[RISOLTO] Pacchetto per EdrawMax
bastien30
Registrazione: 8 marzo 2024 - 15:21
13 dicembre 2024 - 13:25
Ho creato un pacchetto per il software Wondershare EdrawMax, con update_package() funzionante.
Ho visto che avevi un pacchetto per EdrawMind, ma a quanto pare stai recuperando il programma di installazione dal tuo repository (problemi di licenza?).
setup.py:
from setupdevhelpers import *
from os import rename
    appver = control.get_software_version()
    appname = control.name
    install_exe_if_needed(r'edrawmax_%s.exe' % appver, silentflags=r'/VERYSILENT /NORESTART /ACCEPTEULA', min_version=appver, name=appname)
    remove_desktop_shortcut(appname)
def session_setup():
    remove_user_desktop_shortcut(appname)
def update_package():
    url = control.sources
    for col in bs_find_all(url, "div", "class", "m-3"):
        if "EdrawMax for Windows" in col.text:
            for release in bs_find_all(col, "div", "class", "font-size-small"):
                if "what's new" in release.text:
                    latest_version = release.text.strip().split("(")[0]
                    break
            for release_link in bs_find_all(col, "div", "class"):
                if "Have trouble" in release_link.text:
                    latest_release_link = bs_find(release_link, "a", "href")
                    if latest_release_link["href"].endswith(".exe"):
                        if r"64bit" in latest_release_link["href"]:
                            latest_url = latest_release_link["href"]
                            break
        if latest_version and latest_url:
            break
    if not latest_version:
        error(r'Error fetching latest version from website !')
    elif not latest_url:
        error(r'Error fetching latest download link from website !')
        print(r'Latest version : %s' % latest_version)
        print(r'Latest url : %s' % latest_url)
    if Version(latest_version, 3) > Version(appver, 3):
        installer = r'edrawmax_latest.exe'
        installer_version = r'edrawmax_%s.exe'
        wget(latest_url, installer)
        # Get full version from binary
        bin_version = get_version_from_binary(installer)
        if Version(bin_version, 3) != Version(latest_version, 3):
            error(r'Error : binary version and website version are not the same !')
            # Renaming installer with full version
            os.rename(installer, installer_version % bin_version)
            control.version = '%s-%s'%(bin_version, control.version.split('-')[-1])
            print('Changing version to: %s in WAPT\\control' % control.version)
            remove_outdated_binaries(bin_version)
        print("Already up to date")
controllare:
package           : xxx-edrawmax
version           : 14.1.0.1212-5
architecture      : x64
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : Edraw Max est un logiciel de diagramme d'affaires et technique en 2D qui aide à créer des diagrammes de flux, des organigrammes, des cartes mentales, des diagrammes de réseau, des plans d'étage, des diagrammes de flux de travail, des graphiques d'affaires et des diagrammes d'ingénierie
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : windows
min_wapt_version  :
sources           : https://www.edrawsoft.com/download-edrawmax.html
installed_size    :
impacted_process  : EdrawMax,EdrawMaxTray
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : EdrawSoft Co.,Ltd.
keywords          :
licence           : proprietary_restricted
homepage          : https://edrawmax.wondershare.com/
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://www.edrawsoft.com/whats-new/edrawmax.html
min_os_version    :
max_os_version    :
italbot
Registrazione: 26 settembre 2023 - 15:50
17 dicembre 2024 - 14:29
grazie per la condivisione e ottima osservazione sul pacchetto EdrawMind; ho appena modificato la funzione update_package() per quel pacchetto.
Ingrid
Tranquillo IT
