Sto provando a installare il pacchetto GLPI (agente) per macOS Intel/x64
(MacOS 15.5)
Durante l'installazione ricevo questo errore:
File "/opt/wapt/common.py", line 4454, in install_wapt
File "/tmp/wapte_3q4feu/setup.py", line 7, in install
File "/opt/wapt/setuphelpers_macos.py", line 619, in installed_softwares
pkg = get_pkg_info(pkgentry)
File "/opt/wapt/setuphelpers_macos.py", line 313, in get_pkg_info
pkginfo_str = run('pkgutil --pkg-info-plist {0}'.format(pkg_id))
File "/opt/wapt/waptutils.py", line 2263, in run
waptutils.CalledProcessErrorOutput: Command b'pkgutil --pkg-info-plist com.plogue.ARIA Player.ARIA Playerau.pkg' returned non-zero exit status 1.
Output:No receipt for 'com.plogue.ARIA' found at '/'.
Output:No receipt for 'com.plogue.ARIA' found at '/'.Nessun problema invece con il pacchetto "arm".
