Versione WAPTWUA 2.6.0.17177
guigeek
Registrazione: 21 novembre 2017 - 21:21
10 aprile 2025 - 08:39
Buongiorno !
Ho installato la nuova versione 2.6.0.17177.
Da questa mattina è stato rilasciato l'aggiornamento 2025-04 di Windows 11 e sto provando a installarlo, ma ricevo il seguente errore:
Done searching
Updates scan done.
Merging installation history into scan results.
Writing status in local wapt DB
Updating workstation status on remote wapt server
- Get downloads for update 1248d549-d317-493f-a1db-f79fc8c0db48_100
Download Update 1248d549-d317-493f-a1db-f79fc8c0db48_100
Downloading windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu
Downloading windows11.0-kb5043080-x64_953449672073f8fb99badb4cc6d5d7849b9c83e8.msu
Run dism command: "C:\WINDOWS\system32\dism.exe" /Online /Quiet /NoRestart /Add-Package /PackagePath:"C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu"
MSU KbFile installed C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5043080-x64_953449672073f8fb99badb4cc6d5d7849b9c83e8.msu with code 3010
Count of Updates to Install: 0
Count of actually installed Updates : 1
ERROR install update: Invalid floating point operation
Status:            ERROR, 1 pending, 6 discarded
Installed updates: 3
Pending updates:   1
Discarded updates: 6
Reboot required:
Last install date:   4/10/2025 8:34:49
Last install result:
WSUSScan cab date:   4/10/2025 5:10:32
sfontenau
10 aprile 2025 - 09:38
guigeek ha scritto: 10 aprile 2025 - 08:39 Esegui il comando dism: "C:\WINDOWS\system32\dism.exe" /Online /Quiet /NoRestart /Add-Package /PackagePath:"C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu"
MSU KbFile installato C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5043080-x64_953449672073f8fb99badb4cc6d5d7849b9c83e8.msu con codice 3010
ERRORE durante l'aggiornamento dell'installazione: Operazione in virgola mobile non valida
Da quello che posso vedere, l'installazione ha funzionato, ma quando si richiede una nuova scansione di WUA per verificare lo stato dell'aggiornamento, il motore restituisce "Operazione in virgola mobile non valida"
La macchina dovrebbe essere qui in attesa di riavvio... le installazioni sono in corso, esegui un'altra scansione per vedere?
guigeek
10 aprile 2025 - 09:47
Eseguire una nuova scansione dopo un riavvio funziona, ma non ho mai riscontrato lo stato PENDING_REBOOT.
Tuttavia, ho dovuto eseguire l'installazione due volte perché la prima volta ho ricevuto il seguente errore:
Download di windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu
Download di windows11.0-kb5043080-x64_953449672073f8fb99badb4cc6d5d7849b9c83e8.msu
ERRORE 1 File mancanti per l'aggiornamento 1248d549-d317-493f-a1db-f79fc8c0db48_100 : http://dl.delivery.mp.microsoft.com/fil ... 996157.msu
Numero di aggiornamenti da installare: 0
Numero di aggiornamenti effettivamente installati: 0
Aggiornamento dello stato della workstation sul remoto
: ERRORE, 1 in sospeso, 2 scartati.
Non so se questo possa essere d'aiuto.
Grazie
guigeek
10 aprile 2025 - 09:48
Stesso tipo di errore con Windows 10: Ricerca aggiornamenti completata. Scansione aggiornamenti completata. Unione della cronologia di installazione nei risultati della scansione. Aggiornamento dello stato della workstation sul server wapt remoto Download di windows10.0-kb5055518-x64_941409af9ab0c70606d3fd1e39e5be67ecae40d3.cab ERRORE 1 File mancanti per l'aggiornamento 4861ab0d-9efc-46df-98a2-4aa7cb703e34_200: http://download.windowsupdate.com/d/msd ... ae40d3.cab Numero di aggiornamenti da installare: 0 Numero di aggiornamenti effettivamente installati: 0 Aggiornamento dello stato della workstation sul server wapt remoto Stato: ERRORE, 1 in sospeso, 1 scartato Aggiornamenti installati: 6 Aggiornamenti in sospeso: 1 Aggiornamenti scartati: 1 Riavvio richiesto: è necessario riavviare una seconda volta affinché sembri funzionare
sfontenau
10 aprile 2025 - 09:56
ERRORE 1 La mancanza di file per l'aggiornamento è "normale".
Infatti, durante la scansione, l'aggiornamento KB passa allo stato "in sospeso". Ogni 30 minuti, il server scarica i file CAB mancanti.
Tuttavia, se il computer è il primo a visualizzare questo file CAB come "in sospeso", non sarà in grado di scaricarlo dal server perché quest'ultimo non ha avuto il tempo di scaricare il file KB.
In precedenza, in questo caso il computer rimaneva nello stato "in sospeso"; ora lo segnaliamo come "errore" perché è più logico.
guigeek
10 aprile 2025 - 10:01
Ah, ok, ora capisco meglio.
Quindi, in effetti, se eseguo una nuova scansione subito dopo l'installazione, lo stato passa a PENDING_REBOOT.
Comunque, lo stato "SCANNING" è ottimo!
guigeek
10 aprile 2025 - 10:22
sfonteneau ha scritto: 10 aprile 2025 - 09:56 ERRORE 1 La mancanza di file per l'aggiornamento è "normale"
. In realtà, durante la scansione, il KB passa allo stato "in sospeso". E ogni 30 minuti, il server scarica i CAB mancanti.
Ma se la macchina è la prima ad avere questo CAB nello stato "in sospeso", non sarà in grado di scaricare il CAB dal server perché il server non ha avuto il tempo di scaricare il KB.
Prima, in questo caso la macchina rimaneva nello stato "in sospeso"; ora lo segnaliamo come "errore" perché è più logico.
È strano perché continua a succedere a me per tutti, anche se il taxi è già stato scaricato sulla prima macchina, già aggiornata
guigeek
10 aprile 2025 - 10:27
guigeek ha scritto: 10 aprile 2025 - 10:22
Oh no, mi dispiace, l'errore era di nuovo la virgola mobile non valida
guigeek
11 aprile 2025 - 08:37
Ciao di nuovo,
dopo aver provato di tutto, continuo ad avere il problema (solo su Windows 11) per cui l'aggiornamento KB rimane in stato "IN SOSPESO" anche se è installato correttamente.
E come con gli aggiornamenti precedenti, non succede su tutti i computer.
Nei miei test, si verifica su 20 macchine su 89.
Questa casualità è molto strana.
Grazie per il tuo feedback
jlepiquet
Registrazione: 3 settembre 2024 - 16:09
11 aprile 2025 - 8:50
avete eseguito un'altra scansione dopo aver riavviato le macchine?
Risposta
