[RISOLTO] Pacchetto di rimozione delle app metro
Matteo
Iscrizioni: 18 agosto 2016 - 10:24
14 luglio 2019 - 10:18
Di recente ho riscontrato un problema con un pacchetto di app Remove Metro. Funzionava perfettamente, ma dopo alcune installazioni, il pacchetto mostra un errore, anche se non ho modificato lo script da quando il pacchetto è stato messo in produzione
Ecco il messaggio:
Starting the debloating process...Trying to remove Microsoft.BingFinance
NoneTrying to remove Microsoft.BingNews
NoneTrying to remove Microsoft.BingSports
NoneTrying to remove Microsoft.BingWeather
NoneTrying to remove Microsoft.Getstarted
NoneTrying to remove Microsoft.XboxApp
NoneTrying to remove Microsoft.ZuneMusic
NoneTrying to remove Microsoft.ZuneVideo
NoneTrying to remove Microsoft.MinecraftUWP
NoneTrying to remove Microsoft.BingFoodAndDrink
NoneTrying to remove Microsoft.BingTravel
NoneTrying to remove Microsoft.BingHealthAndFitness
NoneTrying to remove Microsoft.WindowsReadingList
NoneTrying to remove Flipboard.Flipboard
NoneTrying to remove ShazamEntertainmentLtd.Shazam
NoneTrying to remove king.com.CandyCrushSaga
NoneTrying to remove king.com.CandyCrushSodaSaga
NoneTrying to remove king.com.*
NoneTrying to remove ClearChannelRadioDigital.iHeartRadio
NoneTrying to remove 4DF9E0F8.Netflix
NoneTrying to remove 6Wunderkinder.Wunderlist
NoneTrying to remove Drawboard.DrawboardPDF
NoneTrying to remove 2FE3CB00.PicsArt-PhotoStudio
NoneTrying to remove D52A8D61.FarmVille2CountryEscape
NoneTrying to remove TuneIn.TuneInRadio
NoneTrying to remove TheNewYorkTimes.NYTCrossword
NoneTrying to remove 828B5831.HiddenCityMysteryofShadow
NoneTrying to remove Microsoft.Advertising.Xaml
NonePreviously removed by wapt :
Remaining metro apps ;) : Traceback (most recent call last):
  File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
  File "c:\windows\temp\waptxq1txp\setup.py", line 102, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4399, in run_powershell
    raise ValueError(u'%s returned non json data:\n%s' % (cmd,result))
UnicodeDecodeError: 'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128)
'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128) : faulty string is ''[\r\n    {\r\n        "Name":  "1527c705-839a-4832-9118-54d4Bd6a0c89",\r\n        "Publisher":  "CN=Microsoft Windows, O=Microsoft Corporation, L=Redmond, S=Washington, C=US",\r\n        "PublisherId":  "cw5n1h2txyewy",\r\n        "Architecture":  11,\r\n        "ResourceId":  "neutral",\r\n        "Version":  "10.0.16299.15",\r\n        "PackageFamilyName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_cw5n1h2txyewy",\r\n        "PackageFullName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_10.0.16299.15_neutral_neutral_cw5n1h2txyewy",\r\n        "InstallLocation":  "C:\\\\Windows\\\\SystemApps\\\\Microsoft.Windows.FilePicker_cw5n1h2txyewy",\r\n        "IsFramework":  false,\r\n        "PackageUserInformation":  [\r\n                                       "S-1-5-21-485133025-386941804-4221807023-500 [Administrateur]: Installed",\r\n
Ho dovuto tagliarlo, ma continua con tutte le app presenti nello script.
Non capisco perché all'improvviso la sceneggiatura ha iniziato a non funzionare più.
Grazie per l'aiuto
Ultima modifica di Mathieu il 2 ottobre 2019 alle 17:45, modificato 1 volta.
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 e Windows 11 22h2
19 luglio 2019 - 19:08
Ciao Mathieu,
Mathieu ha scritto: ↑14 luglio 2019 - 10:18 Ho recentemente riscontrato un problema con un pacchetto per la rimozione delle app Metro. Prima funzionava perfettamente, ma dopo alcune installazioni il pacchetto mostra un errore, anche se non ho modificato lo script da quando il pacchetto è stato messo in produzione.
Quale versione di WAPT, quale versione del sistema operativo?
Mathieu ha scritto: ↑14 luglio 2019 - 10:18 Ecco il messaggio:
Anche le macchine hanno i loro sbalzi d'umore, le loro piccole stranezze, ecc. Ogni aggiornamento di Windows può essere un'opportunità per scoprire nuovi comportamenti e nuove anomalie :-) .
In questo caso, lo script di PowerShell restituisce un file JSON con una codifica imprevista. Sembra che il blob JSON sia stato troncato, giusto?
Sinceramente,
Denis Cardon
Matteo
22 luglio 2019 - 14:10
Scusate, ho dimenticato di menzionarlo
: WAPT 1.7.4.6143 Enterprise
- Debian 9.9.
