- Raspbian: versione lite con solo SSH abilitato
- Debian: versione "small installation image" con il minimo indispensabile ("SSH" e "utility di sistema usuali")
Aggiungerò le righe al file e vi terrò informati
. Grazie.
root@srvads:~# kinit administrator
kinit: Cannot contact any KDC for realm 'DOHAKOR.LAN' while getting initial credentials
root@srvads:~# klist
klist: No credentials cache found (filename: /tmp/krb5cc_0)Codice: Seleziona tutto
search dohakor.lan
nameserver 127.0.0.1Codice: Seleziona tutto
[libdefaults]
default_realm = DOHAKOR.LAN
dns_lookup_realm = false
dns_lookup_kdc = trueCodice: Seleziona tutto
[libdefaults]
[realms]
DOHAKOR.LAN = {
kdc = srvads.dohakor.lan
admin_server = srvads.dohakor.lan
}Codice: Seleziona tutto
Ticket cache: FILE:/tmp/krb5cc_0
Default principal: administrator@DOHAKOR.LAN
Valid starting Expires Service principal
05/15/2020 16:42:06 05/16/2020 02:42:06 krbtgt/DOHAKOR.LAN@DOHAKOR.LAN
renew until 05/16/2020 16:41:55Codice: Seleziona tutto
root@srvads:~# samba_dnsupdate --use-samba-tool
Failed to get Kerberos credentials, falling back to samba-tool: kinit for SRVADS$@DOHAKOR.LAN failed (Cannot contact any KDC for requested realm)
ERROR(runtime): uncaught exception - (9711, 'WERR_DNS_ERROR_RECORD_ALREADY_EXISTS')
File "/usr/lib/python3/dist-packages/samba/netcmd/__init__.py", line 185, in _run
return self.run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/samba/netcmd/dns.py", line 945, in run
raise e
File "/usr/lib/python3/dist-packages/samba/netcmd/dns.py", line 941, in run
0, server, zone, name, add_rec_buf, None)
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
raise e
Failed update of 20 entriesCodice: Seleziona tutto
root@srvads:~# host -t SRV _ldap._tcp.dohakor.lan
Host _ldap._tcp.dohakor.lan not found: 3(NXDOMAIN)
root@srvads:~# host -t SRV _ldap._tcp.srvads.dohakor.lan
Host _ldap._tcp.srvads.dohakor.lan not found: 3(NXDOMAIN)
root@srvads:~# host -t SRV _ldap._tcp.dohakor.lan.
Host _ldap._tcp.dohakor.lan. not found: 3(NXDOMAIN)
root@srvads:~# host -t SRV _kerberos._udp.dohakor.lan
Host _kerberos._udp.dohakor.lan not found: 3(NXDOMAIN)
root@srvads:~# host -t A srvads.dohakor.lan.
Host srvads.dohakor.lan. not found: 3(NXDOMAIN)Codice: Seleziona tutto
root@srvads:~# service samba-ad-dc status
● samba-ad-dc.service - Samba AD Daemon
Loaded: loaded (/lib/systemd/system/samba-ad-dc.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2020-05-18 11:24:38 CEST; 4min 45s ago
Docs: man:samba(8)
man:samba(7)
man:smb.conf(5)
Process: 375 ExecStart=/usr/sbin/samba --foreground --no-process-group $SAMBAOPTIONS (code=exited, status=1/FAILURE)
Main PID: 375 (code=exited, status=1/FAILURE)
May 18 11:24:37 srvads.dohakor.lan systemd[1]: samba-ad-dc.service: Main process exited, code=exited, status=1/FAILURE
May 18 11:24:37 srvads.dohakor.lan samba[397]: task[dnsupdate][397]: [2020/05/18 11:24:37.698256, 0] ../../source4/smbd/process_standard.c:84(sigterm_signal_handler)
May 18 11:24:37 srvads.dohakor.lan samba[397]: task[dnsupdate][397]: sigterm_signal_handler: Exiting pid 397 on SIGTERM
May 18 11:24:37 srvads.dohakor.lan samba[399]: task[dns][399]: [2020/05/18 11:24:37.725713, 0] ../../source4/smbd/process_standard.c:84(sigterm_signal_handler)
May 18 11:24:37 srvads.dohakor.lan samba[399]: task[dns][399]: sigterm_signal_handler: Exiting pid 399 on SIGTERM
May 18 11:24:38 srvads.dohakor.lan samba[389]: task[ldapsrv][389]: [2020/05/18 11:24:38.466342, 0] ../../source4/smbd/process_standard.c:84(sigterm_signal_handler)
May 18 11:24:38 srvads.dohakor.lan samba[389]: task[ldapsrv][389]: sigterm_signal_handler: Exiting pid 389 on SIGTERM
May 18 11:24:38 srvads.dohakor.lan systemd[1]: Failed to start Samba AD Daemon.
