[RISOLTO] Problema con il certificato di deposito secondario dall'aggiornamento 2.6
djfb1
Iscrizioni: 7 febbraio 2025 - ore 8:57
7 febbraio 2025 - 9:47
Dall'aggiornamento dalla versione 2.5 alla 2.6, ricevo un errore durante l'installazione di pacchetti sui miei PC o server in siti remoti.
In questi siti sono installati impianti di stoccaggio secondari.
Ecco il messaggio di errore sulla console:
Erreur lors de l'installation de ['srv-bureautique.domain.local(=7)']: erreurs dans les paquets [[('https://srv-wapt.domain.local/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]'), None]
E il messaggio di errore sul server dove sto provando a installare il pacchetto 7zip:
2025-02-07 09:22:03,966 [waptcore WaptTaskManager 5200] CRITICAL Error downloading package from http repository, please update... error : THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]
2025-02-07 09:22:03,966 [waptcore WaptTaskManager 5200] CRITICAL Error downloading some files : [('https://srv-secondaire.domain.local/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]')]
2025-02-07 09:22:03,966 [waptcore WaptTaskManager 5200] CRITICAL Package ltm-7zip [x64_fr_PROD] not installed due to errors : EWaptDownloadError: Package file ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt not downloaded properly.
Erreur lors de l'installation de ['ltm-7zip']: erreurs dans les paquets [[('https://srv-secondaire.domain.local.ltm.bzh/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]'), None], [PackageRequest(package='ltm-7zip',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-2012serverr2', 'win-2012serverr2', 'w-2012serverr2', 'windows2012serverr2', 'win2012serverr2', 'w2012serverr2', 'windows', 'win', 'w'],min_os_version=Version('6.3.9600'),max_os_version=Version('6.3.9600')), PackageEntry('ltm-7zip','24.9-46' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5471, in install\n    raise EWaptDownloadError(\'Package file %s not downloaded properly.\' % p.filename)\nwaptpackage.EWaptDownloadError: Package file ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt not downloaded properly.\n']]
2025-02-07 09:22:03,966 [wapttasks WaptTaskManager 5200] CRITICAL Task error Installation de ltm-7zip (tâche #78): Exception: Erreur lors de l'installation de ['ltm-7zip']: erreurs dans les paquets [[('https://srv-secondaire.domain.local/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]'), None], [PackageRequest(package='ltm-7zip',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-2012serverr2', 'win-2012serverr2', 'w-2012serverr2', 'windows2012serverr2', 'win2012serverr2', 'w2012serverr2', 'windows', 'win', 'w'],min_os_version=Version('6.3.9600'),max_os_version=Version('6.3.9600')), PackageEntry('ltm-7zip','24.9-46' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5471, in install\n    raise EWaptDownloadError(\'Package file %s not downloaded properly.\' % p.filename)\nwaptpackage.EWaptDownloadError: Package file ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt not downloaded properly.\n']]
Grazie per l'aiuto.
Server Linux Debian (2.6)
Repository secondari Linux Debian (2.6) (secondary-srv)
Console installata sul server 2022
Ultima modifica di djfb1 il 07 feb 2025 - 11:33, modificato 1 volta.
7 febbraio 2025 - 11:16
Ciao Farid,
sembra che il repository secondario sia configurato per HTTPS, ma il certificato non viene riconosciuto. Se disponi di un'autorità di certificazione interna, potresti aggiungere certificati HTTPS riconosciuti dagli agenti? Per fare una prova, potresti configurare il repository remoto per HTTP anziché HTTPS? (Dal punto di vista della sicurezza, l'agente convalida tutti i download a livello di firma, quindi avere i repository secondari in HTTP non è un problema rilevante.)
djfb1
7 febbraio 2025 - 11:30
Ciao Denis,
sì, funziona tramite HTTP.
Non utilizziamo un'autorità di certificazione interna.
Lascerò tutto così com'è.
Grazie.
7 febbraio 2025 - 11:40
Ciao di nuovo Farid,
grazie per il feedback, :-) contrassegno la discussione come RISOLTA.