Tutte le nostre macchine hanno la stessa versione di Windows 10, la 1709.
Gli aggiornamenti vengono distribuiti tramite WSUS, quindi per quanto riguarda il sistema operativo, le macchine sono identiche.
Per quanto riguarda il "JSON Blob", non ne so nulla; non l'ho mai modificato.
- Debian 9.9
25 luglio 2019 - 11:12
Sarebbe interessante vedere cosa c'è che non va nella versione di PowerShell...
nel pacchetto alla fine della procedura install()
sostituire
    print(u'Remaining metro apps ;) : ')
    print(u'\n'.join(sorted(u'"%(Name)s", # (%(Version)s)",' % app for app in run_powershell('Get-AppxPackage -AllUsers'))))
di
    print(repr(run_powershell('Get-AppxPackage -AllUsers',output_format='txt')))
Puoi postare il risultato di un'installazione su una macchina in cui sta causando problemi?
Tranquillo IT
Matteo
30 luglio 2019 - 17:46
Penso che ci sia stato un problema: ho sostituito le linee correttamente
  File "c:\waptdev\futur-OptionW10_remove_metroapps_PROD-wapt\setup.py", line 104, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4384, in run_powershell
    raise CalledProcessErrorOutput(e.returncode,cmd,e.output)
CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
FATAL ERROR : CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾†ªÿ†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ªÆøÿ‘¾Ý‘­œ‘?¸Æûý‡øÿƒïÿ‘??‡?ý‘«¸ƒ?©‡?¬‡?¾‘¾ü‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«?‘«?‘«õƒ??ƒæ?‘«?‡­?‡?¸ƒ??ƒæ?‡??†æ­ƒæ?‡??†æ­†ªÿ„÷ð†?î‘«ý‘¾Ý‘?ªƒ??ƒæ?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…æ?ƒ??ƒ?ÿ†ªÿ„Ïð‡?©‡?æ‘«?‘æý‡?­‡ªÿ‘??‡?÷‡øÿ†ÿÿ„ñ?†æ«†ªÿ„¬ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï†?¯‡­¾ƒ?ïƒ?¬„æ?‡æ?…æ?ƒ??ƒ?ÿ†ªÿ†?ð‘û¸‘«Ï†?ú‡¾ï‘?ªÆøÿ‡?ü‘ñûÆû¾ƒ??ƒæ?‘û?‘«œ‘?Ï„?Ï‘æî‘?ð‘?©Æøÿ‘«Ÿ‘æð‘û­‘?Ï‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿÆ÷ï…æ?ƒ??ƒ?ÿ†ªÿ„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ðÆøÿ‘­œŠñ­‘?©†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘¾?‘?ªÆøÿ‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ÆûýÆøÿ‡?­‡?õ‘?ð‡?©Æûüƒ??ƒæ?‡­?‘?¾‡?æ‘«¸†?©‘ñî‘?¸ƒ?û†?¬‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«Ÿ‘æð‘û­ƒ?σ?¯ƒ?ðƒ?¬‘?¬‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸Æûÿ‘?ð‘?ýƒ?ü‡?¬‘?­‘?ª‡?­‘?ÿ‘?õ‘?ý‘ææ‘û¾‡?ï†ïó…ù?ƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?¬‘?¬‘?ù‘§?Æû¾†ªÿ†?¬‡?­‘æ­‡??‘?ýƒ?ü‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?φïó‡ïÿ†ïÿ…ù?…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾ƒïÿ‘??‡?ª‡øÿƒïÿƒ?