Errore jQuery di PostgreSQL nei log di PostgreSQL
Risposta
Mikael S
Registrazione: 20 gennaio 2025 - 15:54
3 ottobre 2025 - 8:11
Nei registri del database, mi sono imbattuto in questo
2025-10-02 23:59:27.817 CEST [1202] LOG:  starting PostgreSQL 15.14 (Debian 15.14-0+deb12u1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv6 address "::1", port 5432
2025-10-02 23:59:27.822 CEST [1202] LOG:  listening on IPv4 address "127.0.0.1", port 5432
2025-10-02 23:59:27.824 CEST [1202] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-10-02 23:59:27.856 CEST [1224] LOG:  database system was shut down at 2025-10-02 23:59:02 CEST
2025-10-02 23:59:27.888 CEST [1202] LOG:  database system is ready to accept connections
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt ERROR:  extension "jsquery" is not available
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt DETAIL:  Could not open extension control file "/usr/share/postgresql/15/extension/jsquery.control": No such file or directory.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt HINT:  The extension must first be installed on the system where PostgreSQL is running.
2025-10-02 23:59:30.866 CEST [1794] wapt@wapt STATEMENT:  CREATE EXTENSION if not exists jsquery;
2025-10-02 23:59:30.867 CEST [1794] wapt@wapt WARNING:  there is no transaction in progress
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt LOG:  could not send data to client: Broken pipe
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt STATEMENT:  COPY public.hostauditdata (id, host_id, value_id, value_date, value_section, value_key, value, expiration_date, created_on, created_by) TO stdout;
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt ERROR:  canceling statement due to user request
2025-10-03 00:02:58.370 CEST [2675] postgres@wapt FATAL:  connection to client lost
Non menzioni la necessità di installare il pacchetto postgresql-15-jsquery su bookworm nel wiki. O forse è su una pagina diversa da https://www.wapt.fr/en/doc/wapt-server- ... ehm-install
Sinceramente,
3 ottobre 2025 - 11:04
Ciao Mickael,
l'estensione jQuery non è più necessaria per WAPT. Inoltre, durante una nuova installazione, lo script postconf la installa solo se è presente sul sistema. È vero, però, che può causare problemi in caso di ripristino da un backup o di reinstallazione del server. Questa estensione può essere utilizzata nelle query SQL/JSON.
Verificherò con il team se possiamo reinserirla nella documentazione durante l'installazione o se riusciamo a trovare un modo migliore per gestirla durante un aggiornamento.
Risposta
