[RISOLTO] Pacchetto per Winmail Opener
bastien30
Registrazione: 8 marzo 2024 - 15:21
16 dicembre 2024 - 10:33
Ecco un pacchetto per il software Winmail Opener (per aprire i file winmail.dat).
setup.py:
    appver = control.get_software_version()
    appname = control.name
    install_exe_if_needed(r'winmail_opener.exe', silentflags=r'/S', key=appname, min_version=appver)
    remove_desktop_shortcut(appname)
    remove_user_desktop_shortcut(appname)
def session_setup():
def update_package():
    url_dl = control.sources
    binary = r'winmail_opener.exe'
    # Download latest binary to check version
    wget(url_dl, binary)
    latest_version = get_version_from_binary(binary)
    if Version(latest_version, 2) > Version(appver, 2):
        print(r'Latest version is %s' % latest_version)
        control.version = '%s-%s'%(latest_version, control.version.split('-')[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        print("Already up to date")
controllare:
package           : xxx-winmail_opener
version           : 1.7-0
architecture      : all
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : Winmail Opener is a small and simple utility that allows you to view and extract the contents of winmail.dat files sent by Outlook
depends           :
conflicts         :
maturity          : PROD
locale            :
target_os         : all
min_wapt_version  :
sources           : https://www.eolsoft.com/get/wmo
installed_size    :
impacted_process  :
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : Eolsoft
keywords          :
licence           : proprietary_free
homepage          : https://www.eolsoft.com/freeware/winmail_opener/
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://www.eolsoft.com/freeware/winmail_opener/whatsnew.htm
min_os_version    :
max_os_version    :
19 dicembre 2024 - 14:23
Grazie Bastien :-)
