[RISOLTO] Pacchetto per Postman (Windows/MacOS)
bastien30
Registrazione: 8 marzo 2024 - 15:21
30 ottobre 2024 - 10:56
Se può essere utile, ecco il codice del pacchetto che utilizzo per il software Postman:
Per Windows:
import time
setup_path = r'C:\ProgramData\postman-installer'
bin_name = r'Postman-win64-Setup.exe'
    mkdirs(setup_path)
    filecopyto(bin_name, makepath(setup_path, bin_name))
    for user_path in local_users_profiles():
        # Uninstall silently
        if isfile(makepath(user_path, r'\AppData\Local\Postman', r'Update.exe')):
            run_notfatal(r'"%s" --uninstall -s' % makepath(user_path, r'\AppData\Local\Postman', r'Update.exe'))
            time.sleep(2)
        # Remove local appdata dir
        if isdir(makepath(user_path, r'\AppData\Local\Postman')):
            remove_tree(makepath(user_path, r'\AppData\Local\Postman'))
    remove_tree(setup_path)
def session_setup():
    run(r'"%s" -s' % makepath(setup_path, bin_name))
    time.sleep(5)
    for i in range(30):
        if not isfile(makepath(user_local_appdata, r'\Postman\Update.exe')):
            time.sleep(5)
            break
def update_package():
    url = r'https://dl.pstmn.io/download/latest/win64'
    wget(url, bin_name)
    version_from_file = get_version_from_binary(bin_name)
    version_from_package = control.version.split('-')[0]
    if Version(version_from_file) > Version(version_from_package):
        print(r'Latest Postman version is %s' % version_from_file)
        control.version = '%s-%s' % (version_from_file, control.version.split('-', 1)[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        print(r'Already up to date !')
Per macOS:
zip_name = r'Postman-MacOS-arm64.zip'
app_name = r'Postman.app'
    run(r'unzip -qq %s %s/*' % (zip_name, app_name))
    install_app(app_name)
    uninstall_app(app_name)
    import plistlib
    if isdir(app_name):
        remove_tree(app_name)
    url = r'https://dl.pstmn.io/download/latest/osx_arm64'
    wget(url, zip_name)
    unzip(zip_name, target=r'', filenames=r'%s/*' % app_name)
    plist_file = plistlib.readPlist(r'%s/Contents/Info.plist' % app_name)
    version_from_plist = plist_file[r'CFBundleShortVersionString']
    if Version(version_from_plist) > Version(version_from_package):
        print(r'Latest Postman version is %s' % version_from_plist)
        control.version = '%s-%s' % (version_from_plist, control.version.split('-', 1)[-1])
6 novembre 2024 - 12:00
Ciao Bastien,
grazie per la condivisione. Sembra un ottimo software; penso che lo useremo anche internamente. :-)
fschelfaut
Registrazione: 7 nov 2024 - 12:22
8 novembre 2024 - 15:26
Ciao Bastien,
abbiamo creato i pacchetti di Postman per Windows e macOS. Sono attualmente disponibili nel repository PREPROD e saranno accessibili sullo store tra 5 giorni.
Ecco i link alle build PREPROD:
- Windows x64
- macOS Intel
- macOS ARM
Flavien
bastien30
8 novembre 2024 - 16:43
ottimo! Aspetterò che sia disponibile nel repository stabile prima di provarlo e probabilmente sostituirò i miei pacchetti con i tuoi :D
. Grazie.
bastien30
17 dicembre 2024 - 12:27
fschelfaut ha scritto: ↑8 novembre 2024 - 15:26 Ciao Bastien,
abbiamo creato i pacchetti di Postman per Windows e macOS. Attualmente è disponibile nel repository PREPROD e sarà accessibile nello store tra 5 giorni.
- Windows x64
- macOS Intel
- macOS arm
Flavien
Ho scaricato i tuoi pacchetti invece dei miei perché sono più puliti (installazione nei file di programma).
Tuttavia, ho notato un piccolo problema dopo l'aggiornamento di un pacchetto: su Windows, il programma si avvia e si chiude dopo pochi secondi.
Dopo un'indagine, è emerso che il problema era dovuto al file AppData\Roaming\Postman\storage\settings.json, in cui è presente un parametro "lastKnownVersion" che ha il valore della versione installata in precedenza.
Se aggiorniamo il valore con la nuova versione, il programma si avvia normalmente.
Sarebbe possibile aggiungere questa modifica al pacchetto, per favore?
Ritengo quindi che sarebbe necessario farlo per tutti gli utenti.
Grazie in anticipo.
fschelfaut
20 dicembre 2024 - 10:05
Ciao Bastien,
grazie per il tuo feedback! In effetti, non avevo considerato quel file.
Ho quindi adattato il codice in modo che settings.json venga aggiornato automaticamente (session-setup).
Puoi trovare il pacchetto in PREPROD qui.
Fammi sapere se questo risolve il tuo problema.
Flavien,
bastien30
20 dicembre 2024 - 17:11
Grazie mille! :)
bastien30
26 dicembre 2024 - 17:11
ho appena aggiornato Postman e ora funziona tutto perfettamente :D
. Grazie!