¨ƒ?¬Æ¬î…ù?…ù?†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‘­Ÿ‡?­‘?õ‘øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘?Ï‘?ÿ‘ûî‘«ü‘?ª†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª‡?ü‘??‘?¸Š?¸ƒ?©‘«?‡?æ‘?ÿŠ?ý‡?¾‡?ÿ…橃??ƒ?ÿ‘?ÿ‘?¸‘¾ù‡?¾‘?ÿƒ?¾‘«œ‡?©‘ñîƒñ¾‡?ÿ‘¾ï‘¾ª‘?üƒ?§‡­?‘«ø‡?ý„?ð‘ûî‘«ü‘?ª‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘??‡?ý‘«¸…橃??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿƒ?­‘?ô‡?ý‘«¸ƒ?©‡?ü‘??‘?¸Š?¸ƒ?¾‘?φ?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª…ïÿƒ??ƒ?ÿ„?ÿ‡?©‘?ýƒ?§‘ûæ‘÷ÿ‘ææ‡??ƒ?î‘?χ?ÿ‡?¾‘¾ü‘ûî‘?ÿ‘?ôƒ?œ‘?ª‡?ÿ‡?­‘æ­‡??‘?ýƒ?ª‘?ïƒ?ª‡?ñƒ?¾ƒ?©‡?ð‡?¾‘¾ü‘ûîÆ?ÿÆ?©ˆ¬ÿ…ï©…ï?ƒï?‘«?‘«?‘«õ…ù?ƒ?ÿƒ?ÿ‘??‡?ü‘?æ‘øÿƒ?­‘?½‘û©Š¸¸‘?ý‘?ÿƒ?¾‘«œ‡¾ø‘¾ý‘­õƒ?ï‡?­‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‘«?‡­?‡?¸…ù?ƒ?ÿƒ?ÿ‘??‡?ÿƒ?¾‘?Ý‘æýƒ?¾‘?øƒ?ü‡?­Š¸ýƒ?üƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?σ?ü‘«œ‘æð‘û­‘?σ?ü‘?Ï‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾Š?ÿ‘øÿ‘?õ‘?¸ƒ?¾ƒ?Ï‘ûæ‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒûÏ…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒ?φ?ù„??ƒ?¸‡?¾ƒ?ï‡?æ‘ñ¸‡?¸ƒ??‘?øƒ?ýŠ?Ï‘?݇?æ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ýƒ?ýƒ?ª‘û¸‘?ï‡?ýŠ?ý‘?ï‡?æ‘?ÿƒ?¾‘«œ‘æð‘û­‘?σ?üƒ??ƒ?ª‘¾­‘?Ï‘?ÿ‡?õƒ?©‘ñœ‘¾î‘«ü‘û©‘澑û¾ƒ?ï‡?ð‡?ª‡?¸‡?ù‘?¾ƒûÏ…ù?…ù?„÷ð†?î‘«ý‘¾Ý‘?ª…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘?ù‘?ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‘«ý‘¾Ýƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…ù?ƒ?ÿƒ?ÿƒ??‘?­‘¾Ý‘­œƒ?¾‘?øƒ?üƒ?Ï‘û¸‘¾ô‘?ï‘Ïÿ‡?©‡?¾‘?­‘¾ï‘?ô‡?ÿ‡?îƒ?ýƒ?ª‡?æ‘ñ¸‡?¸‡?­‡?¾ƒûý…ù?…ù?„Ïð‡?©‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‡?œ‡?¸‘øÿƒ?¾‘«Ý‘æý‡?­‘?ÿ‡?¾‘?ÿ‘ûîŠ?©‡?¾‘?ÿ‡?©‡¾î‘??ƒ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?©‘??ƒ?ü‘?ô‘?ª‡?æ…æüƒ??ƒ?ÿ‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‡??‡?ï‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‘?ï‘æý‘û¸ƒ?¾‘?ª‘ïÿ‡??‘«ù‘?Ï‘?ÿƒ?¾‘¾ð‘?ü‘?ÿƒ?©‘«Ý‘æýƒ?¾‘?Ï‘øÿƒ?­‘«ü‡?ý‘?¸‘?ÿƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…暑??ƒ?ÿ„øÿ‡?¾‡?ÿ‘ñ­‡?¾‡?ý‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‘¾?‘?©‡?î‡??‘ñû…澃??ƒ?ÿ„?ÿ‘??‘û¸‡?¸‘øÿƒ?¾‡?ü‘ñûƒ?¾‘?Ï‘?ÿ‘û¾‡??‘?ý‡?ÿ‡?æ„÷ÿ‡?î‘?ðƒñª„ïÿ‘û¸‘渇¸¸‘?¾ƒ?ª‘??‘¾÷‘¾ð‘?§ƒ?χ?î„ÿÿ‘?¸‘?σû©…ù?…ù?„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿ‘?œ‡?¾‘?ï‡?ÿ‘?©‡?ÿ‡?¾‘¾ü‘ûî‘?ÿƒ?¾‘­œŠñ­‘?©‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿƒ?ïƒ?Ï‘ûæƒ?¾‘«œ‘æð‘û­‘?σ?©‡??‘ñ¸‡?¸‡¸¾…ù?ƒ?ÿƒ?ÿ‘?œ‡?ÿ‡?­‘æ­‡??‘?ý‡?ÿ‡?îƒ?ý‘û¾‘«ô‘?ûƒ?ý‘?σ?