Versione dell'agente: 2.6.0.17293 (Windows 11 Pro)
Ho uno strano problema che riguarda solo una macchina nella nostra rete: dalla console, non sono visibili pacchetti nella scheda generale della macchina.
L'agente WAPT sembra considerare correttamente i pacchetti da installare quando guardo direttamente sulla macchina.
Ho anche questo errore nei log waptservice sulla macchina in questione (per contestualizzare, il mio server WAPT è accessibile tramite la porta 8443 e non 443):
2025-06-25 13:12:06,929 [wapttasks WaptTaskManager 13444] INFO Reloading waptcore configuration for Wapt instance thread 13444
2025-06-25 13:12:06,945 [wapttasks WaptTaskManager 13444] INFO Core Wapt config file has changed, reloaded. Reloading waptservice config too
2025-06-25 13:12:06,993 [wapttasks SocketIOClient 4784] INFO Connecting Socketio to https://wapt.int.mondomaine.fr:8443
2025-06-25 13:12:07,057 [wapttasks SocketIOClient 4784] INFO WS read loop for 120s
2025-06-25 13:12:28,051 [wapttasks WaptTaskManager 13444] INFO Add task Mise jour de la liste des paquets disponibles to queue
2025-06-25 13:12:28,062 [wapttasks WaptTaskManager 13444] INFO Running task "Mise jour de la liste des paquets disponibles" created by "SCHEDULER"
R cup ration de la liste des paquets depuis [<WaptRepo https://wapt.int.mondomaine.fr:8443/wapt verify_cert=C:\Program Files (x86)\wapt\ssl\server\wapt.int.mondomaine.fr.crt client_cert_path=C:\Program Files (x86)\wapt\private\pcportable12.mondomaine.local.crt>, <WaptHostRepo https://wapt.int.mondomaine.fr:8443/wapt-host for host_id pcportable12.mondomaine.local >]
Disabling Windows auto update service, using WaptWUA instead
2025-06-25 13:12:29,332 [wapttasks WaptTaskManager 13444] INFO update_server_status successful (data size:2978, keys:dict_keys(['uuid', 'computer_fqdn', 'computer_name', 'host_capabilities', 'host_metrics', 'last_update_status', 'status_hashes']))
2025-06-25 13:12:47,878 [wapttasks CP Server Thread-7 1180] INFO Add task Mise jour de la liste des paquets disponibles to queue
2025-06-25 13:12:47,878 [wapttasks WaptTaskManager 13444] INFO Running task "Mise jour de la liste des paquets disponibles" created by "administrateur"
2025-06-25 13:12:48,517 [wapttasks CP Server Thread-9 2308] INFO Add task Installation des icones pour 56 paquets (t che #-1) to queue
2025-06-25 13:12:49,119 [wapttasks WaptTaskManager 13444] INFO Running task "Installation des icones pour 56 paquets (t che #4)" created by "administrateur"
-> download finished (46.58Kb/s)
-> download finished (83.57Kb/s)
socket.error 5
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\server.py", line 1291, in communicate
req.respond()
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\server.py", line 1081, in respond
self.server.gateway(self).respond()
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\wsgi.py", line 141, in respond
self.write(chunk)
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\wsgi.py", line 223, in write
self.req.write(chunk)
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\server.py", line 1137, in write
self.conn.wfile.write(chunk)
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\makefile.py", line 68, in write
res = super().write(val, *args, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\makefile.py", line 24, in write
self._flush_unlocked()
File "C:\Program Files (x86)\wapt\lib\site-packages\cheroot\makefile.py", line 33, in _flush_unlocked
n = self.raw.write(bytes(self._write_buf))
File "socket.py", line 734, in write
File "ssl.py", line 1207, in send
ssl.SSLError: [SYS] unknown error (_ssl.c:2501)
socket.error 5
req.respond()
self.write(chunk)
