Ho un problema con la distribuzione automatica dei pacchetti quando la sessione di Windows è chiusa.
Sto utilizzando la versione 1.3.13.0 di wapt su un server Windows 2012 con client Windows 7/10.
Durante la fase di test ha funzionato, ma quando ho avviato il client wapt sull'intera rete, ho notato che alcune workstation non installavano i pacchetti quando le sessioni erano chiuse.
Ecco cosa trovo nel file waptservice.log su una macchina client.
2018-01-05 10:22:06,528 CRITICAL Error downloading package from http repository, please update... error : ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt/sog-flashplayer_27.0.0.130-2_all.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x0352A2D0>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))
2018-01-05 10:22:06,762 CRITICAL Error downloading package from http repository, please update... error : ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt-host/machine.domaine.local.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x034370F0>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))
2018-01-05 10:22:06,762 CRITICAL Error downloading some files : [(u'http://serveur.domaine.local/wapt/sog-flashplayer_27.0.0.130-2_all.wapt', u"ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt/sog-flashplayer_27.0.0.130-2_all.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x0352A2D0>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))"), (u'http://serveur.domaine.local/wapt-host/machine.domaine.local.wapt', u"ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt-host/machine.domaine.local.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x034370F0>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))")]
2018-01-05 10:22:06,762 CRITICAL Package sog-flashplayer not installed due to errors : Exception: No control found for c:\wapt\cache\sog-flashplayer_27.0.0.130-2_all.wapt
2018-01-05 10:22:06,762 CRITICAL Package machine.domaine.local (=3) not installed due to errors : Exception: No control found for c:\wapt\cache\machine.domaine.local.wapt
2018-01-05 10:22:06,762 CRITICAL Exception: Error during install of machine.domaine.local (=3): errors in packages [[(u'http://serveur.domaine.local/wapt/sog-flashplayer_27.0.0.130-2_all.wapt', u"ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt/sog-flashplayer_27.0.0.130-2_all.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x0352A2D0>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))"), None], [(u'http://serveur.domaine.local/wapt-host/machine.domaine.local.wapt', u"ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt-host/machine.domaine.local.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x034370F0>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))"), None], [u'sog-flashplayer', PackageEntry('sog-flashplayer','27.0.0.130-2')], [u'machine.domaine.local (=3)', PackageEntry('machine.domaine.local','3')]]
2018-01-05 10:22:07,135 CRITICAL Error downloading package from http repository, please update... error : ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt/sog-flashplayer_27.0.0.130-2_all.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x03437B30>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))
2018-01-05 10:22:07,135 CRITICAL Error downloading some files : [(u'http://serveur.domaine.local/wapt/sog-flashplayer_27.0.0.130-2_all.wapt', u"ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt/sog-flashplayer_27.0.0.130-2_all.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x03437B30>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))")]
2018-01-05 10:22:07,135 CRITICAL Package sog-flashplayer (=27.0.0.130-2) not installed due to errors : Exception: No control found for c:\wapt\cache\sog-flashplayer_27.0.0.130-2_all.wapt
2018-01-05 10:22:07,135 CRITICAL Exception: Error during install of sog-flashplayer (=27.0.0.130-2): errors in packages [[(u'http://serveur.domaine.local/wapt/sog-flashplayer_27.0.0.130-2_all.wapt', u"ConnectTimeout: HTTPConnectionPool(host='serveur.domaine.local', port=80): Max retries exceeded with url: /wapt/sog-flashplayer_27.0.0.130-2_all.wapt (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x03437B30>: Failed to establish a new connection: [Errno 11004] getaddrinfo failed',))"), None], [u'sog-flashplayer (=27.0.0.130-2)', PackageEntry('sog-flashplayer','27.0.0.130-2')]]
2018-01-05 10:22:08,569 ERROR Traceback (most recent call last):
File "c:\wapt\lib\site-packages\rocket\main.py", line 143, in start
time.sleep(THREAD_STOP_CHECK_INTERVAL)
IOError: [Errno 4] Interrupted function call
Come esempio viene utilizzato il pacchetto flashplayer, ma lo stesso vale per altri pacchetti, la maggior parte dei quali sono importazioni di pacchetti dal sito wapt-tranquil.it.
Non credo che il problema sia il file di controllo, poiché l'installazione CLI funziona sul client.
Forse un problema di connessione?
Il problema è dovuto al fatto che il computer è connesso tramite Wi-Fi?
Tuttavia, l'ho testato su macchine non amministrative e tramite Wi-Fi con un certificato utente e non ho riscontrato problemi.
