[Risolto] Installazione/aggiornamento di Firefox 53.0.2-93
IiscsiI
Registrazione: 25 maggio 2016 - 09:03
16 maggio 2017 - 16:45
Ciao a tutti,
Versione del server WAPT: 1.3.12.13
Versione dell'agente WAPT: 1.3.9.3
Versione di installazione WAPT: 1.3.9.3
Versione di distribuzione WAPT: 1.3.12.3
Ho aggiornato il pacchetto Firefox sulla mia console e quando lo installo sui PC ricevo il seguente messaggio di errore:
Installing waptp-firefox
Exception: Error during install of waptp-firefox (=53.0.2-93): errors in packages [[u'waptp-firefox (=53.0.2-93)', PackageEntry('waptp-firefox','53.0.2-93')]]
  File "c:\wapt\waptservice\waptservice.py", line 2099, in run
    self.running_task.run()
  File "c:\wapt\waptservice\waptservice.py", line 1360, in pwrapper
    return func(*arg, **kwargs)
  File "c:\wapt\waptservice\waptservice.py", line 1420, in run
    self._run()
  File "c:\wapt\waptservice\waptservice.py", line 1844, in _run
Se attivo il "tray" appare il messaggio "versione errata di WAPT".
Ho saltato un passaggio durante l'aggiornamento?
1 - i miei pacchi
dpkg --status tis-waptserver tis-waptrepo tis-waptsetup
Package: tis-waptserver
Status: install ok installed
Priority: optional
Section: base
Maintainer: TIS <technique@tranquil-it-systems.fr>
Architecture: all
Version: 1.3.12.13
Depends: python, mongodb-server (>= 2.4.8), dialog, tis-waptrepo, python-m2crypto, python-passlib, uwsgi, uwsgi-plugin-python, python-tz, cabextract, python-netifaces, python-urllib3, python-requests
Recommends: tis-waptsetup, uwsgi-plugin-http
Description: WAPT Server for linux
Package: tis-waptrepo
Priority: optional
Section: base
Maintainer: Tranquil-IT-Systems <admin@tranquil-it-systems.fr>
Architecture: all
Version: 1.3.12.13
Depends: python, apache2, python-requests
Description: serveur depot wapt local
Homepage: http://www.tranquil-it-systems.fr
Package: tis-waptsetup
Priority: optional
Section: base
Architecture: all
Version: 1.3.12.13
Depends: tis-waptrepo
Description: WAPT setup executable for Windows
2 - comando post conf /usr/bin/python /opt/wapt/waptserver/scripts/postconf.py -> Fatto e OK
3 - Installa la console nella sua nuova versione
4 - generare un nuovo agente.
Ma la console e l'agente rimangono alla versione 1.3.9.3.
grazie in anticipo
Ultima modifica di IiscsiI il 18 maggio 2017 alle 15:49, modificato 1 volta.
Stenone
Registrazione: 2 giugno 2016 - 8:04 AM
17 maggio 2017 - 09:03
CIAO
Hai installato sul tuo computer Windows la nuova versione che gestisce i pacchetti WAPT?
Altrimenti, vai all'indirizzo web del tuo server e installalo
◾WAPTSetup (per l'installazione sulla macchina di gestione)
Quindi non ti resta che generare il pacchetto agente...
IiscsiI
18 maggio 2017 - 08:43
grazie per la risposta.
Ho trovato il problema. Il mio pacchetto di aggiornamento client non si era installato correttamente e generava un errore "sconosciuto" durante l'installazione.
L'ho rigenerato e ora funziona molto meglio, quindi per quanto mi riguarda possiamo chiudere la questione.
Buona giornata.
