[RISOLTO] WADS: l'agente wapt non si registra
rlegrand
Iscrizioni: 30 giugno 2026 - ore 15:37
30 giugno 2026 - 16:11
Sto riscontrando un problema durante la distribuzione di Windows 11 con WADS; il sistema operativo viene distribuito correttamente, ma l'agente WAPT sulla macchina non si registra più con il server e anche lo script di post-installazione non viene eseguito
Ho testato l'installazione su due macchine diverse e continuo a riscontrare lo stesso problema.
Di seguito è riportato il log del client Wapt:
2026-06-30 10:29:39,180 [waptcore WaptTaskManager 7500] CRITICAL Error merging Packages from wapt into db: 400 Client Error: Bad Request for url: https://srv-wapt.xxx.fr/wapt/Packages
Disabling Windows auto update service, using WaptWUA instead
2026-06-30 10:29:43,061 [waptcore WaptTaskManager 7500] WARNING Unable to update server status : 400 Client Error: Bad Request for url: https://srv-xxx.fr/update_host
2026-06-30 10:29:43,061 [waptcore WaptTaskManager 7500] CRITICAL Unable to update_server_status: None
2026-06-30 10:29:43,061 [wapttasks WaptTaskManager 7500] WARNING Update status failed, trying to register the computer...
2026-06-30 10:29:45,877 [waptcore WaptTaskManager 7500] CRITICAL Unable to register: Error sending registration data: status 403 content <html>
<head><title>403 Forbidden</title></head>
<body>
<center><h1>403 Forbidden</h1></center>
<hr><center>nginx</center>
</body>
</html>
2026-06-30 10:29:45,877 [wapttasks WaptTaskManager 7500] CRITICAL Unable to update server status: Error sending registration data: status 403 content <html>
<body>
</body>
</html>
2026-06-30 10:29:57,387 [wapttasks SocketIOClient 3520] INFO Socketio connection params have changed. Socketio needs reconnect
2026-06-30 10:29:57,394 [wapttasks SocketIOClient 3520] INFO Creating socketio client: https://srv-xxx.fr:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.crt', 'C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.pem') proxies: None verify_cert: False
2026-06-30 10:29:57,394 [wapttasks SocketIOClient 3520] INFO Connecting Socketio to https://srv-xxx.fr:443
2026-06-30 10:29:57,467 [waptws SocketIOClient 3520] WARNING Exception ConnectionError('Connection error'), waiting 33.76406250000001s before retrying
2026-06-30 10:30:31,250 [wapttasks SocketIOClient 3520] INFO Socketio connection params have changed. Socketio needs reconnect
2026-06-30 10:30:31,250 [wapttasks SocketIOClient 3520] INFO Creating socketio client: https://srv-xxx:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.crt', 'C:\\Program Files (x86)\\wapt\\private\\70bf4a6c-9463-4c39-bca3-4be5c2139a21.pem') proxies: None verify_cert: False
Grazie in anticipo per il vostro aiuto
sfontenau
1° luglio 2026 - 17:32
Salve
, potrebbe specificare il metodo di registrazione utilizzato sul server WAPT?
Kerberos?
rlegrand
2 luglio 2026 - 10:37
sì, la registrazione Kerberos è abilitata.
Il server Linux è in versione 2.6.1.17834.
Quando eseguo `wapt-get register` sulla macchina client, mi vengono richieste le credenziali. Non so perché; non credo che succedesse prima.
Prima funzionava correttamente, ma sospetto che la registrazione Kerberos non funzioni più.
2 luglio 2026 - 12:30
Ciao rlegrand,
quando prepari la macchina, selezioni il modello con integrazione AD e generi correttamente il file DJoin? In tal caso, hai più Active Directory? E qual è il tempo di propagazione delle modifiche ad AD? È possibile che tu abbia creato il file DJoin su un Active Directory, ma la workstation si connette a un altro.
rlegrand
2 luglio 2026 - 13:59
dcardon ha scritto: 2 luglio 2026 - 12:30 Ciao rlegrand,
quando prepari la macchina, scegli il modello con integrazione AD e generi correttamente il file DJoin? In tal caso, hai più Active Directory? E qual è il tempo di propagazione delle modifiche di AD? È possibile che tu abbia creato il file DJoin su un AD, ma la workstation si connette a un AD diverso.
Saluti,
Sì, sto usando un template con integrazione di dominio.
L'adesione al dominio è funzionante, l'agente WAPT si installa correttamente, ma la registrazione del client Wapt sul server non funziona più (la workstation non compare nella console) e pertanto l'esecuzione dei comandi dello script di post-installazione non può funzionare (comandi "Wapt-get").
sfontenau
2 luglio 2026 - 14:53
Potresti dirmi cosa restituisce questo comando sul server WAPT?
https://www.wapt.fr/fr/doc/wapt-securit ... -with-curl
Potresti anche dirmi che tipo di server hai? Red Hat? Alma? Debian?
rlegrand
2 luglio 2026 - 15:53
sfonteneau ha scritto: 2 luglio 2026 - 14:53 Puoi indicare cosa restituisce questo sul server Wapt?
root@SRV-WAPT:/home/wapt# kdestroy
root@SRV-WAPT:/home/wapt# kinit <user>
Password for <user>@<domaine>:
root@SRV-WAPT:/home/wapt# klist
Ticket cache: FILE:/tmp/krb5cc_0
Default principal: <user>@<domaine>
Valid starting       Expires              Service principal
07/02/2026 15:35:34  07/03/2026 01:35:34  krbtgt/<domaine>@<domaine>
        renew until 07/03/2026 15:35:28
root@SRV-WAPT:/home/wapt# curl -v --negotiate -u : https://srv-wapt.<domaine>/api/v3/add_host_kerberos -k
* Host srv-wapt.<domaine>:443 was resolved.
* IPv6: (none)
* IPv4: 192.168.1.11
*   Trying 192.168.1.11:443...
* connect to 192.168.1.11 port 443 from 192.168.1.10 port 34656 failed: No route to host
* Failed to connect to srv-wapt.<domaine> port 443 after 3078 ms: Could not connect to server
* closing connection #0
curl: (7) Failed to connect to srv-wapt.<domaine> port 443 after 3078 ms: Could not connect to server
sfontenau
2 luglio 2026 - 15:59
Qual è l'indirizzo IP del server?
rlegrand
2 luglio 2026 - 16:34
sfonteneau ha scritto: 2 luglio 2026 - 15:59
192.168.1.10
sfontenau
2 luglio 2026 - 16:44
L'indirizzo 192.168.1.11 non è presente in /etc/hosts? (configurazione errata)
Kinit sta tentando di connettersi a 192.168.1.11...
