[RISOLTO] Opzioni Logitech
nliaudat
Iscrizioni: 8 agosto 2019 - ore 8:31
13 aprile 2022 - 10:24
Ecco un pacchetto per installare e, cosa ancora più importante, disinstallare Logitech Options:
#https://prosupport.logi.com/hc/en-us/articles/1500002995241-Mass-installation-and-configuration-of-Logitech-Options
#impacted_process  : DJCUHost.exe,LogiOptions.exe,LogiOptionsMgr.exe,LogiOverlay.exe
    print('installing %s' % control.asrequirement())
    install_exe_if_needed("options_installer.exe",'/quiet:1 /update:0 /flow:0 /sso:0 /analytics:0',key='',min_version='9.60.87')
    print('uninstalling %s' % control.asrequirement())
    run('"C:\Program Files\Logitech\LogiOptions\uninstaller.exe" /S')
    run('"C:\Program Files\Logi\LogiBolt\LogiBoltUninstaller.exe" /silent')
def session_setup():
    print('Session setup for %s' % control.asrequirement())
def update_package():
    pass
def audit():
    pass
    if isfile(r"C:\Program Files\Logitech\LogiOptions\LogiOptions.exe"):
        return "OK"
        return "ERROR"
13 aprile 2022 - 15:10
grazie nliaudat :-)