ü‘«œ‘æð‘û­‘?σ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘÷ÿ‘??‡?¾‘¾ü‘?ï‡?©…ù?ƒ?ÿƒ?ÿ‘?σ?ü‡?õ‘ñ¸‘?ª‘?ð‡?ï‘?ÿ‘æî‘ñø‡­¾‡?¾‘¬ÿƒ?æ‘?σ?ü‘?­‘«œ‘?ª‘?σûü…ù?…ù?„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð…ù?ƒ?ÿƒ?ÿ‡??‘??‘?¸‘?¸‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿƒ?¾‘«œ‘?©‘?¸‡?æ‡?­‘«¸ƒ?©‘?χ?©‘øÿ‡?¾‘?æƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘?ÿ‡?ü‘?ÿŠ?÷‡?œŠ?ï…暑??ƒ?ÿ„Ïÿƒ?ª‘?ø‡?æ‡?ÿ‘?õ‘¾õƒ?ý‘?χ?ÿ‡?îƒ?ï‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿ‡?©‘?¾‡?¸‡?ïƒ??‡?üƒ?ý‘?ª‘ïÿ‘?­‘¾ù‘?©‘øÿ‘?î‘ñ­ƒñ¾‘÷ÿ‡?î‘æ­‘?ð‡?©‘øÿ‡?¾…ù?ƒ?ÿƒ?ÿ‘«ø‘û¸‡?ï‘?ÿƒ?¾‘?ï‘æý‘û¸‘¾­‘«üƒ?©ƒ??‘¾Ï‡?ü‘û­‘?œ‡?ÿ‡?­‘?ÿ‘??‡?­ƒ??‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?ª‡?î‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‡?ÿ‡?¾‘«ü‘û©‘ñ­‡?¸…ô?ƒ??ƒ?ÿ‘?ÿ‡?îƒ??‘?Ï‘?ÿ‡?­‘?­‡?¸‡??‡?ÿŠ?ø‘¾œ‘¾Ý‡?ñ‡?¾‘?ÿƒ?æ‚?ý‘?ª‡?ÿ‘¾ï‘¾ª‘?ü‘?ï‡?æ…暑??ƒ?ÿ…ïÿƒï?‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‡­?‘??‡?æƒ?¾‘?ª‡?ÿ‡?œ‡?¸ƒ?ï‡?ü‘??‘?¸Š?¸‘?ÿ‘û­ƒ?üƒ?ª‡??‘û¾‡?σ?¾‘«ª‘?œ‘?ªƒÿÿ‡?­‘?¾ˆ÷ÿ‘?ÿ‡?î‡?ð‡?î‘?ý‘û¸ƒ?õƒÝîƒ?ª‘?χ?ÿ‡?î‘?ï‡?ÿ‘?æ‘øÿ‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‘ûî‡?œ‘«¸‡?©‘?ÿƒ?ï‘?ô‘¾ý‘?­‘?ªƒ?ü‡?œŠ??‡?¾‡?ÿ‡?­‘øÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾î‘û¾ƒ?χ?ü‘ûî‘?¸‘?ªƒ?ü‘?χ?©‘øÿƒ?­…ù?ƒ?ÿƒ?ÿ‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ôƒ?©‘û?‡?¾‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒ?ï‡?¾‘øÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡??‘û¾‡?ï‘ñ¾ƒûü…ïÿƒ??ƒ?ÿ„øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾‡?ÿ‡?­‘æ­‡??‘?ý‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒñ¾‘?ÿ‡?­‡?ÿ‡?îƒ?ü‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘÷ÿ‘æî‘?ÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾‘¾?‘?ª‡?ÿ‘ûîƒ?ï‘û¸‘?ï‡?ýŠ?ýŠ?ï…æüƒ??ƒ?ÿ‘?ÿ‘æî‘?ðŠ?ÿ‘?ï‡?©‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒñï‡?ÿ‘¾æ‘¾ô‘?ÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?„?ð‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ…ù?ƒ?ÿƒ?ÿŠ??‘¾Ý‘¾©ƒ?ï‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî‡?ÿ‡?­‘?ÿ‘??‡?­ƒ?ï‘?Ï‘øÿƒ?­‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ô‘?ÿƒ?ïƒ?ª‘û¾‘?ý‘¾õ‡?ü‘?ý…ïÿƒ??ƒ?ÿ‘?ÿ‘û­ƒ?ü‘?ª‡?ÿ‡?­‘?¸‘ñ½ƒ?¾ƒ?Ï‘û¾‘¾ô‘«ý‘û©‘澑û¾ƒ?ï‘?χ?©†?§„??‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ‡??‘?¾‡?¾‘û¾‘?œƒ?©…ù?ƒ?ÿƒ?ÿ‘?Ÿ‡?ÿ‡?­‘æ­‡??‘?ý‘÷ÿƒ?¾‘«ð‘¾Ï‘¾Ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª…ù?ƒ?ÿƒ?ÿŠ?Ï‘¾Ý‘¾©ƒ?¾‘?χ?©‘øÿƒ?¾‘??‘¾õ‡?ü‘?ý…ï©…ï?ƒï?‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿŠ?