[RISOLTO] Problema dall'aggiornamento 2.6.0.16881
TomTom
Registrazione: 25 maggio 2018 - 15:43
4 febbraio 2025 - 9:06
Ciao a tutti,
Da questa mattina ho notato un'attività anomala della CPU sui miei computer Linux (ubuntu/debian).
Ho appena notato che durante la notte hanno installato l'ultimo aggiornamento WAPT 2.6.0.16881, il che sembra influire sul funzionamento dell'agente.
Ho allegato degli screenshot dell'utilizzo prima e dopo l'interruzione del servizio Wapt; la differenza è evidente. È incluso anche uno screenshot dello stato nella console.
Quando provo a eseguire un aggiornamento wapt-get sui computer, ecco l'output:
Using config file: /opt/wapt/wapt-get.ini
Nothing to upgrade
2025-02-04 08:58:46,341 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:49,342 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:51,664 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:54,749 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:57,502 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:01,060 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:03,257 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:05,931 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:08,402 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:11,145 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:13,385 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:15,909 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
Grazie per il tuo aiuto, il mio server sta iniziando a sovraccaricarsi :rotolo:
Tommaso
Allegati
Ultima modifica da TomTom il 04 feb 2025 - 11:32, modificato 1 volta.
Versione WAPT: 2.6.0.17392 (Enterprise Edition)
Sistema operativo del server: Debian 12 "Bookworm"
Sistema operativo della macchina di amministrazione/creazione pacchetti: Windows 11 24h2
4 febbraio 2025 - 9:18
Se il server non è stato aggiornato alla stessa versione, questo potrebbe essere la causa del problema.
Abbiamo avuto un problema con un cliente i cui computer in Active Directory avevano un nome diverso dal nome host.
Quindi ora effettuiamo la corrispondenza (per determinare se un computer è stato clonato, ad esempio, o eliminato e deve essere registrato nuovamente) basandoci solo sul nome host.
Sfortunatamente, il server con la versione precedente non restituisce questo computer_name e quindi il computer si registra nuovamente (correttamente) in un ciclo infinito.
Hai aggiornato il server?
Tranquillo IT
TomTom
4 febbraio 2025 - 9:20
No, non ancora, non volevo causare altri problemi. Farò uno snapshot e proverò l'aggiornamento per vedere se, come dici, il problema potrebbe dipendere da quello.
Ti ricontatterò non appena avrò maggiori informazioni.
Grazie per la rapida risposta, Hubert.
Ultima modifica da TomTom il 04 feb 2025 - 11:54, modificato 1 volta.
TomTom
4 febbraio 2025 - 10:29
In effetti, il problema derivava dalla differenza di versione tra client e server.
Possiamo ora chiudere questo problema; tutto è tornato alla normalità.
Grazie ancora, Hubert, per la spiegazione.
