[RISOLTO] problema aggiornamento 1.5.1.23 a 1.6
cdeze
Registrazione: 29 nov 2016 - 09:39
26 settembre 2018 - 14:19
Ricevo questo messaggio di errore
Puoi dirmi se questo ti tocca?
GRAZIE
root@wapt:~# apt-get update
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stable InRelease
Ign:3 http://cdn-fastly.deb.debian.org/debian stable-update InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stable Release
Ign:5 https://wapt.tranquil.it/debian/wapt-1.6 stretch InRelease
Ign:6 http://cdn-fastly.deb.debian.org/debian stable-update Release
Ign:7 http://deb.debian.org/debian stable-update/main all Packages
Ign:7 http://cdn-fastly.deb.debian.org/debian stable-update/main all Packages
Ign:9 http://deb.debian.org/debian stable-update/main amd64 Packages
Ign:9 http://cdn-fastly.deb.debian.org/debian stable-update/main amd64 Packages
Ign:10 http://deb.debian.org/debian stable-update/main Translation-en
Ign:10 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en
Ign:11 http://deb.debian.org/debian stable-update/main Translation-fr
Ign:11 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-fr
Ign:12 https://wapt.tranquil.it/debian/wapt-1.6 stretch Release
Ign:13 http://deb.debian.org/debian stable-update/main Translation-en_US
Ign:13 http://cdn-fastly.deb.debian.org/debian stable-update/main Translation-en_US
Ign:14 http://deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:14 http://cdn-fastly.deb.debian.org/debian stable-update/contrib amd64 Packages
Ign:15 http://deb.debian.org/debian stable-update/contrib all Packages
Ign:15 http://cdn-fastly.deb.debian.org/debian stable-update/contrib all Packages
Ign:16 http://deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:16 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en_US
Ign:17 http://deb.debian.org/debian stable-update/contrib Translation-en
Ign:17 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-en
Ign:18 http://deb.debian.org/debian stable-update/contrib Translation-fr
Ign:18 http://cdn-fastly.deb.debian.org/debian stable-update/contrib Translation-fr
Ign:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
Ign:20 http://deb.debian.org/debian stable-update/non-free all Packages
Ign:20 http://cdn-fastly.deb.debian.org/debian stable-update/non-free all Packages
Ign:21 http://deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:21 http://cdn-fastly.deb.debian.org/debian stable-update/non-free amd64 Packages
Ign:22 http://deb.debian.org/debian stable-update/non-free Translation-fr
Ign:22 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-fr
Ign:23 http://deb.debian.org/debian stable-update/non-free Translation-en
Ign:23 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en
Ign:24 http://deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:24 http://cdn-fastly.deb.debian.org/debian stable-update/non-free Translation-en_US
Ign:25 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main all Packages
Ign:26 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en
Ign:27 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-en_US
Ign:28 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main Translation-fr
Err:9 http://deb.debian.org/debian stable-update/main amd64 Packages
  404  Not Found
Err:19 https://wapt.tranquil.it/debian/wapt-1.6 stretch/main amd64 Packages
  gnutls_handshake() failed: Error in the pull function.
Reading package lists... Done
W: The repository 'http://deb.debian.org/debian stable-update Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'https://wapt.tranquil.it/debian/wapt-1.6 stretch Release' does not have a Release file.
E: Failed to fetch http://deb.debian.org/debian/dists/stable-update/main/binary-amd64/Packages  404  Not Found
E: Failed to fetch https://wapt.tranquil.it/debian/wapt-1.6/dists/stretch/main/binary-amd64/Packages  gnutls_handshake() failed: Error in the pull function.
E: Some index files failed to download. They have been ignored, or old ones used instead.
26 settembre 2018 - 15:13
Ciao cdeze,
cdeze ha scritto: ↑26 settembre 2018 - 14:19 Ricevo questo messaggio di errore
GRAZIE
Penso che tu stia riscontrando un problema con il download di APT... Potresti controllare il tuo proxy? C'è un attacco man-in-the-middle (MITM) che utilizza un certificato jolly sul tuo proxy?
Sinceramente,
cdeze
26 settembre 2018 - 16:03
Buongiorno
Nessun MITM, ma piuttosto un proxy che non deve conoscere un cifrario o una versione SSL
PER TUA INFORMAZIONE
root@wapt:~# curl -vv https://wapt.tranquil.it/
*   Trying 100.78.56.201...
* TCP_NODELAY set
* Connected to (nil) (100.78.56.201) port 8001 (#0)
* Establish HTTP proxy tunnel to wapt.tranquil.it:443
> CONNECT wapt.tranquil.it:443 HTTP/1.1
> Host: wapt.tranquil.it:443
> User-Agent: curl/7.52.1
> Proxy-Connection: Keep-Alive
< HTTP/1.1 200 Connection established
* Proxy replied OK to CONNECT request
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* Unknown SSL protocol error in connection to wapt.tranquil.it:443
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to wapt.tranquil.it:443
cdeze
26 settembre 2018 - 16:12
Credo che il mio proxy supporti solo TLS 1.3 e che il vostro server non disponga di questo protocollo
. Mi sbaglio?
26 settembre 2018 - 16:16
Ciao Cdeze,
cdeze ha scritto: ↑26 set 2018 - 16:12 Credo che il mio proxy permetta solo TLS 1.3 e che il tuo server non supporti questo protocollo
. Mi sbaglio?
Penso che il tuo proxy non supporti TLS 1.2... Se il tuo proxy accetta solo TLS 1.3, non riuscirà a connettersi molto! :-)
cdeze
26 settembre 2018 - 16:22
Eppure lo fa:
root@wapt:~# curl -vv https://forum.tranquil.it/
* TCP_NODELAY set
* Establish HTTP proxy tunnel to forum.tranquil.it:443
> CONNECT forum.tranquil.it:443 HTTP/1.1
> Host: forum.tranquil.it:443
* ALPN, offering h2
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
*  subject: OU=Domain Control Validated; OU=Gandi Standard Wildcard SSL; CN=*.tranquil.it
*  start date: May 25 00:00:00 2018 GMT
*  expire date: Jun  8 23:59:59 2020 GMT
*  subjectAltName: host "forum.tranquil.it" matched cert's "*.tranquil.it"
*  issuer: C=FR; ST=Paris; L=Paris; O=Gandi; CN=Gandi Standard SSL CA 2
*  SSL certificate verify ok.
26 settembre 2018 - 17:21
Ciao cdeze,
cdeze ha scritto: ↑26 settembre 2018 - 16:22 Eppure lo fa:
Stiamo anche utilizzando un proxy; ho lo stesso TLS e la stessa cifratura in entrambi i casi... Ammetto di non capire...
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://wapt.tranquil.it/
* Tentativo 192.168.149.13...
* Connessione SSL tramite TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
[dcardon@srvlts1.ad.tranq ~]$ curl -vv https://forum.tranquil.it/
Simon mi ha detto che, nel peggiore dei casi, puoi sempre scaricare i file .deb tramite il tuo browser e installarli con dpkg... :-)
cdeze
27 settembre 2018 - 08:46
Il problema derivava dal nostro sistema di filtraggio Bluecoat, che aveva segnalato il sito come sospetto.
Ci scusiamo per l'inconveniente
2 ottobre 2018 - 20:04
Ciao Cdeze,
cdeze ha scritto: ↑27 set 2018 - 8:46 Il problema derivava dal nostro sistema di filtraggio di Bluecoat, che aveva segnalato il sito come sospetto.
Ci scusiamo.
Grazie per il feedback, contrassegno l'argomento come [RISOLTO]
Sinceramente,