÷‡?œ‘?ï‘øÿ‡?¾‘?ÿ‘æî‘?ð‘?©‡?¾‡?ÿŠ?ø‘¾œ‘¾Ý‘??ƒ?ü‘?ùƒ?ï‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾Š?ÿ‘?ô‡?©‘?æ‡?ªƒ?¸‘«œ‘æðƒ?¾‘¾ü‘?ÿ‘ñª‡?¾Š?ÿ‘?ï‘?¸‡?©…ù?ƒ?ÿƒ?ÿ‘û¾‡?ï‘??ƒ?ü‘?χ?©‘øÿ‘Ïõ‡?©‡?¸ƒ?¾‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿ‘¾æƒ?ü‘?ü‘?ÿ‡?¾‘?ðƒ?ª‘?ü‘?æ‡?ÿƒ?¸…ù?ƒ?ÿƒ?ÿ‘«?‡­?‡?¸‘?ÿ‡?ü‡?ÿŠ?ø‘¾œ‘¾Ýƒ§?„øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘?ø‡?æŠÿÿ‡?ïƒ?¾ƒ?©ƒ?ðƒýî‡?ÿ‘?©‘?ÿ‘?ù‘§?ƒ?¾‡?î‡?ÿ…橃??ƒ?ÿ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ïƒ?©ƒ?ðƒýî‘øÿƒ?¾‘?ï‡?÷ƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿ‡?ü‘øÿƒ?æ‘?χ?©…ù?ƒ?ÿƒ?ÿƒ?ª‘û¾‡?ï‘??‡?ÿ‘?ï‘?©‡?­ƒûÏ…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒñï‘?ÿ‘ñ¾‘¾æ‘?ðƒ?¸‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘ñø‘?­…ô?ƒ??ƒ?ÿ‘?ÿ‡?©‘?ý‘?ÿ‘?œ‘ñî‘?­‡?¾ƒÿÿ‡æ¯ƒ÷¸†?ÿ‡?îƒ?ü‘«ø‡?懸¾‡?ÿŠ?ø‘¾œ‘¾Ý‡?¾‡?ÿƒ?©‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾©‡?ñ‘澑û¾…æïƒ??ƒ?ÿ‘øÿ‡?î‡?ü‘?æ‡?ÿ‡?îƒ?ü‡­¾‘??‡?懸¾†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª‡­¾ƒ?¾‘?χ?©†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª„øÿ‡?¾‡?ÿ‡??‘ñæ‘?ï‡?ï‘?ÿƒ?æ‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘ûîƒ?ï‘?ý‡?©‡¾î‡??Š?ÿ‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ý‡?©‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï†ÿÿ„ñ?‘?ÿ‡??‡??‘?¸‘¾ªŠ?üƒ?ü‡?¾‘÷ÿ‘ûî‡?ÿ‡?­‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï‘?ÿ‡?œ‘?¸ƒûü…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©ƒ?ª‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ýЏð‡?ïƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?σ?ª‘?œƒ?ý‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«ü‡?©…ù?ƒ?ÿƒ?ÿ‘û¸‘?ï‡?ýŠ?ýŠ?ïƒ?ü‘«œ‘æðƒ?¾‡?­‡?õ‘?ð‡?©ƒ?ü‘?Ï‘?ÿ‘æî‘?ð‘?©ƒû¾…ù?…ù?ƒ?ÿƒ?ÿ‘«?‡?æŠ?ÿ‡?œ‡?¸ƒ?¾‘ûæƒ?¾‘­œŠñ­‘?©‡?ÿ‘¾æ‘?ÿŠ?÷‡?œ‘?ï‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…廙??ƒ?ÿ‡?ÿ‘¾ï‘¾ª‘?üƒ?§‘?ª‘?ÿ‡?î‘?ðƒ?ï…ï§…Ï?ƒ?½‡ªÿ‘?¬‘æî‘?ð‘?©Æû¾ƒ?«…ù?ƒ?ÿƒ?ÿ‚?î‘øÿ‡?¾‘?ÿ‘¾æ‘ñª‘澇?¾ƒ?ü‘û¸‘¾Ï‡?ñ‘û¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©‘?ÿƒ?ïƒ?ª‡?î‡??‡?­‡?¾ƒ?ýƒ?χ?­‘?øƒ?ªƒ?ù…︃??ƒ?ÿ‘?ÿ‡?©‘?ý‘§?ƒ?¾ƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï…ï©…ï?ƒï?‘??‡?ªƒ?ªÆ¬ðƒ?ªÆ¬î…ù?ƒ?ÿƒ?ÿ‘??‘¾Ý‘­œƒ?¾‘?œ‘ïÿ‡?¾‘?ü‘?õƒ?©‘¾?‡?ÿ‡?îƒ?ü‘û¾‡?¾‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«?‘?ú†?ý‘?ù‘ñª‘?©‘?÷‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?î…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿŠ?ý‘¾Ý‘?÷ƒ?§‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?­‘?