May 18 11:24:38 srvads.dohakor.lan systemd[1]: samba-ad-dc.service: Unit entered failed state.
May 18 11:24:38 srvads.dohakor.lan systemd[1]: samba-ad-dc.service: Failed with result 'exit-code'.Codice: Seleziona tutto
root@srvads:~# service samba-ad-dc stop
root@srvads:~# service samba-ad-dc start
root@srvads:~# service samba-ad-dc statusCodice: Seleziona tutto
Active: active (running) since Mon 2020-05-18 11:35:32 CEST; 5s ago
Docs: man:samba(8)
man:samba(7)
man:smb.conf(5)
Main PID: 755 (samba)
Status: "smbd: ready to serve connections..."
Tasks: 23 (limit: 4915)
CGroup: /system.slice/samba-ad-dc.service
├─755 samba: root process
├─756 samba: task[s3fs_parent]
├─757 samba: task[dcesrv]
├─758 samba: task[nbtd]
├─759 samba: task[wrepl]
├─760 samba: task[ldapsrv]
├─761 samba: task[cldapd]
├─762 samba: task[kdc]
├─763 samba: task[dreplsrv]
├─764 samba: tfork waiter process
├─765 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
├─766 samba: task[winbindd_parent]
├─767 samba: task[ntp_signd]
├─768 samba: task[kccsrv]
├─769 samba: tfork waiter process
├─770 /usr/sbin/winbindd -D --option=server role check:inhibit=yes --foreground
├─771 samba: task[dnsupdate]
├─772 samba: task[dns]
├─773 samba: tfork waiter process
├─774 /usr/bin/python3 /usr/sbin/samba_dnsupdate
├─780 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
├─781 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
└─782 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
May 18 11:35:28 srvads.dohakor.lan samba[755]: root process[755]: Copyright Andrew Tridgell and the Samba Team 1992-2019
May 18 11:35:29 srvads.dohakor.lan samba[755]: root process[755]: [2020/05/18 11:35:29.544625, 0] ../../source4/smbd/server.c:773(binary_smbd_main)
May 18 11:35:29 srvads.dohakor.lan samba[755]: root process[755]: binary_smbd_main: samba: using 'standard' process model
May 18 11:35:32 srvads.dohakor.lan winbindd[770]: [2020/05/18 11:35:32.467112, 0] ../../source3/winbindd/winbindd_cache.c:3166(initialize_winbindd_cache)
May 18 11:35:32 srvads.dohakor.lan winbindd[770]: initialize_winbindd_cache: clearing cache and re-creating with version number 2
May 18 11:35:32 srvads.dohakor.lan systemd[1]: Started Samba AD Daemon.
May 18 11:35:32 srvads.dohakor.lan winbindd[770]: [2020/05/18 11:35:32.486989, 0] ../../lib/util/become_daemon.c:136(daemon_ready)
May 18 11:35:32 srvads.dohakor.lan winbindd[770]: daemon_ready: daemon 'winbindd' finished starting up and ready to serve connections
May 18 11:35:32 srvads.dohakor.lan smbd[765]: [2020/05/18 11:35:32.569315, 0] ../../lib/util/become_daemon.c:136(daemon_ready)
May 18 11:35:32 srvads.dohakor.lan smbd[765]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connectionsCodice: Seleziona tutto
raise e
0, server, zone, name, add_rec_buf, None)Codice: Seleziona tutto
netstat -tapn | grep 53Codice: Seleziona tutto
root@srvads:~# netstat -tapn | grep 53
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 772/samba: task[dns
tcp 0 0 0.0.0.0:49153 0.0.0.0:* LISTEN 757/samba: task[dce
tcp6 0 0 :::53 :::* LISTEN 772/samba: task[dns
tcp6 0 0 :::49153 :::* LISTEN 757/samba: task[dceCodice: Seleziona tutto
# Global parameters
[global]
dns forwarder = 192.168.1.1
netbios name = SRVADS
realm = DOHAKOR.LAN
server role = active directory domain controller
workgroup = DOHAKOR
[sysvol]
path = /var/lib/samba/sysvol
read only = No
[netlogon]
path = /var/lib/samba/sysvol/dohakor.lan/scripts
read only = NoCodice: Seleziona tutto
[libdefaults]
[realms]
DOHAKOR.LAN = {
srvads.dohakor.lanCodice: Seleziona tutto
127.0.0.1 localhost
127.0.1.1 pc-47.home pc-47
# The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
192.168.1.150 srvads.dohakor.lan srvads
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto enp0s3
iface enp0s3 inet static
address 192.168.1.150/24
gateway 192.168.1.1
# This is an autoconfigured IPv6 interface
iface enp0s3 inet6 auto
