Richiesta di pacchetti per il software Icy
Risposta
Aramis
Registrazione: 16 luglio 2024 - 11:48
Posizione: Lille
15 ottobre 2025 - 15:40
la comunità scientifica fa ampio uso del software Icy.
https://icy.bioimageanalysis.org/
Sarebbe utile avere una versione di questo software disponibile per Windows, Linux e Mac.
blemoigne
Registrazione: 17 luglio 2020 - 11:29
16 ottobre 2025 - 12:34
Ciao di nuovo,
Questo software presenta lo stesso problema operativo, non rispettando le migliori pratiche di sicurezza in un ambiente professionale. Abbiamo inviato questo messaggio all'editore del software sul suo forum:
Subject: Installation path recommendation – conflict with security best practices
Dear Support Team,
I hope this message finds you well.
While reviewing your installation documentation, I noticed that you recommend not installing your software in the “Program Files” directory due to potential permission issues.
However, according to security best practices and government cybersecurity agencies — such as ANSSI (the French National Cybersecurity Agency) and similar organizations like NIST (U.S. National Institute of Standards and Technology) and ENISA (European Union Agency for Cybersecurity) — it is strongly recommended that applications be installed in system-protected directories such as Program Files.
In professional environments, execution of binaries is restricted to trusted paths (e.g. C:\Program Files and C:\Program Files (x86)) to prevent the execution of untrusted or potentially malicious code.
This policy is commonly enforced through application whitelisting and endpoint security controls, which are standard practice in enterprise and government environments.
Would it be possible for you to review your installation process or adjust your software so that it can safely run from within Program Files while maintaining proper permission handling ?
This change would greatly facilitate deployment in secured and compliant environments.
Thank you for your attention, and please let me know if you would like more details about these compliance requirements.
Kind regards,
Vedremo se riusciamo ancora a farlo funzionare nei file di programma.
Distinti saluti,
Bertrand
Aramis
Posizione: Lille
21 ottobre 2025 - 13:35
grazie. Questa è sicuramente una cattiva abitudine che si è diffusa in questa comunità. ;)
Julien
vcardon
Posizione: Nantes, Francia
21 ottobre 2025 - 19:17
Ciao Julien,
quando parli di "questa comunità", intendi la comunità degli editori di software scientifico?
In tal caso, conosci il sito https://www.eprist.fr/qui-sommes-nous/ ? Potresti metterci in contatto con qualcuno di questa associazione in modo che possiamo chiarire questa situazione, che sembra stia diventando sempre più diffusa?
Tranquillo IT
Aramis
Posizione: Lille
27 ottobre 2025 - 14:22
vcardon ha scritto: 21 ott 2025 - 19:17 Ciao Julien,
quando dici "questa comunità", intendi la comunità degli editori di software scientifico?
In tal caso, conosci https://www.eprist.fr/qui-sommes-nous/ ? Potresti metterci in contatto con qualcuno di questa associazione in modo che possiamo spiegare questa situazione, che sembra effettivamente stia diventando sempre più diffusa?
Sì, mi riferisco alla comunità degli editori di software scientifico. Definire il packaging di questo tipo di software è sempre un processo laborioso.
Purtroppo non ho alcun contatto con questa associazione, che altrimenti non conoscevo.
Sinceramente,
Risposta