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ïƒïùƒ?¸‡?¾…ù?ƒ?ÿƒ?ÿ‘«©ƒ?©‘?øƒ?ü‡?­‘?¾‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æƒÿÿƒÏîƒ?©‘«?‡?æ‡?ÿ‡?î‘?ôƒ?§‡?æ‘ñ¸‡?¸‡?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ï‡?î‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æ‘?ÿ‘û­ƒ?ü‘柃ûχ­¾ƒû¾…ù?…ù?†­?„æ?„ñ?†??…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ†??‘«Ÿ‡?©‘ñî„?¾‘ñ¸ƒ?¾‡??†?ª‘?©„¾øƒû©‡??Æ?œ…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ‘?ô‡?ý‘«¸ƒ?©ƒ÷ýƒ?ø„÷ð„ñî‘?îƒ?î„Ïð‡?©‡?æ‘«?‘æý‡?­‡?ÿ‡­¾ƒ?ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï„æ?…æ?ƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð„?ÿ‘æÏ‘û¸‘«?‘?ª…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©‡ªÿ‘??ƒæï‡??‘û¾„ñï‘?îƒïÿ‘«?„ûõ‘æ­ƒ?¾‘?ü‡?œ‘¾ý‡¾ï…櫃??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©ƒ?ÿƒ?Ý„?¯‡?¾„?ð‘?ô‡?©‘«?ƒ?õ„øð‘?î‘??‘?ð‡?ÿ‘?¾‡?æ‡?¸‡æû…ï½…ï?ƒ??ƒ?ÿƒ?ÿ†?ÿ‡?îƒ?ý‡?æ‘ñ¸‡?¸‡?¾‘øÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?υ遼??ƒ?ÿƒ?ÿ‘«œ‘æð‘û­ƒ?σ?«‘?õ‡?¸ƒ?ÿƸœ‡??‘«ý‡?õ‘æ­‘?ÿ‘ñ¸‡?¾ƒ?½…ïõƒ??ƒ?ÿƒ?ÿ‡¾½‘?ïƒ?üƒ?«†??‡?û‘?ïƒûð‘??‡?÷„?©‘?©‘?î‘û¸†æõÆù§‘û?‘?¸‘?îƒû¾‘??„?ï‡?û‡?¾ƒ?ù‘«œ‘æð‘û­ƒ¾Ï…ù?ƒ?ÿƒ?ÿ‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?σ?«„??‘ûî‘?ô‡?ýƸ?†?§„?î‡?­Æ?¾†?ï‡?ï‘û¸ƒ­õ‘?χ?û‡?¾…︃??ƒ?ÿ‡?ÿ‡?î‡?¾‘­ü‘ñ¾ƒûª‡­¾ƒ?¾‘?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?Ï‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏ„Ï?‡?ð‡?ü‘ñ½ƒ?¾‘?χ?ÿ‘?ý‡?¸‡?¾‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿƒ?©‘?ý‡?¸‘ûî‘?ÿ‡?õ‘?©‡?ÿ‘ñ­‡?¾ƒ?ý‘?χ?ÿ‡?­‘æ­‡??‘?ý‘Ïÿ‘?©‡?î‘?ý‡?œƒû¾ˆ÷ÿ‡?¨‡?÷ˆ¨¨‘÷ÿ‘?õ‡?ü‡?ÿ‡?­‡?ÿƒ?©‘«Ý‘æý‡?­‡?ÿ‘ñ­‘?¸ƒû¾„øÿ‡?¾‘?ÿ‡?î‘?ð‡?ï‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûî‹«ï…阮??‡­¾…æï†ÿ?„ñ?…ù?‘«?‘?©…ù?…ù?
Exit code:  3
- Debian 9.9
Matteo
30 luglio 2019 - 17:52
Ho appena notato che nella configurazione originale c'erano due linee di ##
old_removed.extend(removed)
    WAPT.write_param(control.package,old_removed)
Rimuovendo ##, il pacchetto viene installato con un messaggio alla fine
NoneTraceback (most recent call last):
  File "c:\windows\temp\wapthz_wv2\setup.py", line 96, in install
  File "C:\Program Files (x86)\wapt\lib\json\__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "C:\Program Files (x86)\wapt\lib\json\decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
- Debian 9.9
raselinario
Registrazione: 18 settembre 2019 - 16:37
18 settembre 2019 - 16:45
ho ricevuto il seguente messaggio e non è stato disinstallato nulla!
Avvio del processo di debloating...
