[RISOLTO] Pacchetto per EdrawMax - Aggiornato 08/2025
bastien30
Registrazione: 8 marzo 2024 - 15:21
7 agosto 2025 - 12:55
Ho condiviso un pacco per il software Wondershare EdrawMax ma il pacchetto di aggiornamento non funziona più perché hanno cambiato sito.
Ecco una nuova versione che funziona.
setup.py:
from setupdevhelpers import *
from os import rename
    appver = control.get_software_version()
    appname = control.name
    install_exe_if_needed(r'edrawmax_%s.exe' % appver, silentflags=r'/VERYSILENT /NORESTART /ACCEPTEULA', min_version=appver, name=appname)
    remove_desktop_shortcut(appname)
def session_setup():
    remove_user_desktop_shortcut(appname)
def update_package():
    url = control.changelog
    latest_version = None
    for col in bs_find_all(url, "h2", "class", "mb-3"):
        if "Windows" in col.text:
            latest_version = col.text.split("Windows V")[1].split(" ")[0]
            break
    if not latest_version:
        error(r'Error fetching latest version from website !')
        # Installers for all versions are availables here: https://support.wondershare.com/how-tos/wondershare/product-download.html
        # It seems all installers contains "full5371" in file name
        latest_url = r'https://download.edrawsoft.com/cbs_down/edraw-max_64bit_%s_full5371.exe' % latest_version
        print(r'Latest version : %s' % latest_version)
        print(r'Latest url : %s' % latest_url)
    if Version(latest_version, 3) > Version(appver, 3):
        installer = r'edrawmax_latest.exe'
        installer_version = r'edrawmax_%s.exe'
        wget(latest_url, installer)
        # Get full version from binary
        bin_version = get_version_from_binary(installer)
        if Version(bin_version, 3) != Version(latest_version, 3):
            error(r'Error : binary version and website version are not the same !')
            # Renaming installer with full version
            os.rename(installer, installer_version % bin_version)
            control.version = '%s-%s'%(bin_version, control.version.split('-')[-1])
            print('Changing version to: %s in WAPT\\control' % control.version)
            remove_outdated_binaries(bin_version)
        print("Already up to date")
controllare:
package           : xxx-edraw_max
version           : 14.5.4.1333-104
architecture      : x64
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : Edraw Max est un logiciel de diagramme d'affaires et technique en 2D qui aide à créer des diagrammes de flux, des organigrammes, des cartes mentales, des diagrammes de réseau, des plans d'étage, des diagrammes de flux de travail, des graphiques d'affaires et des diagrammes d'ingénierie.
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : windows
min_wapt_version  :
sources           : https://www.edrawsoft.com/download-edrawmax.html
installed_size    :
impacted_process  : EdrawMax,EdrawMaxTray
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : EdrawSoft Co.,Ltd.
keywords          :
licence           : proprietary_restricted
homepage          : https://edrawmax.wondershare.com/
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://edrawmax.wondershare.com/whats-new.html
min_os_version    :
max_os_version    :
italbot
Registrazione: 26 settembre 2023 - 15:50
7 agosto 2025 - 15:49
da parte nostra, l'update_package è già stato modificato ed è funzionante, ma l'installazione non è più silenziosa, motivo per cui il pacchetto non risulta aggiornato nello store. Se disponete di informazioni che potrebbero aiutarci a risolvere questo problema, vi preghiamo di comunicarcelo. Grazie.
Ingrid
Tranquillo IT
bastien30
7 agosto 2025 - 16:16
da parte mia l'installazione procede senza intoppi, l'ho distribuita su diverse macchine oggi...
E non ho modificato i parametri della riga di comando che erano già presenti nel pacchetto precedente.
italbot
7 agosto 2025 - 17:25
Strano, da parte nostra, sia come amministratore che come account di sistema, l'installazione fallisce perché non procede in modalità silenziosa; compare una finestra di dialogo che chiede conferma. E su Luti, l'installazione va in timeout.
Avete eseguito le installazioni utilizzando i pacchetti wapt nella console?
Ingrid
Tranquillo IT
bastien30
7 agosto 2025 - 17:37
Ho appena installato con successo il pacchetto WAPT tramite riga di comando (utente amministratore) e console (utente di sistema).
Entrambi i metodi hanno funzionato senza problemi.
Hai scaricato il programma di installazione offline completo? A prima vista sembra che tu stia usando il programma di installazione online.
Guarda la variabile latest_url nel mio pacchetto qui sopra.
italbot
8 agosto 2025 - 10:22
sì, non stavamo scaricando il file binario corretto, grazie per la segnalazione :)
. Le modifiche sono state apportate e il pacchetto verrà aggiornato.
Buona giornata.
Ingrid
Tranquillo IT
