[RISOLTO] WAPT 2.5.5.15691: Errore TLS con waptdeploy.exe
Risposta
TomTomGo
Registrazione: 3 maggio 2017 - 15:36
Ubicazione: La Chapelle-sur-Erdre
25 luglio 2024 - 14:36
Server WAPT: Debian 11 aggiornato
Postazione di lavoro client: Windows 11 23H2
Scoperta WAPT 2.5.5.15691
Dopo l'aggiornamento del mio server WAPT da 2.5.5.15640 a 2.5.5.15691 questa mattina, ricevo un messaggio di errore quando provo ad aggiornare l'agente WAPT sulle workstation utilizzando waptdeploy.exe:
waptdeploy.exe --waptsetupurl=https://srvwapt.mydomain/wapt/waptagent.exe --hash=942cde31e7b6144a873b0daad14db24abb040042fb6ed27ee84a76d60918aa7b --minversion=2.5.5.15691 --tasks=autorunTray,installService,installredist2008,!autoUpgradePolicy --wait=15
{"waptsetupurl":"https://srvwapt.mydomain/wapt/waptagent.exe","hash":"942cde31e7b6144a873b0daad14db24abb040042fb6ed27ee84a76d60918aa7b","minversion":"2.5.5.15691","tasks":"autorunTray,installService,installredist2008,!autoUpgradePolicy","wait":"15"}
WAPT version: 2.5.5.15640
WAPT required version: 2.5.5.15691
Wapt agent path: C:\Users\toto\AppData\Local\Temp\waptagent.exe
Wget new waptagent from https://srvwapt.mydomain/wapt/waptagent.exe
Trying to reach https://srvwapt.mydomain/wapt/waptagent.exe...
Expecting hash sha256: 942cde31e7b6144a873b0daad14db24abb040042fb6ed27ee84a76d60918aa7b
Using proxy :
Error trying to get https://srvwapt.mydomain/wapt/waptagent.exe : Error downloading https://srvwapt.mydomain/wapt/waptagent.exe: [ENetSock] THttpClientSocket.DoTlsAfter: TLS failed [ESChannel <srvwapt.mydomain>: ComputeAndSendAnswer returned 80090302 [SEC_E_UNSUPPORTED_FUNCTION], System Error 1 [ERROR_INVALID_FUNCTION]]... sleeping
Delete sheduled task "fullwaptupgrade"
An unhandled exception occurred at $00323D02:
Exception: Error downloading https://srvwapt.mydomain/wapt/waptagent.exe: [ENetSock] THttpClientSocket.DoTlsAfter: TLS failed [ESChannel <srvwapt.mydomain>: ComputeAndSendAnswer returned 80090302 [SEC_E_UNSUPPORTED_FUNCTION], System Error 1 [ERROR_INVALID_FUNCTION]]
  $00323D02
  $00325402
Ho eliminato e rigenerato i certificati SSL Nginx in /opt/wapt/waptserver/ssl/ utilizzando lo script postconf.sh => SAME
Ho anche provato a sostituire l'FQDN del server Wapt con l'indirizzo IP => STESSO RISULTATO (vedi viewtopic.php?p=11185&hilit=%5BENetSock ... led#p11185)
Ho forzato la reinstallazione dei pacchetti tis-waptserver e tis-waptsetup e ho riavviato postconf => STESSO RISULTATO
Sono a corto di idee, qualcun altro ha riscontrato questo problema?
Grazie in anticipo e buona giornata
Ultima modifica da TomTomGo il 29 luglio 2024 alle 15:41, modificato 1 volta.
TomTomGo
25 luglio 2024 - 15:24
Bene, dopo aver consultato il CHANGELOG per la versione 2.5.5.15691, ho visto questo:
[IMP] waptserver: su Linux: usa TLS1.3 per nginx su Linux
Quindi sono tornato a TLS 1.2 in /etc/nginx/sites-enabled/wapt.conf:
ssl_protocols               TLSv1.2;
Dopo aver riavviato i servizi Nginx, tutto funziona di nuovo :)
25 luglio 2024 - 17:15
Ciao Thomas,
sembra che Windows 11 non abiliti TLS 1.3 per impostazione predefinita (è necessario modificare alcune chiavi di registro).
WAPTAgent utilizza OpenSSL per tutta la crittografia, ma WAPTDeploy, per essere più leggero, si basa sull'implementazione schannel di Windows per evitare di dover includere OpenSSL (il che raddoppierebbe le dimensioni di WAPTDeploy...). Inoltre, la configurazione schannel predefinita su Windows 11 non ha TLS 1.3 abilitato (è necessario impostare una chiave di registro/GPO per questo). Nota: Edge utilizza TLS 1.3 perché si basa sul livello TLS di Chromium e non su quello di Windows, quindi questa informazione è un po' fuorviante. Nota 2: Per ingannare ulteriormente l'ignaro amministratore di sistema, TLS 1.3 è abilitato su Windows 10 da diversi anni, anche se Microsoft afferma il contrario, e non è abilitato su Windows 11, anche se Microsoft afferma il contrario[1]...
Siamo passati a TLS 1.3 per il processo di certificazione CSPN, ma poiché TLS 1.2 è ancora accettato da ANSSI, penso che modificheremo il Target di valutazione per specificare TLS 1.2; sarà più semplice.
Grazie per avercelo segnalato.
[1] https://learn.microsoft.com/en-us/windo ... on-support
TomTomGo
25 luglio 2024 - 17:31
dcardon ha scritto: ↑25 lug 2024 - 17:15 Ciao Thomas,
sembra che Windows 11 non abiliti TLS 1.3 per impostazione predefinita (ci sono chiavi di registro che devono essere modificate).
WAPTAgent usa OpenSSL per tutta la crittografia, ma WAPTDeploy, per essere più leggero, si basa sull'implementazione schannel di Windows per evitare di dover includere OpenSSL (che raddoppierebbe le dimensioni di waptdeploy...). E la configurazione schannel predefinita su una macchina Windows 11 non ha TLS 1.3 abilitato (c'è una chiave di registro/GPO che deve essere impostata per questo). Nota: Edge usa TLS 1.3 perché è basato sul livello TLS di Chromium e non su quello di Windows, quindi questo è un po' fuorviante. Nota 2: Per ingannare ulteriormente l'ignaro amministratore di sistema, TLS 1.3 è abilitato su Windows 10 da diversi anni, anche se Microsoft afferma il contrario, e non è abilitato su Windows 11, anche se Microsoft afferma il contrario[1]...
Ciao Denis,
Grazie per il tuo feedback, hai ragione, non è qualcosa che puoi inventare, ed è sorprendente che Windows 11 non abiliti TLS 1.3 per impostazione predefinita, è bello saperlo...
E la gestione indipendente delle versioni di TLS da parte dei browser non aiuta, ma alla fine ho capito che questo era il problema. Quindi, se ho capito bene, continuerai a usare TLS 1.2 finché sarà ancora validato da ANSSI?
Grazie e buona serata
Tommaso
Risposta