Tentativo di rimozione di Microsoft.BingFinance
Nessuno
Tentativo di rimozione di Microsoft.BingNews
Nessuno
Tentativo di rimozione di Microsoft.BingSports
Nessuno
Tentativo di rimozione di Microsoft.BingWeather Nessuno Tentativo di rimozione di Microsoft.Getstarted
Nessuno
Tentativo
di
rimozione di Microsoft.XboxApp
Microsoft.ZuneMusic
Nessuno
di rimozione di Microsoft.ZuneVideo
Nessuno
Tentativo di rimozione di Microsoft.MinecraftUWP
Nessuno
Tentativo di rimozione di Microsoft.BingFoodAndDrink
Nessuno
Nessuno
di rimozione di Microsoft.BingHealthAndFitness
Nessuno
Tentativo di rimozione di Microsoft.WindowsReadingList
Nessuno
Tentativo di rimozione di Flipboard.Flipboard
Nessuno
di ShazamEntertainmentLtd.Shazam
Nessuno
di king.com.CandyCrushSaga
Nessuno
Tentativo di rimozione di king.com.CandyCrushSodaSaga
Nessuno
Tentativo di rimozione di king.com.*
Nessuno
Tentativo per rimuovere ClearChannelRadioDigital.iHeartRadio
Nessuno
Tentativo di rimuovere 4DF9E0F8.Netflix
Nessuno
Tentativo di rimuovere 6Wunderkinder.Wunderlist
Nessuno
Tentativo di rimuovere Drawboard.DrawboardPDF
Nessuno
Tentativo di rimuovere 2FE3CB00.PicsArt-PhotoStudio
Nessuno
Tentativo di rimuovere D52A8D61.FarmVille2CountryEscape
Nessuno
Tentativo di rimuovere TuneIn.TuneInRadio
Nessuno
Tentativo di rimuovere TheNewYorkTimes.NYTCrossword
Nessuno
Tentativo di rimuovere king.com.CandyCrushSag
Nessuno
Tentativo di rimuovere king.com.CandyCrushSodaSaga
Nessuno
Tentativo di rimuovere 828B5831.HiddenCityMysteryofShadow
Nessuno
Tentativo di rimuovere Microsoft.Advertising.Xaml
Nessuno
Precedentemente rimosso da wapt:
App metro rimanenti :;)
"1527c705-839a-4832-9118-54d4Bd6a0c89", # (10.0.17763.1)",
"7EE7776C.LinkedInforWindows", # (2.0.1.0)",
"AppUp.IntelGraphicsControlPanel", # (3.1.0.0)",
"AppUp.IntelOptaneMemoryandStorageManagement", # (17.0.1011.0)",
"CyberLinkCorp.th.Power2GoforLenovo", #(8.0.8621.0)",
"CyberLinkCorp.th.PowerDVDforLenovo", #(14.1.8627.0)",
"E046963F.LenovoCompanion", #(4.26.43.0)",
"E2A4F912-2574-4A75-9BB0-0D023378592B", # (10.0.17763.1)",
"F46D4000-FD22-4DB4-AC8E-4E1DDDE828FE", # (10.0.17763.1)",
"InputApp", # (1000.17763.1.0)",
"Microsoft.AAD.BrokerPlugin", # (1000.17763.1.0)",
"Microsoft.AccountsControl", # (10.0.17763.1)",
"Microsoft.Advertising.Xaml", # (10.1804.2.0)",
"Microsoft.AsyncTextService", # (10.0.17763.1)",
"Microsoft.BingWeather", # (4.25.12127.0)",
"Microsoft.BioEnrollment", # (10.0.17763.1)",
"Microsoft.CredDialogHost", # (10.0.17763.1)",
"Microsoft.DesktopAppInstaller", # (1.0.22011.0)",
"Microsoft.ECApp", # (10.0.17763.1)",
"Microsoft.GetHelp", # (10.1706.10441.0)",
"Microsoft.Getstarted", # (6.13.11581.0)",
"Microsoft.HEIFImageExtension", # (1.0.11792.0)",
"Microsoft.HEVCVideoExtension", # (1.0.12203.0)",
"Microsoft.LockApp", # (10.0.17763.1)",
"Microsoft.MPEG2VideoExtension", # (1.0.6.0)",
"Microsoft.MSPaint", # (4.1807.12027.0)",
"Microsoft.Messaging", # (3.43.27001.0)",
"Microsoft.Microsoft3DViewer", # (4.1808.15012.0)",
"Microsoft.MicrosoftEdge", # (44.17763.1.0)",
"Microsoft.MicrosoftEdgeDevToolsClient", # (1000.17763.348.0)",
"Microsoft.MicrosoftOfficeHub", # (17.8918.5926.0)",
"Microsoft.MicrosoftSolitaireCollection", #(4.1.5252.0)",
"Microsoft.MicrosoftStickyNotes", # (2.0.13.0)",
"Microsoft.MixedReality.Portal", # (2000.18081.1242.0)",
"Microsoft.NET.Native.Framework.1.6", # (1.6.24903.0)",
"Microsoft.NET.Native.Framework.1.7", # (1.7.25531.0)",
"Microsoft.NET.Native.Runtime.1.6", # (1.6.24903.0)",
"Microsoft.NET.Native.Runtime.1.7", # (1.7.25531.0)",
"Microsoft.Office.Desktop", # (16040.10730.20103.0)",
"Microsoft.Office.OneNote", # (16001.10228.20003.0)",
"Microsoft.OneConnect", # (5.1807.1991.0)",
"Microsoft.PPIProjection", # (10.0.17763.1)",
"Microsoft.People", # (10.1805.1361.0)",
"Microsoft.Print3D", # (3.0.1521.0)",
"Microsoft.ScreenSketch", # (10.1806.2112.0)",
