024-05-07 14:35:11,565 [wapttasks MainThread 11728] INFO Tasks queue running
2024-05-07 14:35:11,567 [wapttasks MainThread 11728] INFO Starting waitress waptservice on port 8088
2024-05-07 14:35:11,575 [wapttasks SocketIOClient 16820] INFO Starting socketio on "https://serveur.wapt:443" Thread id 16820
2024-05-07 14:35:11,576 [wapttasks SocketIOClient 16820] INFO Socketio connection params have changed. Socketio needs reconnect
2024-05-07 14:35:11,577 [wapttasks SocketIOClient 16820] INFO Creating socketio client: https://serveur.wapt:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\00222798-6bec-ec11-8145-c83632083293.crt', 'C:\\Program Files (x86)\\wapt\\private\\00222798-6bec-ec11-8145-c83632083293.pem') proxies: None verify_cert: C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt
2024-05-07 14:35:11,577 [wapttasks SocketIOClient 16820] INFO Connecting Socketio to https://serveur.wapt:443
2024-05-07 14:35:11,584 [wapttasks WaptTaskManager 12976] INFO Core Configuration: {'wapt_base_dir': 'C:\\Program Files (x86)\\wapt', 'waptserver': <WaptServer https://serveur.wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=C:\Program Files (x86)\wapt\private\00222798-6bec-ec11-8145-c83632083293.crt>, 'config_filename': 'C:\\Program Files (x86)\\wapt\\wapt-get.ini', 'proxies': {'http': '', 'https': ''}, 'repositories': [<WaptRepo https://serveur.wapt/wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=C:\Program Files (x86)\wapt\private\00222798-6bec-ec11-8145-c83632083293.crt>, <WaptHostRepo https://serveur.wapt/wapt-host for host_id 00222798-6bec-ec11-8145-c83632083293 >], 'personal_certificate_path': '', 'public_certs_dir': 'C:\\Program Files (x86)\\wapt\\ssl', 'package_cache_dir': 'C:\\Program Files (x86)\\wapt\\cache', 'dbpath': 'C:\\Program Files (x86)\\wapt\\db\\waptdb.sqlite', 'use_http_proxy_for_repo': False, 'use_http_proxy_for_server': False, 'limit_bandwidth': None, 'locales': ['fr'], 'custom_tags': [], 'packages_whitelist': None, 'packages_blacklist': None, 'maturities': ['PROD'], 'host_uuid': '00222798-6bec-ec11-8145-c84632783293', 'use_fqdn_as_uuid': False, 'use_hostpackages': True, 'use_ad_groups': False, 'use_repo_rules': False, 'host_profiles': [], 'host_organizational_unit_dn': 'OU=Magasin,OU=Gestion des Achats et du Patrimoine,OU=Departement des Ressouces Budgetaires et Logistiques,OU=Direction Ressources Humaines Logistique et Patrimoine,OU=Direction Generale,OU=Postes,OU=notreOU,OU=nom,DC=nom,DC=fr', 'host_ad_site': None, 'waptaudit_task_period': '2h', 'hiberboot_enabled': 0, 'max_gpo_script_wait': 180.0, 'pre_shutdown_timeout': 180.0, 'uninstallkey_timeout': 120, 'check_certificates_validity': True, 'token_lifetime': 86400, 'trust_all_certs_in_pems': False, 'include_dmi_inventory': False, 'include_wmi_inventory': False, 'wapt_temp_dir': None}
2024-05-07 14:35:11,590 [wapttasks WaptTaskManager 12976] INFO Wapt tasks queue started
2024-05-07 14:35:11,608 [wapttasks SocketIOClient 16820] INFO WS read loop for 120s
2024-05-07 14:35:21,877 [wapttasks WaptTaskManager 12976] INFO Add task Mise � jour de la liste des paquets disponibles to queue
2024-05-07 14:35:21,881 [wapttasks WaptTaskManager 12976] INFO Running task Mise � jour de la liste des paquets disponibles created by SCHEDULER
t packages index from [<WaptRepo https://serveur.wapt/wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\serveur.wapt.crt client_cert_path=C:\Program Files (x86)\wapt\private\00222798-6bec-ec11-8145-c83632083293.crt>, <WaptHostRepo https://serveur.wapt/wapt-host for host_id 00222798-6bec-ec11-8145-c83632083293 >]
2024-05-07 14:35:25,300 [wapttasks WaptTaskManager 12976] CRITICAL Unable to update server status: Error on server:
yann83
13 maggio 2024 - 07:18
Ciao
, non so quale valore superi i 255 caratteri, ma penso che sia molto probabilmente quello nel registro di sistema in cui viene registrato l'indirizzo del computer in Active Directory.
Infatti, in Active Directory, il distinguishedName è lungo 276 caratteri.
Cosa ne pensi? Se sì, come posso risolvere il problema?
29 maggio 2024 - 10:44
Sì, è molto probabile.
Nella prossima versione aumenteremo la dimensione della colonna computer_ad_ou nella tabella hosts. (2048 sembra ragionevole?)
Puoi farlo tu stesso connettendoti al tuo server Wapt ed eseguendo il comando:
sudo -u wapt psql -c "alter table hosts alter column computer_ad_ou type varchar(2048);"
Tranquillo IT
3 giugno 2024 - 09:48
il problema è stato risolto internamente e dovrebbe essere disponibile nella prossima versione di WAPT. Contrassegno questo argomento come risolto.
