Sto utilizzando WAPT Enterprise versione 2.5.5.15691 su un server Debian 12.6 (6.1.94-1 (21/06/2024)).
Ho provato a distribuire il pacchetto tis-java8 alle workstation tramite un'unità organizzativa AD.
Ricevo il seguente errore:
Installing: drsilil-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
File "<string>", line 1939, in run
self._run()
Exception: Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n exitstatus = setup.install()\n File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
self._run()
Rimuovo il pacchetto dall'elenco dei pacchetti da installare in questa OU.
Ho riscontrato costantemente un errore nello stato di ogni macchina.
Ho quindi provato il pacchetto wapt-forget-packages specificando correttamente il pacchetto tis-java8, ma senza successo, poiché questo pacchetto non è installato sui computer.
L'errore persiste nella console con uno stato di errore per ogni macchina.
Consultando il forum, il consiglio dato è di usare il comando "dimentica il pacchetto".
Ma questo comando non è disponibile quando seleziono una macchina.
Come posso ripristinare lo stato di ogni macchina e rimuovere definitivamente l'installazione di questo pacchetto?
Grazie per qualsiasi consiglio possiate darmi.
Sinceramente,