"Microsoft.Services.Store.Engagement", # (10.0.18101.0)",
"Microsoft.SkypeApp", # (14.26.95.0)",
"Microsoft.StorePurchaseApp", # (11805.1001.8.0)",
"Microsoft.VCLibs.110.00.UWPDesktop", # (11.0.61135.0)",
"Microsoft.VCLibs.140.00", # (14.0.26706.0)",
"Microsoft.VCLibs.140.00.UWPDesktop", # (14.0.26905.0)",
"Microsoft.VP9VideoExtensions", # (1.0.12342.0)",
"Microsoft.Wallet", # (2.2.18179.0)",
"Microsoft.WebMediaExtensions", # (1.0.12341.0)",
"Microsoft.WebpImageExtension", # (1.0.11551.0)",
"Microsoft.Win32WebViewHost", #(10.0.17763.1)",
"Microsoft.Windows.Apprep.ChxApp", # (1000.17763.1.0)",
"Microsoft.Windows.AssignedAccessLockApp", # (1000.17763.1.0)",
"Microsoft.Windows.CapturePicker", # (10.0.17763.1)",
"Microsoft.Windows.CloudExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.ContentDeliveryManager", # (10.0.17763.1)",
"Microsoft.Windows.Cortana", # (1.11.5.17763)",
"Microsoft.Windows.NarratorQuickStart", # (10.0.17763.1)",
"Microsoft.Windows.OOBENetworkCaptivePortal", # (10.0.17763.1)",
"Microsoft.Windows.OOBENetworkConnectionFlow", # (10.0.17763.1)",
"Microsoft.Windows.ParentalControls", # (1000.17763.1.0)",
"Microsoft.Windows.PeopleExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.Photos", # (2018.18051.21218.0)",
"Microsoft.Windows.PinningConfirmationDialog", # (1000.17763.1.0)",
"Microsoft.Windows.SecHealthUI", # (10.0.17763.1)",
"Microsoft.Windows.SecureAssessmentBrowser", # (10.0.17763.1)",
"Microsoft.Windows.ShellExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.XGpuEjectDialog", # (10.0.17763.1)",
"Microsoft.WindowsAlarms", # (10.1805.1361.0)",
"Microsoft.WindowsCalculator", # (10.1805.1201.0)",
"Microsoft.WindowsCamera", # (2018.425.120.0)",
"Microsoft.WindowsFeedbackHub", # (1.1805.2331.0)",
"Microsoft.WindowsMaps", # (5.1805.1431.0)",
"Microsoft.WindowsSoundRecorder", # (10.1805.1941.0)",
"Microsoft.WindowsStore", # (11805.1001.49.0)",
"Microsoft.Xbox.TCUI", # (1.11.28003.0)",
"Microsoft.XboxApp", # (41.41.18001.0)",
"Microsoft.XboxGameCallableUI", # (1000.17763.1.0)",
"Microsoft.XboxGameOverlay", # (1.32.17005.0)",
"Microsoft.XboxGamingOverlay", # (2.20.22001.0)",
"Microsoft.XboxIdentityProvider", # (12.44.20001.0)",
"Microsoft.XboxSpeechToTextOverlay", # (1.17.29001.0)",
"Microsoft.YourPhone", # (0.0.12084.0)",
"Microsoft.ZuneMusic", # (10.18052.20211.0)",
"Microsoft.ZuneVideo", # (10.18052.20211.0)",
"RealtekSemiconductorCorp.RealtekAudioControl", # (1.2.148.0)",
"Windows.CBSPreview", # (10.0.17763.1)",
"Windows.PrintDialog", # (6.2.1.0)",
"c5e2524a-ea46-4f67-841f-6a9465d9d515", # (10.0.17763.1)",
"microsoft.windowscommunicationsapps", # (17.9330.21365.0)",
"windows.immersivecontrolpanel", #(10.0.2.1000)",
Matteo
25 settembre 2019 - 11:29
Continuo a ricevere un errore sul pacchetto; ho più di 100 postazioni di lavoro che mostrano un errore
Continuo a ricevere lo stesso messaggio:
NoneTrying to remove Microsoft.MicrosoftOfficeHub
NoneTrying to remove Microsoft.MicrosoftSolitaireCollection
NoneTrying to remove Microsoft.OneConnect
NoneTrying to remove Microsoft.People
NoneTrying to remove Microsoft.WindowsAlarms
NoneTrying to remove Microsoft.WindowsMaps
NoneTrying to remove Microsoft.WindowsPhone
NoneTrying to remove Microsoft.WindowsSoundRecorder
NoneTrying to remove microsoft.windowscommunicationsapps
NoneTrying to remove Microsoft.MixedReality.PortalMicrosoft.BingFoodAndDrink
  File "c:\windows\temp\waptdzylcw\setup.py", line 98, in install
Hai una soluzione?
- Debian 9.9
Gaetano
Iscrizioni: 8 agosto 2019 - ore 10:16
Posizione: Tolosa
25 settembre 2019 - 15:08
lo script viene eseguito manualmente su una delle macchine che presentano l'errore?
Matteo
25 settembre 2019 - 16:30
Sulla mia macchina virtuale, il pacchetto non presenta più errori, pur non avendo apportato alcuna modifica.
Su un'altra macchina, invece, riavviando l'installazione, l'errore persiste.
- Debian 9.9
