[RISOLTO] Problema con l'app Microsoft Store e il modello di condivisione rapida
Vincent38
Registrazione: 22 maggio 2023 - 12:13
26 settembre 2025 - 12:39
Buongiorno
Ho un problema con il pacchetto "template microsoft store app", che sembra non funzionare per generare il pacchetto con l'app di condivisione rapida.
Funziona con altri software, ma con QuickShare ottengo questo:
Retrieving informations from Microsoft Store API, please wait
Downloading: SAMSUNGELECTRONICSCoLtd.SamsungQuickShare_2.2.19.0_neutral___wyx1vj98g3asy_17cba7b8-16ac-49e2-aa9e-429b732b4bdd.msixbundle
CRITICAL:waptcore:Fatal error in update_package  None : None:
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 534, in _make_request
    response = conn.getresponse()
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 565, in getresponse
    httplib_response = super().getresponse()
  File "http\client.py", line 1375, in getresponse
  File "http\client.py", line 318, in begin
  File "http\client.py", line 279, in _read_status
  File "socket.py", line 717, in readinto
TimeoutError: timed out
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 644, in send
    resp = conn.urlopen(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 841, in urlopen
    retries = retries.increment(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 474, in increment
    raise reraise(type(error), error, _stacktrace)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\util.py", line 39, in reraise
    raise value
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 787, in urlopen
    response = self._make_request(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 536, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 367, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='tlu.dl.delivery.mp.microsoft.com', port=80): Read timed out. (read timeout=10)
  File "C:\Program Files (x86)\wapt\common.py", line 9036, in call_python_code
    hookdata = hook_func()
  File "C:\Users\vmorey\AppData\Local\Temp\wapt\MKDEGI_9\domoprod-template-microsoft-store-app_0-77_windows_10.0_PROD-wapt\update_package.py", line 109, in update_package
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1139, in wget
    httpreq = session.get(url,
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 602, in get
    return self.request("GET", url, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 690, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='tlu.dl.delivery.mp.microsoft.com', port=80): Read timed out. (read timeout=10)
    raise value
  File "C:\Program Files (x86)\wapt\common.py", line 9040, in call_python_code
    raise e
Hai idea di cosa sta succedendo?
GRAZIE
Comandante
WAPT 2.6.1.17472
Server Debian 12
Macchina di creazione Win 11 24h2 (26100.4349)
jlepiquet
Registrazione: 3 settembre 2024 - 16:09
29 settembre 2025 - 09:35
Ciao Vincent,
sembra esserci un problema di timeout con i link per il download.
Ho effettuato un test da parte nostra e funziona, quindi potrebbe esserci un blocco dell'URL da parte tua, oppure un problema di temporizzazione durante il download.
Per favore, riprova e facci sapere.
Joffrey
Vincent38
30 settembre 2025 - 13:45
Salve
, sì, sembra esserci qualcosa che lo blocca da parte nostra. Il download da Microsoft è strano; ci sto lavorando con WatchGuard.
Cordiali saluti
30 settembre 2025 - 16:18
Ciao Vincent,
grazie per il feedback :-) , contrassegno la discussione come risolta.
